help!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Marioso, Nov 8, 2009.
  1. Nov 8, 2009 at 1:04 PM
    Marioso
    Marioso [OP] Risueno
    San diego Ca
    2007 Toyota Fj Cruiser
    im trying to find the paint hoodscoop mod. i unscrewed the nuts but the hoodscoop piece wont budge
  2. Nov 8, 2009 at 1:11 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    PM Scottcrumley24, He just recently did this mod....
  3. Nov 8, 2009 at 1:12 PM
    Marioso
    San diego Ca
    ive used the search engine but i cant find the diy thread. just wanted to add that before anyone tells me to use the search button
  4. Nov 8, 2009 at 1:17 PM
    JJ Customs
    JJ Customs Supreme Leader!
    Jay
    NV
    Silverado Crew Cab Z71, 5.3 made from real Tornado's!
    A few additions to make me feel cool.
    How many nuts have you removed?
  5. Nov 8, 2009 at 1:19 PM
    Marioso
    San diego Ca
    all five i count 5 in my pocket
  6. Nov 8, 2009 at 1:20 PM
    JJ Customs
    Jay
    NV
    There are five nuts that have to be removed then 1 recessed screw in the center towards the front of the hood. The screw has a square plastic clip that centers the scoop that you will have to pop out. The front lifts out first with a couple of clips at the top of the scoop that come out at an angle.
  7. Nov 8, 2009 at 1:21 PM
    Marioso
    San diego Ca
    let me try that brb
  8. Nov 8, 2009 at 1:22 PM
    JJ Customs
    Jay
    NV
    The screw is right between the front two nuts. Take that out and you will be gtg. There is a hole in the hood. Get under there and you will see it. I missed it when I tried to take mine off to.
  9. Nov 8, 2009 at 1:25 PM
    JJ Customs
    Jay
    NV
    Now to take the grille out you will have to drill or cut the plastic rivets. No big deal but make sure you have some new rivets and you might have to drill the holes in the plastic tub that it attaches to. Take you time with it and paint your rivets before you put them in because they will show through the grill.
  10. Nov 8, 2009 at 1:27 PM
    Marioso
    San diego Ca
    so i got the screw out and i kept the plastic piece still in the hood...then i fucked up and i lifted up the hood and it slid to the back of the hood...fml
  11. Nov 8, 2009 at 1:29 PM
    JJ Customs
    Jay
    NV
    You should be able to fish it out, if you are not able to then you should be able to fab up something pretty easy. Let me know if you need anything else bro.
  12. Nov 8, 2009 at 1:31 PM
    Marioso
    San diego Ca
    the rivets i can cop at homedepot???
  13. Nov 8, 2009 at 1:32 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
  14. Nov 8, 2009 at 1:33 PM
    JJ Customs
    Jay
    NV
    Yeah you can get the rivets at any hardware or auto store. I used aluminum ones and a rived gun but if you don't have a rivet gun then look for some plastic ones or some push in clips. Remember the shorter the better because they will poke through.
  15. Nov 8, 2009 at 1:35 PM
    JJ Customs
    Jay
    NV
    If you are going to paint the whole scoop then don't even take it apart. You could just tape it up to.
  16. Nov 8, 2009 at 1:36 PM
    ColtsTRD
    Scott
    AZ
    I don't recomend that...over spray is a bitch lol
  17. Nov 8, 2009 at 1:41 PM
    DanGer
    DanGer Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
  18. Nov 8, 2009 at 1:43 PM
    ColtsTRD
    Scott
    AZ
  19. Nov 8, 2009 at 2:02 PM
    Marioso
    San diego Ca
    i got the fusion and i didnt sand or anythign i degreased it thats it. i did a few coats there are dots of red paint where the paint isnt covering.
  20. Nov 8, 2009 at 3:01 PM
    Marioso
    San diego Ca
    this isnt going too well...dimples in the paint. i over sprayed so i tried to whipe it with napkin, didnt work. so i got a razor blade and took the pieces of napkin that stayed on , repainted but u can see the marks where i peeled paint off and napkin. fuck
