Rear diff rebuild due--254000 miles
Discussion in '1st Gen. Tacomas (1995-2004)' started by Blakeus Maximus, Jul 15, 2019.
  1. Jul 15, 2019 at 10:05 AM
    Blakeus Maximus
    Blakeus Maximus [OP] Well-Known Member
    Southwest
    2000 TACOMA TRD 4X4
    So I've owned my 2000 Tacoma since 2003. I got it with 30k on it and now have 212K. Over the last 6 months my truck has been making a light screeching metal sound when driving, mainly at freeway speeds, but now I'm hearing it on city streets. I know what bad bearings sound like and this doesn't sound like bearings. I'm wondering if that sound could be the bearings. It kind of sounds like the wear indicator on the brake pads but those are fairly new. Have any of you guys heard anything like that before? Thanks in advance!
    GQ7227 and cruiserguy like this.
  2. Jul 15, 2019 at 10:08 AM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    Prolly best to pull the wheels and at least look at the brakes. Typically you hear the brake pad squealers at low speeds
  3. Jul 15, 2019 at 10:11 AM
    Blakeus Maximus
    Southwest
    2000 TACOMA TRD 4X4
    Yeah I first noticed it at freeway speeds. I will look at the pads again though. The rotors and pads are about a year old though.
  4. Jul 15, 2019 at 10:17 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Also check the dust plate on your brakes. That thin sheet metal might be contacting the rotor.
    Can you tell at all where it's coming from?
  5. Jul 15, 2019 at 10:20 AM
    Blakeus Maximus
    Southwest
    2000 TACOMA TRD 4X4
    That’s a good idea, it sounds like the front, but the sound isn’t consistent like that. I’ve been in the collision industry for 20 years and I’m aware of weird sounds that car and truck make. I will check that though.
    cruiserguy likes this.
  6. Jul 15, 2019 at 10:24 AM
    jbrandt
    Justin
    your avatar looks the same size as everyone else's...
  7. Jul 15, 2019 at 10:27 AM
    cruiserguy
    Elijah
    SEKS
    Has the sound worsened over these 6 months? Or pretty much is same and just comes and goes?
  8. Jul 15, 2019 at 10:38 AM
    Blakeus Maximus
    Southwest
    2000 TACOMA TRD 4X4
    It sounds the same is it always has, seems like I hear it more at freeway speeds though. Bearings are more of a vibration and humming sound right? I didn't know if they sounded different on these Tacomas though. I will look at the brakes and the dust shield though.
  9. Jul 15, 2019 at 10:40 AM
    cruiserguy
    Elijah
    SEKS
    Yeah, how you describe the bearings is how I'd describe it as well
  10. Aug 13, 2019 at 4:04 PM
    Gritto
    Gritto Mrs Gritto's First Husband
    Nowhere Else, Pottsylvania
    2006 AC AT V6 PreRunner
    Stock. SR5 Package #2.
    Sometimes threads just end with no resolution.
    Or maybe the OP is still living with the noise? :notsure:
    I came across this thread while searching for possible causes of a noise coming from my driver's side front wheel.
    Kind of a wisp wisp wisp sound, with tempo directly proportional to speed.
    Didn't really sound like a bearing or worn out brake pad to me (which I've heard before).
    Not a squeal or screech, or hum or rumble, just a muted wispy sound, only vaguely metallic sounding.
    And here's the thing:
    First thing in the morning it would be there, loud enough to hear while driving at highway speed with the window down.
    Later in the day, start up and drive, and...no noise.
    I'm driving only local lately, and was gonna wait until I gotta get my state inspection done next month.
    But my wife wants to visit some relatives this weekend. :mad:
    Okay, started doing a little research, and, among others, found this thread.
    And the following post:
    Yeah, okay, I guess it's time to get under the truck and actually look. :p
    Well, the dust shields (or whatever they're called) are pretty rusty.
    The one on the driver's side was rusty enough to be buckled and ragged on the bottom.
    I reach up and pieces come off. :eek:
    Anyway, that was the cause of the noise alright. A rusty shield intermittently contacting the rotor.
    I bent the shield away from the rotor. Noise gone.
    Question:
    Should I bother replacing those shields?
    GQ7227 likes this.
  11. Aug 13, 2019 at 4:07 PM
    eon_blue
    Azusa, CA
    If they're rusty and breaking apart or bending themselves into your rotors then yeah you should replace them. Otherwise I wouldn't worry about it.
    I bent mine back when I was doing my tie rods last week and forgot to bend them back into place, driving to work the next day was interesting to say the least. Thought my wheel bearings were taking a dump it was grinding so bad lol
    beaverdamland and Gritto[QUOTED] like this.
  12. Aug 13, 2019 at 4:14 PM
    Gritto
    Yeah, I will have them replaced.
    I'm just curious how important it is and what might happen if the rotors are partially exposed.
    Thanks for the reply. :thumbsup:
    eon_blue[QUOTED] likes this.
  13. Aug 13, 2019 at 9:57 PM
    Parkvisitor
    Parkvisitor Do you know midnight?
    Juan
    So Cal
    It’s a truck
    stuff
    It's a dust shield, all it does is keeps or tries to keep brake dust off your wheels.
  14. Mar 12, 2025 at 6:23 AM
    Blakeus Maximus
    Southwest
    2000 TACOMA TRD 4X4
    Update on an old thread. Rear end needs to be gone through and rebuilt. Almost 255k on it. Fluid is clean. Not too bummed out, Im redoing everything under the truck anyways, it'll give me a piece of mind knowing the rear diff is good to go.
  15. Mar 12, 2025 at 1:29 PM
    beaverdamland
    beaverdamland Well-Known Member
    97 Xtracab MT 3.4
    OP- did you pin down the noise? Dust shields? This sounds odd, but have you checked your front differential fluid as well- esp if you have a.d.d/CVs… I had a pinion seal leak and unfortunately found out by hearing my front diff grinding.
  16. Mar 12, 2025 at 1:39 PM
    Blakeus Maximus
    Southwest
    2000 TACOMA TRD 4X4
    Sounds like its the Carrier bearing. The sound was definitely coming form the rear of the truck while driving. I had the truck at my friends shop yesterday and we isolated the noise to the rear diff. He has a gear specialist he uses and he is going over there soon to verify it, but 98% sure thats the issue. We went through the entire truck, not just for that noise, but for restoration purposes. My Tacoma has been parked and rarely driven for 3 years. Im bringing it back to where it needs to be, plus some. Front diff passed with flying colors.
    beaverdamland likes this.
  17. Mar 12, 2025 at 2:47 PM
    Blakeus Maximus
    Southwest
    2000 TACOMA TRD 4X4
    @Clearwater Bill, your talking about the Center Bearing that supports the driveshaft. The Carrier Bearing is related to the rear diff. I think those are often confused with one another.
  18. Mar 12, 2025 at 3:24 PM
    Clearwater Bill
    Billy
    Largo Florida
    Realized immediately after I posted, which was why I deleted the post. You're too quick. :D
