Hesitation in 4WD
Discussion in '3rd Gen. Tacomas (2016+)' started by cjwilk, Jul 6, 2020.
  1. Jul 6, 2020 at 6:04 AM
    cjwilk
    cjwilk [OP] Member
    Connor
    2020 White Tacoma TRD OR
    I have a 2020 OR that I bought new a month ago.
    When I have it in 4WD, there is a significant hesitation driving or in reverse. It almost feels like my wheels can’t get traction and things are slipping.
    The dealership said because it hasn’t thrown a code and no lights are on, there’s nothing they can do.
    What are my next steps?
  2. Jul 6, 2020 at 6:06 AM
    ToyoTaco25
    ToyoTaco25 Well-Known Member
    North Carolina
    09 Super-White DCSB 6-Speed
    PROCOMP 4" LIFT, AMP RESEARCH POWERSTEPS, 285/70-R17’s, MAGNAFLOW, AFE COLD AIR INTAKE, DIPPED BADGES/GRILL
    Are you on pavement when this happens?
    wilcam47 and m603holden like this.
  3. Jul 6, 2020 at 6:20 AM
    cjwilk
    cjwilk [OP] Member
    Connor
    Yep. And while it’s worse when it’s wet outside, it does the same thing when it’s dry if there is any resistance (curb, uneven pavement, etc).
  4. Jul 6, 2020 at 6:23 AM
    Rock Lobster
    Rock Lobster knows nothing, yet an expert in everything.
    Dee Eff Dub
    Sport Crew represent
    Welcome to TW. Can you describe this hesitation in more detail please? Like start to finish, what is it doing? Is it clunking? throttle delay? actual wheel slip?
  5. Jul 6, 2020 at 6:25 AM
    sbx22
    sbx22 Well-Known Member
    Norcal
    2020 TRD DCSB OR 4x4; 2005 TRD sport PreRunner DCLB
    Bilstein 5100
    I wonder if you can get it in action, have someone record?
  6. Jul 6, 2020 at 6:27 AM
    cjwilk
    cjwilk [OP] Member
    Connor
    When I press on the gas, nothing happens until I essentially mash it to the floor. When I do press the pedal more forcefully, it will act as if it cannot get traction and do lots of slipping. As soon as I turn 4wd off, the problem goes away.
  7. Jul 6, 2020 at 6:29 AM
    m603holden
    m603holden @Koditten Pirate Radio member #063
    Marteeen
    New England
    2017 Tacoma DCSB OR MT
    Lots of sail boat fuel
    Don't do that on pavement...
  8. Jul 6, 2020 at 6:33 AM
    jowybyo
    jowybyo Mobtown Offroad
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    42 Designs Catch Can Mobtown Offroad Ribbed Tailgate Skin Mobtown Offroad Tailgate Cap Mobtown Offroad Locking Storage Doors Mobtown Offroad Utility Bed Bars (Prototype)
    Do you have the steering wheel turned while you are doing this?
    trazerr and Chew like this.
  9. Jul 6, 2020 at 6:38 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    This is what I was thinking, sharp turn on dry pavement in 4wd is going to bind big time.
    Skydvrr likes this.
  10. Jul 6, 2020 at 6:39 AM
    cjwilk
    cjwilk [OP] Member
    Connor
    Not usually. One great example is backing out of my driveway. There is a small incline/lip at the end of my driveway that you have to go over to get out. When it was storming last week, I went to back up in 4wd, and there was a ton of hesitation and almost like it couldn’t get traction. However, there was no standing water or anything that would prevent traction. My wife’s CRV had zero issues when she pulled out right next to me.
  11. Jul 6, 2020 at 6:40 AM
    ToyoTaco25
    North Carolina
    Yeah, don't use 4x4 on pavement unless you really have to - it will grab and bind and not want to drive and feel really funny (almost like slipping). Try using your 4x4 on grass and see if it acts the same.
    Is this your first 4x4?
  12. Jul 6, 2020 at 6:40 AM
    Chew
    Chewy
    Midwest
    19 TRD OR
    Does this only happen in 4wd?
  13. Jul 6, 2020 at 6:41 AM
    cjwilk
    cjwilk [OP] Member
    Connor
    I have a 4x4 Nissan NV (big ass 12 passenger van/SUV), and I’ve never had issues. But this is my first truck.
  14. Jul 6, 2020 at 6:42 AM
    cjwilk
    cjwilk [OP] Member
    Connor
    Yes, only in 4wd.
  15. Jul 6, 2020 at 6:48 AM
    3JOH22A
    3JOH22A Cunning Linguist
    District 6ix
    3rd Gen TRD Off-Road on 35"s
    Is your 4WD indicator light solid (not flashing) in the gauge cluster?
    What tire pressures are you running? Rears should be 1-2 psi lower than the fronts if you have an empty bed. This to keep the front and rear rolling radii the same.
    Chew likes this.
  16. Jul 6, 2020 at 6:55 AM
    m603holden
    Marteeen
    New England
    Sick.
    Those only come in 2wd. I've seen some cooler 4x4 conversions. Did you do it or the previous owner?
    Your wheels are probably binding. See if it still does it with the wheels straight or if it only happens when the wheel is cut.
  17. Jul 6, 2020 at 6:55 AM
    Chew
    Chewy
    Midwest
    19 TRD OR
    Try backing up in 4wd somewhere else, and see if it's still an issue. If you can easily duplicate the issue, that'll save you time at the dealer, but make sure you make it clear, you want to drive and have the tech or writer witness the issue.
    Note; you don't need a CEL to report an issue, but that's why I say make sure you're driving and easily able to duplicate. If you don't, they'll most likely move parking spots and say all good, can't duplicate customer complaint!
  18. Jul 6, 2020 at 7:22 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    I was surprised how slick the 4wd actuator works on these 2020 tacos compared to my gen1 tundra where there was a flashing green delay before 4wd locked in. Soon as i twist the 4wd knob on the taco it locks in no matter what, and without any clunking.
  19. Jul 6, 2020 at 7:34 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    You are NEVER, EVER, supposed to be operating in 4X4 unless you are on a slippery surface. And wet pavement does not qualify. You bought a 4X4 truck and 4X4 is intended to be used in harsh OFF ROAD conditions. It is OK in DEEP snow on pavement or on ice. Continuing to use it on hard dry surfaces will result in breaking expensive parts.
    Chances are the Nissan you drove is AWD which is a different system designed to be used on pavement. AWD does great in light snow, wet pavement, and even light duty off road driving, but isn't as good in harsher off road conditions or deep snow.
    zoo truck and m603holden like this.
  20. Jul 6, 2020 at 7:38 AM
    EatSleepTacos
    Randy
    Hampton Roads, VA
    4x4 2005 SR5 AC 6MT
    I assumed that as well until I took a couple seconds to do a google search. It's not AWD.
    m603holden likes this.
