Hey Connecticut, our everything hurts
Discussion in 'North East' started by Jrs13086, Jan 3, 2014.
  1. Aug 24, 2020 at 4:31 PM
    tattooedsnake
    tattooedsnake Well-Known Member
    Erick
    Connecticut
    '10 TRD sport 4x4
    -Bilstein 6112 front shock. Leveling lift -Bilstein 5100 rear shock w/TSB leaf pack. -Cooper Rugged Trek 265/70/17 -EBC front ultimax rotors w/yellow pads -Stoptech sport rear drums -Steel braided brake lines -Wet Okele seat covers front/rear with heaters -Custom built exhaust with Black Widow venom 250 muffler -Afe Stage 2 Dry CAI -Diode dynamics SS3 fog lights yellow. -OPT7 Projector Headlight Assembly w/Black backing -Undercover Flex Tonneau cover -Weather Tech floormats front and back
    I got these parts sitting in my closet waiting for it to cool down so that I can install them. The blower motor resistor is what causes the fan speed issues. It might also be worth replacing the blower motor fan assembly itself if you are going to do the resistor. The blower motor gets noisy as it ages and makes a loud squeeking sound,most noticable at lower fan speed ironically.
    https://www.tacomaworld.com/threads/replacement-of-hvac-blower-motor-resistor.8310/
  2. Aug 24, 2020 at 5:02 PM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    I'm an old mechanic but I have neither a mustache nor a dwell meter :rofl:
  3. Aug 24, 2020 at 7:00 PM
    jas235
    jas235 Member
    On the hunt!
    Flamig Farm! Love that place...nice sticker.
    TOMB and Cativelense like this.
  4. Aug 25, 2020 at 2:35 AM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
  5. Aug 25, 2020 at 3:48 AM
    lynyrd3
    Bill
    East Central Upstate NY
    Morning Connecticut :hattip:
  6. Aug 25, 2020 at 4:16 AM
    Cativelense
    Cativelense Well-Known Member
    Nuno
    CT
    2014 DCSB Black 4x4 TRD Sport
    -TRD oil cap -TRD radiator cap -TRD shift knob -2015 Entune system with Nav, -OEM roof rack -Front windows tinted to match back (20%) -BPK Skid Plate -Non clock hazard switch assembly -WeatherTech floor mats -AFE Stage II Pro Dry Intake -AVS Vent Shades -AMP Research bed extender -Horn relocation mod -Bob's Mirror -Redline hood struts -UltraGauge MX 1.3 -Debadged -Reverse LEDs & shifter bezel LED -Black steering wheel controls, black shifter bezel, black AC vent panel -Black gauge cluster rings + black tweeter rings -Morimoto XB LED fog lights -Anzo tail lights -Hilux 4x4 lighted switch -Bed mat -Hondo Garage radio knobs -OKLED 20" light bar mounted on BAMF behind the grill mount -CH4X4 LED light bar switch w/add-a-fuse -nd4spdbh fog light anytime mod (HUGE thanks to @tgriff) -Debadged bed -Secondary air pump filter -Retros (Morimoto Mini H1's and Morimoto Panamera shrouds with dual intensity LED DRL's & 5000k bulbs) -Tailgate Anti-Theft Device by @scleaf -OEM TRD Sport 17" wheels painted black w/Bridgestone Blizzak DM-V1 tires (Winter wheels) -Pro Comp Extreme 17" wheels w/Firestone Destination LE2 tires (Spring/Summer/Fall wheels) -Anzo blacked out third break light -HomerTaco Tacoma Ghost Raptor Insert -Rear diff breather mod (HUGE thanks to @jc11taco89) -Fumoto Valve -LEER 100R -Salex center console and glove box organizers -Power Pop N Lock -Mobtown Tailgate Skin -TRD Pro suspension with HS Progressive AAL (overload leaf in) -ECGS replacement bearing -Dust caps on rear drums to match front -Me-So Customs "The Gasshole" -ACEkraut license plate bracket -mesojdm's 2nd Gen Ultimate LED Dome and Map lights -Seat spacers from olecoot -Bullaculla Trailer Harness Relocation Bracket
    Morning everyone. Happy Tuesday.
  7. Aug 25, 2020 at 4:56 AM
    lynyrd3
    Bill
  8. Aug 25, 2020 at 5:04 AM
    Breakfast Taco
    Breakfast Taco Well-Known Member
    SW CT
    2002 4x4 5spd 2.7L
    morning everyone.
    @Cativelense go get your mower back. Bet it's in parts. Have him double check for the bits still on his bench. He'll give you all the bad motor parts & forget a transmission link or something you need.
    On a happy lawn note - taking down those 4 trees, I now have 1/3 less lawn to mow. Not sure how they managed to completely eliminate all signs of grass (& daisies) with their trucks. But less mowing for me is always good. Going to have a good mud pit back there tonight.
