"HELP"
Discussion in 'New Members' started by xTACOMAx, Jun 2, 2013.
  1. Jun 2, 2013 at 6:10 PM
    xTACOMAx
    xTACOMAx [OP] Well-Known Member
    07 prerunner TSS
    Rough Country 3 inch lift, Aries bull bar, Spider headlights
    I have a 07 four door long bed prerunner and was wanting to do a lift and was thinking of buying bilsteins 5100's front and rear shocks and set the front ones to 2.5 and was wanting to run toyo open country at2 285/70r17 and dick cepek gunmetal rims 17 x 8.5 backspacing is 5 offset is 6 and was needing to know would them rims give me enough room to run that size of tire?
  2. Jun 2, 2013 at 6:23 PM
    adamiata
    adamiata --
    Auburn, AL
    Way wrong section pal.
  3. Jun 2, 2013 at 6:26 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
  4. Jun 2, 2013 at 6:26 PM
    xTACOMAx
    07 prerunner TSS
    Ok man well what do I need to do?
  5. Jun 2, 2013 at 6:26 PM
    OZ-T
    Peter North
    British Columbia
    Very helpful
  6. Jun 2, 2013 at 6:28 PM
    DriverSound
    DriverSound Señor Member
    SoCaca
    2015 DCSB OR 4x4
    Too few to list.
    Welcome, I run 285's with 5100's currently set at 1.75" though it involves some trimming.
  7. Jun 2, 2013 at 6:29 PM
    xTACOMAx
    07 prerunner TSS
    Do y'all think that set up would be a good set up to run?
  8. Jun 2, 2013 at 6:31 PM
    OZ-T
    Peter North
    British Columbia
    Stock wheels and spacers or aftermarket wheels ?
  9. Jun 2, 2013 at 6:36 PM
    DriverSound
    SoCaca
    2015 DCSB OR 4x4
    Too few to list.
    17X9 aftermarket with 4.5" backspace, -12 offset. No rub on street but did the cab mount chop. Caster currently set at 2.3 though I'm going 885's and LightRacing uppers.
  10. Jun 2, 2013 at 6:37 PM
    DriverSound
    SoCaca
    2015 DCSB OR 4x4
    Too few to list.
    5100's set at 2.5" might be a little stiff for most but some like it. Many run OME 885 coils either with nitro shocks or 5100's.
  11. Jun 2, 2013 at 6:42 PM
    xTACOMAx
    07 prerunner TSS
    Aftermarket there Dick Cepek torque gunmetal, I forgot to add torque to my first post.
  12. Jun 2, 2013 at 6:44 PM
    xTACOMAx
    07 prerunner TSS
    Would it be bad to run a thin wheel spacer if I had to?
  13. Jun 2, 2013 at 6:50 PM
    DriverSound
    SoCaca
    2015 DCSB OR 4x4
    Too few to list.
    I suggest you get the correct wheel so you won't have to run wheel spacers. I believe people here only use wheel spacers on stock wheels so they can run 285's as the stock wheels don't have correct backspace.
  14. Jun 2, 2013 at 6:51 PM
    xTACOMAx
    07 prerunner TSS
    I don't do any off-roading I just do street and just some drive ways but would I still need to chop the cab mount?
  15. Jun 2, 2013 at 6:56 PM
    xTACOMAx
    07 prerunner TSS
    Ok well do you know what size wheel spacer I would need if I used my stock wheels?
  16. Jun 2, 2013 at 7:02 PM
    DriverSound
    SoCaca
    2015 DCSB OR 4x4
    Too few to list.
    It only rubbed the cab mounts on full lock in reverse. whatever setting you choose for your 5100's, get an alignment. Zero camber/toe, Caster at 2+ but hard to do after a lift so that's why people get aftermarket upper control arms to get caster back. I think 1.5" spacers are used for stock wheels though you might want to do a search on that just to make sure.
  17. Jun 2, 2013 at 7:21 PM
    xTACOMAx
    07 prerunner TSS
    Ok thanks man.
  18. Jun 2, 2013 at 7:26 PM
    xTACOMAx
    07 prerunner TSS
    Oh yea one more question would it be bad if I didn't cut the cab mount and just let it rub at full lock in reverse?
  19. Jun 2, 2013 at 7:34 PM
    DriverSound
    SoCaca
    2015 DCSB OR 4x4
    Too few to list.
    Worst can happen is that your tires wear out quicker where it rubs.
  20. Jun 2, 2013 at 7:43 PM
    xTACOMAx
    07 prerunner TSS
    Ok thanks again
