HFT 80 Watt Iron Plastic Welding Kit
Discussion in 'Product Reviews' started by Sandman614, May 29, 2013.
  1. May 29, 2013 at 8:50 PM
    Sandman614
    Sandman614 [OP] Ex-Snarky TWSS elf, Travis #hotsavannahdotcom
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    This tool is a waste of time and money. I will be returning this.
    First off this iron heated up quickly, melted any of the plastics that I used. That's where the pros stop.
    While I was using the Iron I noticed smoke coming out of the base of the tip. Shortly after that the brass tip started to flex. I thought I was just putting too much pressure on it. After a few minutes the tip just melted off under it's own weight.
    I thought that a component inside burned out so I took it apart. What I found was one 1/4 watt resistor and an LED on a 110v line.... You can see the silk screening has spaces for other components. I wonder if there is another version of this iron that has these components and is worth a crap.
    reference:
  2. Jun 4, 2013 at 7:45 PM
    Chris24
    Chris24 Well-Known Member
    Greensboro, NC
    09 Black DCSB TRD Sport, V6, 6sp
    Yikes...I stay away from harbor freight for the most part bc of things like this, lol.
  3. Jun 4, 2013 at 9:11 PM
    Dcpsychobilly
    Dcpsychobilly Well-Known Member
    Aurora Colorado
    04 dbl cab Taco
    Bumpers, skids, lights and more lights, trail gear bumper, sliders, front kings, dakar lift leaf springs rear, corbeau seats
    I literally used this about a week ago. It got the job done repairing a pretty mest bumper. I went through the first one in one day, the tip pretty much fell out and was useless. I got another to finish the job (replaced with receipt). This one (still have it) is still in one piece but the tip is loose so it'll probably not work after the next job. Tip quality is crap but what can you expect if it's cheap? And from hf
