Hesitation on accelerating from a stop?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Dawnpatrol, Feb 17, 2017.
  1. Mar 20, 2017 at 9:55 AM
    #41
    OdiN1701
    OdiN1701 Well-Known Member
    Colorado
    2017 Quicksand TRD OR DC SB
    ECT helps with towing, but I have not found any lag at all with it off.
    Herniator likes this.
  2. Mar 20, 2017 at 10:56 AM
    #42
    Defuser
    Defuser Virtually Unknown
    Treasure Coast, FL
    17 DCSB TRD OR SSM
    I experienced this phenomenon when I test drove a different '17 Tacoma. It was a bit unsettling.
    I have not replicated it in the second truck (which I bought).
    shakerhood likes this.
  3. Mar 22, 2017 at 6:45 AM
    #43
    Karlyrie
    Karlyrie Well-Known Member
    Northern New England
    2016 Blue Tacoma,DC SB,V6,4X4
    So I had to try your test out, and you are right,i even looked in the rear/side mirrors swearing there really was a parachute back there that sucked all the power away. I have been using the ECT for a few days now,and I thought well there goes my gas mileage,but now I am getting 2mpg more!
    dubstyle7 and Dawnpatrol[OP] like this.
  4. Mar 23, 2017 at 10:46 AM
    #44
    DoubleAction
    DoubleAction Well-Known Member
    Interesting, mine did this a few times early on but it stopped after the 3000 mile mark. Cant get it to do it again. Not sure but it seems the tranny was in a learning mode at the time.
  5. May 20, 2017 at 10:32 AM
    #45
    Ddam
    Ddam New Member
    Dave
    I have a 2017 Tacoma occasionally it hesitates when I pull out in traffic and get on it. Scares the hell out of me because I need it
    to get up and go. It doesn't do it all the time
  6. Oct 7, 2017 at 5:33 AM
    #46
    BOONDOCKSAINT
    BOONDOCKSAINT Well-Known Member
    Central Louisiana
    WHITE 2016 DC OFF ROAD 4X4
    Pioneer 400w amp Infinity Reference Ref 6x9 (front doors) Infinity Reference Ref 6 1/2(rear doors) Kicker HS 8" hideaway
    Was searching for this because, I’m coming up on the end of my factory warranty and wanted to make sure i didn’t need to do anything.
    I will say the ECT button helps a lot!
    I ended up buying a sprint booster which seems to have alleviated the problem.
    Also seems to have eased the problem a bit with searching for the right gear when my cruise is set and on an incline.
    Only have had a small sample of this back and forth from work, so it could be I’m honeymoon phase with it............but it is a nice addition ;-)
  7. Oct 23, 2017 at 7:10 PM
    #47
    Hockeymc3
    Hockeymc3 Well-Known Member
    Colorado
    2017 Super White Tacoma Off-Road
    I have this video up in another thread, but thought I would post it here in case it helps someone Identify their issue. This has nothing to do with traction control or any of the other theories out there. No one has a clue yet as to what is causing this and as of today Toyota does not have fix.
    https://www.youtube.com/watch?v=5sivngR62Pw
  8. Oct 26, 2017 at 10:41 AM
    #48
    Karlyrie
    Well to update my post.The last time I went to have the truck serviced I bitched about the transmission not shifting right,they did the computer update and now I seem to be squealing my tires upon take off alot,I have no hesitation problem now. Traction control off.
  9. Oct 27, 2017 at 9:39 PM
    #49
    Hockeymc3
    Colorado
    You shouldn't have to get in your truck and turn the traction control off every time you drive. The traction control is not linked to the hesitation. Glad it's running better for you though.
