hesitation of the rev up when stabbing the gas.
Discussion in '1st Gen. Tacomas (1995-2004)' started by K-2ombs, Jun 15, 2009.
  1. Jun 15, 2009 at 6:28 PM
    K-2ombs
    K-2ombs [OP] New Member
    Binghamton,NY
    95', 2.7, 4x4
    Does anyone know what may be causing the hesitation to rev? Both oxygen sensors were just replaced, but that hasn't seemed to change things enough. Also with the frame rust issue............Are there some years worse than others........? Where does the 95 rate? Can vin #'s tell any tale? Like has there been a correlation found about this rusting issue?
  2. Jun 15, 2009 at 6:35 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    welcome to tw.
    couple of things maybe.....whens the last time the plugs were changed.....last time throttle body was cleaned/fuel filter replaced??
  3. Jun 15, 2009 at 6:37 PM
    Burgman
    Burgman I KEEEEEL YOU
    Stephen
    Ric VA
    08 PreRunner TRD sport Silver
    K&N intake, Boston Acoustic SL 60 6.5 components up front, Rockford Power T16 6.5 in rear, Pioneer P4100 HU, Soon to be Pioneer Prs 4200f
  4. Jun 15, 2009 at 6:38 PM
    K-2ombs
    Binghamton,NY
    95', 2.7, 4x4
    I don't know about the throttle body, but the plugs were changed about 39k ago.........I don't know a lot because I am in the process of buying this truck.
