Here's somthing I didn't know about lug nuts
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 06Tacooo, Aug 12, 2016.
  1. Apr 7, 2020 at 9:50 PM
    #41
    Waasheem
    Waasheem
    2007 xrunner
    Not speed racers brother?
  2. Dec 31, 2023 at 12:20 PM
    #42
    wolfe-tacotraveler
    wolfe-tacotraveler New Member
    Levi
    stock 2010 trd sport access 4x4
    I see this thread hasn’t been active in awhile, I’m curious about corrosion. Have those eBay nuts rusted at all, any signs of corrosion? Still usable? I live in the Midwest, winter is accepting my truck will be covered in salt darn near the whole time, I’m worried these would rust pretty quickly.
    #42
  3. Jan 1, 2024 at 1:56 AM
    #43
    06Tacooo
    06Tacooo [OP] Earth Czar
    Mark
    39° 14' N / 83° 13' W
    06 Off Road Access Cab Indigo Ink Pearl
    Michelin Defender LTX M/S2, ABS kill switch, Tech Deck, Mirror riser, Ride-Rites, BF Garmin GPS
    They're about the same quality as the originals. I still have them on the truck, so they have held up. I torque them when checking things, and they're holding. No loose outer shells, no corrosion. Taco sits outside, in OH, doesn't get driven much. Based on everything, they were a good buy.
    Make sure you use the correct socket. Most problems come from the outer thin shell deforming, socket won't fit, combined with air tools hammering them. The outer shells deform, changing socket size slightly over time. There are special sets of three sockets, made just for this issue. I keep mine in the truck. I don't let any shop install/remove tires, if at all possible. Solids are available and expensive. I went the cheaper route, so far so good.
    wolfe-tacotraveler likes this.
  4. Jan 1, 2024 at 3:44 AM
    #44
    RLMoody
    RLMoody Well-Known Member
    2017 Toyota Tacoma SR
    Lug nuts also swell over time. I found that out with my 13 Sienna recently when I couldn't get a wrench on them to loosen. Had to tap it on with a hammer and wiggle them to break loose. Ford lug nuts were notorious for doing that. The dealership I worked at took advantage of every customer coming in for oil changes and tire rotations by telling everyone their lug nuts were swollen and needed replaced. Most people trusted the dealership.
    06Tacooo[OP] likes this.
  5. Jan 1, 2024 at 8:12 AM
    #45
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Better to replace them at the dealer than be stuck beside the road trying to change a tire with a lug wrench that won't fit over the lugnuts
    06Tacooo[OP] and wilcam47 like this.
  6. Jan 1, 2024 at 8:16 AM
    #46
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Don't be afraid to use a generous amount of anti-sieze on the threads of each stud. Put a dab inside the nut and try to keep it off the face where the nut contacts the wheel. It's the friction between the nut face and the wheel that holds the torque. The threads themselves can be quite goopy and it won't affect torque or risk backing off.
    And use a good quality nut with the thin metal cap over it. Something that covers the threads and keeps the elements out
    #46
  7. Jan 1, 2024 at 8:22 AM
    #47
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    i wouldnt call it swollen...id call it made poorly (pos). Ive switched to solid lugs on my F150. No issues since
  8. Jan 3, 2024 at 12:54 PM
    #48
    ToyotaMan2015
    ToyotaMan2015 Well-Known Member
    Nathan
    Somerset KY
    2015 Tacoma Limited
    32in Tire
    This is exactly why I bought 1/2 size sockets. I have a 15 with over 200k. What happens with these lugs is overtime, they swell. Mine are so bad, some a 21.5mm socket wont fit on them, have to bump up to a 22mm. So, if you do your own work like me doing rotations and such and have a powerful impact, spend the money on those sockets and be done with it. You want the best fitting socket for your lug when you go to remove them. They will twist on you if you do not. Last I heard, oem lugs for these are $20 a piece. I carefully remove them with my impact when I need to work on it. While its on a lift, I use my milwaukees bolt mode to put them back on. It stops at 50ft lbs. Drop it on the ground, and torque them to 83ft lbs. I will link below those sockets. They are a must have.
    https://www.amazon.com/ARES-59065-S...refix=ares+1/2+size++lug+,aps,127&sr=8-1&th=1
  9. Jan 3, 2024 at 1:02 PM
    #49
    golfindia
    golfindia Well-Known Member
    Yes.
    pickup truck
    They're chrome plated, actually. Chrome is brittle like glass. Impact wrench cracks it and it's toast.