  9. Aug 25, 2020 at 6:41 AM
    santas212
    santas212 I'm on a boat!
    Georgetown, CT
    '09 DCLB, TRD Sport, Barcelona Red
    Mostly miscellaneous electronic mods.... -2 spare Electrical fuse blocks hard wired to the battery with a key on relay. -Hard Wired Radar detector over rearview mirror. -2 Dual Whelen Avenger blue LED emergency lights, one on each side of the rearview mirror. -EP911 Blue LED Light Bar & Traffic Advisor, Rear Windows. -4 corner amber strobes in stock lights. -Hardwired RF Scanner with external speaker under center console. -Huskyliner front splash guards -Fireband 2 way radio in center console. -Herculiner painted on hitch and skid plate. -Switch to power one 12v socket when truck is off. -AntiDark LED strip under hood with switch. -Timbren Rubber Springs - Rear -MBRP Offroad Cat-Back with Resonator -Duratrac's -Provisor -Color matched hood bug shield
    Thanks all for the help with the fan blower resistor info. Big help. Last night on my way home I reached under the glove box and jiggled all the wires that I could feel which is where the resistor and connector are as described in the links you all shared. And voila back in action! I’ll try to get under there with a can of contact cleaner at some point and then move to replace the whole resistor if it becomes clear I can take the easy way out.
  10. Aug 25, 2020 at 6:49 AM
    Checkers10160
    Checkers10160 Well-Known Member
    Chess
    Westchester/Fairfield
    05 Access Cab Long Bed
    OME 885s Bilstein 5100 Deaver AAL AP Sliders SOS Skids Rear diff breather relocation
    It's about an hour from me but always a nice trip when it's not 90 degrees out... Those ostriches freak me out though lol
    jas235[QUOTED] and Cativelense like this.
  11. Aug 25, 2020 at 9:39 AM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    Sounds like the easy way at least thus far. Always the preferred method
    Cativelense likes this.
  12. Aug 25, 2020 at 2:58 PM
    tattooedsnake
    Erick
    Connecticut
    '10 TRD sport 4x4
    Take a look at this thread explaining the issue with the resistor. Hitting it with your fist will only fix it for a little bit. Hitting with a hammer will fix it for a little bit longer but eventually the blower motor itself will end up drawing too much current and continuously pop even new resistors. It's a design issue with the blower motor aging. Toyota has the resistor wired so that it will only give you high speed with the blower so that there is minimal load going on to the resistor. You might get lucky and not have an issue with the blower motor itself for a long while. I've been dealing with the resistor issue for about a year and a half just hitting it with my fist.
    https://www.tacomaworld.com/threads/resistor-blower-motor-or-wiring-whats-going-on.495912
    Post 17
  13. Aug 25, 2020 at 3:06 PM
    ABA180
    East Bridgewater MA
    https://www.tacomaworld.com/threads/resistor-blower-motor-or-wiring-whats-going-on.495912/[/QUOTE]
    Makes sense..I've not encountered it personally yet. See if it does it again and then go the route that Snake posted
  14. Aug 25, 2020 at 3:12 PM
    tattooedsnake
    Erick
    Connecticut
    '10 TRD sport 4x4
    If it takes 100k+ miles for that to become an issue it is fine with me. Seems small enough.
    Breakfast Taco and Cativelense like this.
  15. Aug 25, 2020 at 9:21 PM
    Breakfast Taco
    SW CT
    2002 4x4 5spd 2.7L
    @Cativelense , it just occurred to me, you flipped your deck boards.
    usually they are laid with the grain curving down to prevent cupping.
    Wondering if you're getting any edges raising after a dry summer, boards flipped grain up.
    Wondering if they lose that tendency at some point...
  16. Aug 25, 2020 at 9:32 PM
    Cativelense
    Nuno
    CT
    Not that I've noticed. I'll have to take a look tomorrow, just to make sure.
  17. Aug 26, 2020 at 2:33 AM
    vssman
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Morning all
  18. Aug 26, 2020 at 3:33 AM
    Bridge4
    Bridge4 Well-Known Member
    MA
    2003 DCSB Imperial Jade
    Heard a rumor up north its @Cativelense birthday today
    Happy Birthday Buddy!!!:bananadance::bananadance:
  19. Aug 26, 2020 at 4:23 AM
    Cativelense
    Nuno
    CT
    Morning everyone. Happy hump day.
    LOL! Thank you sir!
  20. Aug 26, 2020 at 5:50 AM
    TOMB
    TOMB Well-Known Member
    Tom
    Newington Ct. 06111
    2013 Access cab Sport -super white
    Changed all drain plugs to Dimple Magnetic plugs UNI filter on air pump
    Happy 29th again
    TOMB
