Hesitation in 4WD
Discussion in '3rd Gen. Tacomas (2016-2023)' started by cjwilk, Jul 6, 2020.
  1. Jul 6, 2020 at 8:10 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Boy if i ever used 4wd on pavement with the tundra....felt like all hell was going to break loose taking a slow sharp corner. I guess its referred to as crow hop.
  2. Jul 6, 2020 at 8:15 AM
    bulalo
    bulalo Well-Known Member
    SoCAL Inland Empire
    2017 trd offroad 4wd LB
    KDMax pro 9.0
    Wow. Don’t use 4wd on pavement . You’ll break it. It’s not cheap
  3. Jul 6, 2020 at 8:44 AM
    andrewbrandon19
    andrewbrandon19 Well-Known Member
    Assuming you are backing out onto a paved road: you are in 4x4 and not going in a strait line as you are transitioning from driveway to roadway. That means you are in 4x4 while on a surface that has no give like mug and dirt leading to the tires having to give. That means the tires are putting a boatload of stress on the axels/differentials and are hopping/skipping across the road surface.
    https://youtu.be/Jk246sutET0
  4. Jul 6, 2020 at 9:25 AM
    adk_tacoma
    adk_tacoma Well-Known Member
    Joe
    Waterford, NY
    2016 quicksand tacoma sr5
    Westin outdoors man winch brush guard, custom switch board, Custom machined tow hooks, 255/85/r16 tires, trd shocks and struts, oba in bed cubby, ladder rack, JDUB skid plate
    If your climbing something 5+ inch tall like a curb in 4H with an automatic trans, and you squarely creeped up to the curb and/or stopped at the bottom . It will severely hesitate as the truck tries to haul its fatness up the curb. the same as trying to climb a curb in 2H. If this describes your approach to your drive way try adding a little more momentum to your appoach or shift it into 4L
    How do you recommend backing over a curb into a narrow grassy gap between houses with a sidewalk placed right where your back tires land when your fronts hit the curb? And do it slow enough to not knock your kidneys or stearing alignment out