  10. Nov 28, 2017 at 5:51 PM
    #50
    DiabloTRD
    DiabloTRD Well-Known Member
    Clearwater, FL
    2017 DCSB TRD Sport (OVT)
    OVT, Spidertrax 1.25, K&N CAI, Dynomax Super Turbo exhaust, Clazzio seat covers
    I seem to have this problem also but not from a stop. It happens when it’s in 2nd gear. It hesitates and then the power kicks in jerking the entire truck. It doesn’t do it with the ECT on though. I’ve had it less than a week and already wish I could default the ECT on always. Lol. I would think that it would already have the new update done. I might take it to check though. Love everything else about it.
  11. Nov 28, 2017 at 6:34 PM
    #51
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    here you go, keep checking this thread until more go up for sale. i got mine works great.
    https://www.tacomaworld.com/threads/ect-auto-turn-on-module.514627/
  12. Nov 29, 2017 at 11:08 AM
    #52
    lostskiier
    lostskiier Well-Known Member
    JK
    Western Slope of Colorado
    Mine does this with ECT on, ECT off, Traction control on, Traction control off, AC on, AC off..... I've run it through every conceivable variation to try get to the bottom of it, including various octanes(which I have found that the truck without a doubt runs better on 91). I currently have an open case with Toyota Corporate and they have admitted that there is an issue and they are working on a solution to the problem.... time will tell
  13. Nov 29, 2017 at 11:26 AM
    #53
    Jaque8
    Jaque8 Well-Known Member
    2017 Inferno TRD OR
    You SURE you're not just letting off the gas?? I mean I could make a video just like this problems or not, just film myself accelerating to 15mph then just going off throttle and letting the truck slow down. Or is there a smaller hesitation you're trying to illustrate that I'm missing??
    I have a hard time believing your truck is just completely dying like that and Toyota not fixing it...
  14. Nov 29, 2017 at 11:43 AM
    #54
    jakes1
    jakes1 Active Member
    Ore.
    2017tacoma Black crew SR5
    3" leveling
  15. Nov 29, 2017 at 11:49 AM
    #55
    jakes1
    Ore.
    3" leveling
    Mine has not died-- but long hesitation no power dead in water from stop signs--- coasted side of hwy twice, other 4 times it came back to life after seconds-- people behind you not impressed--- there is nothing-- : master warning comes on: ( this is mine-- after 7 months of fine) other than surging--small hesitations shifts constantly) can live with all that. 3 appointments at dealership to check for code-== it read none so say nothing wrong. Said call Texas if problem or another dealership---- am not driving 2 1/2 hrs away to check for a code. They sure took the check tho!!!! Texas told me several times ( I have a case #) that not heard of this! Hope all that do have issue calls so they will try figure it out. ( Cannot duplicate it) No way. Dealership does not care.
  16. Nov 29, 2017 at 12:03 PM
    #56
    jakes1
    Ore.
    3" leveling
    I am not letting of gas--- when you pull out from a stop sign you are going and getting out of way.
  17. Nov 29, 2017 at 12:06 PM
    #57
    lostskiier
    JK
    Believe it.......... I have the exact same problem and the case manager I'm dealing with has admitted that the problem exists.
    jakes1 likes this.
  18. Nov 29, 2017 at 6:42 PM
    #58
    dubstyle7
    dubstyle7 Well-Known Member
    Nic
    Dana Point, CA
    2016 Super White Tacoma TRD Sport 4X4 DCSB
  19. Nov 29, 2017 at 10:31 PM
    #59
    Hockeymc3
    Colorado
    Why would I make a video of not being sure if I was taking my whole entire foot off the gas 3 times in a row then post it for input of why it was hesitating?
    This is from flooring it and keeping it floored and it cuts out 2 to 3 times at 1500 rpms then goes. I've had it at Toyota 3 times and they have no clue. I have a case open as well.
  20. Nov 29, 2017 at 10:36 PM
    #60
    Hockeymc3
    Colorado
    Here is another video I made the other day. Each time you see the camera bump is when it hesitates. Some days it does this all day. Other days it don't do it at all.
    https://youtu.be/z-AkrrbTosY
