Discussion in 'Toyota Trucks & SUVs' started by larry bliss, Apr 16, 2009.
  1. Apr 16, 2009 at 6:22 AM
    larry bliss
    larry bliss [OP] New Member
    Have a 97 tacoma (2.7) less then 100k, It has just stared getting noisy on top, Does not do it when cold, Do you think I need a Valve adjustment? One more thing, I have been losing water, Can`t see where it`s going, Does not get hot, No water in oil, Thanks in advance for any help,
  2. Apr 16, 2009 at 6:42 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    If you see no evidence of a leak anywhere, you may have a head gasket leaking water into the Combustion Chamber. May need to replace the Head Gasket. May also be the cause of the noise.
  3. Apr 16, 2009 at 7:39 AM
    larry bliss
    Thanks I was kinda thinking that. How would it cause is to make the noise? Thanks.
  4. Apr 16, 2009 at 8:30 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Without being able to hear the noise, Im just guessing at it. If you are looseing coolant, fix that first. If your going to have someone else to the Gasket replacement for you, you may as well have them check the valves to make sure they are adjusted.
  5. May 15, 2009 at 7:15 PM
    devilsalmostfree
    devilsalmostfree Well-Known Member
    Carl
    Loudon, Tn
    99 Tacoma 4X4, 5 spd, 2.7 ltr
    Deck plate mod, intake silencer removed, AFE Pro Dry S Air Filter, debadged, Goodyear Duratracs 265/75R16. Flowmaster knock-off muffler!
    if u have the head off, y not take the head, have it shaved for more compression, see what kinda performance that would do. cause im interested in doing this one day!
  6. May 19, 2009 at 6:03 PM
    justalilcrazy625
    justalilcrazy625 Got the yota feverrrr.
    Mooresville, NC
    '97 2.7L :)
    What kind of noise? Is it kinda surging a bit? I had absolutely no signs whatsoever of my headgasket going until the day that it had happened. It was surging up and down a bit, but I figured before that it had been a bit since I drove it, so I thought maybe bad gas or running out of gas cuzI was about to fill it up to make a 300mile trip. THANKFULLY, it blew before I even hit the highway. Did it in the parking lot as I was about ti leave to go... I was MAJORLY PO'd.
