help
Discussion in 'Wheels & Tires' started by grunt03tx, Apr 28, 2013.
  1. Apr 28, 2013 at 12:19 PM
    grunt03tx
    grunt03tx [OP] New Member
    texas
    2013 prerunner
    Just bought my first tacoma a month ago 2013. I have 245/75/16 stock tires. Im wanting to leave the stock rims for now and put fierce attitude m/t tires on it. Can I go up in size are width are just stick with the size that came on it?
  2. Apr 28, 2013 at 12:24 PM
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
  3. Apr 28, 2013 at 12:25 PM
    jjew18
    jjew18 the Nightman cometh!
    Alliance Airport
    05 PreRunner SR5
    Added extra awesomeness to its original awesomeness.
    If you don't get an answer check with KPT, he is the resident wheel expert. You can but what size are you looking at?
  4. Apr 28, 2013 at 12:26 PM
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    2011 Suburban 2500
    JBA Shorty Headers, Flowmaster FlowFX Sing/Dual Exhaust
    265/75R16 is the largest size you can run without modification. Welcome to the forums. The search tool will be your friend.
  5. Apr 28, 2013 at 2:28 PM
    grunt03tx
    texas
    2013 prerunner
    Thanks for the information.
