Hey there
Discussion in '2nd Gen. Tacomas (2005-2015)' started by toniodiaz, Nov 8, 2013.
  1. Nov 8, 2013 at 6:50 AM
    toniodiaz
    toniodiaz [OP] Crazy and lovely member
    Maruko
    Southmerica
    2011 SR5 TRD Sport Silver Double Cab and now 2013 SR5 TRD Sport Red Double Cab
    TRD Supercharger, TRD Catback, aFe Cold air intake system, HELLA Rallye 4000 Celis lamps, Spyder Smoke CCFL Halo projector Headlights, JBA Ceramic Coated Long Tube Headers, Centric Cross Drilled Front Brake Rotors, URD smaller diameter S/C pulley, Roof Rack, Recon Tail light bar, 3" OME Leaf pack at the rear with 5100 Bilsteins and Regulable 2.75" Toytec Red Springs with 5100 Bilsteins in the front, Total Chaos UCA, Front TRD Skid Plate, Black Tube Step Bar, Black Emblems and TRD Sport Stripes decal, I JUST FINISHED MY MOD TO THE PARKING, DTR AND TURNING LIGHTS, When you hit the turning switch, DTR ad Parking lights turn of on the side the Turn signals are flashing, so they don't disturb their intensity. Everything installed with my own little hands and help of my dear friend and of course, your mods.
    Hi folks,
    I just got my Ultimate Lift Kit for my 2006 Tacoma from TRDparts4u.com
    It comes with:
    - ToyTec/Bilstein Adjustable Red coilovers featuring Bilstein 5100 maintenance free shocks, adjustable from 1 to 3" lift.
    - Sway bar relocates.
    - Front Diff drop kit.
    - CS047R Complete OME Dakar springs.
    - Bilstein 5160 Remote reservoir rear shocks.
    - Rear axle degree shims for proper pinion angle alignment
    - (4) New rear Leaf u-bolts
    I'll post some pics later today.
    Now my problem is that the kit came with no instructions and I don't know how to install the axle shims and the leaf springs. My springs came with both bushings installed, which part goes in front? and about the shim, how it is supposed to be installed?
    Please help me, I'm stuck with it.
  2. Nov 8, 2013 at 7:00 AM
    Large
    Large Red
    You won't need the shims unless you have some vibes, it's a hit or miss unfortunately but the shim gtes installed with the small side facing forward and the wedge part facing towards the rear. On the dakars, there is markings on the top side of the leafs.
  3. Nov 8, 2013 at 7:38 AM
    toniodiaz
    Maruko
    Southmerica
    Thank you, my leafs came with an arrow and a sign painted at one of the ends (the end with the Toyota bushings), one leaf with a + sign and the other with a -.
    I think that that end goes to the front of the truck, am I right?
  4. Nov 8, 2013 at 7:47 AM
    Large
    Large Red
    Been a while since I've done my dakars but the plus sign is the driver's side pack, the minus is the passenger. The preinstalled bushings from OME should face the front of the truck (frame mounted), the bushings that needed to be installed in the pack should face the rear (shackle mount).
  5. Nov 8, 2013 at 7:53 AM
    toniodiaz
    Maruko
    Southmerica
    Great, and about the shim, of course I need to install it first on the leaf and by removing the center bolt, is that right?
  6. Nov 8, 2013 at 7:59 AM
    Large
    Large Red
    There should be a groove in the shim that faces up towards the bed, if the center pin for the dakars protrudes from the bottom, it should lay in the groove but the shim itself lays on top of the axle but below the leaf pack.
    Unfortunately I have never installed shims so I'm not sure if the center pin goes through it or not, I don't think it does though since the ubolts will hold it in place.
  7. Nov 8, 2013 at 8:02 AM
    Large
    Large Red
    Here is another pic
  8. Nov 8, 2013 at 8:07 AM
    toniodiaz
    Maruko
    Southmerica
    But the hole in the shim is smaller than the bolts head
  9. Nov 8, 2013 at 8:13 AM
    Large
    Large Red
    What brand shims are they? Have any pics?
  10. Nov 8, 2013 at 8:15 AM
    TacoFMS
    TacoFMS Bubble bubble bubble pop
    Justin
    Louisa County, VA
    Just a vehicle to take trash to the dump
    One or two things modded... Check out the build thread
    You have a choice there, you can either take a drill bit to the hole in the shim to make it to where the center pin head will fit in it or you can clamp your springs together, remove the center pin, then run your center pin through the wedge as well as the leafs and tighten everything back down. either will work.
  11. Nov 8, 2013 at 8:16 AM
    Large
    Large Red
    I was just about to say this, if you don't want to drill in to the shim, buy new center pins from Toytec that will work with the shims, or buy new shims that will work with the dakar center pins.
  12. Nov 8, 2013 at 8:34 AM
    toniodiaz
    Maruko
    Southmerica
    I just installed the shim in the passengers leaf, now I'll reinstall the leaf and tell you how it's goin'
  13. Nov 8, 2013 at 9:03 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Whatever you do make sure there is enough of the head of the centre pin exposed to properly seat in the axle
  14. Nov 8, 2013 at 9:12 AM
    Hennessy
    Hennessy Well-Known Member
    Charlotte NC
    13 Red DC TRD Sport
    Demello Baja bumper, Mcneil Fiberglass, Fabtech Uniball Upper Control Arms, Emu Dakar leaf springs, Fox 2.5 Factory Series Coil-over IFP, Fox 2.0 Performance Series IFP
    I used a Steel spacer to make the head of the pin longer and bolted it all back together, also i had to drill out the shim to get it to fit cleanly.
    My springs came with a + and a 0 the + is rated with more arch the 0 is in the middle and the - is lower arch,
    the + on the drivers side will help in the taco lean
