Hi from Orlando
Discussion in 'New Members' started by 8th sin, Dec 7, 2008.
  1. Dec 7, 2008 at 11:52 AM
    8th sin
    8th sin [OP] Swollen Member
    Tampa, FL
    2015 DCLB 4x4 Sport
    Llumar CTX Tint, Grillcraft MX Upper, Pro Comp Rockwell 5034 17x8.5, Nitto Terra Grappler G2 LT285/70/17, Icon Stage III
    Greetings fellow tacos! My name is Brian, and I'm a 25 year old financial analyst from Orlando, Fl. Last week my 1994 Mazda B2300 beater finally died with 219K miles, so I bit the bullet and bought an '06 Prerunner SR5 doublecab. My roomate has a 4runner and I've always though the tacoma was great looking truck and thanks to top gear I know they're tough as nails. It has just over 35,000 miles and is still under factory warranty. That being said, I've noticed a couple things that I think I want to have the dealer look at before I go over 36,000:
    1. I've noticed all exterior painted plastic parts (overfenders and front bumper) have rediculous orange peel. To the point of not even being glossy. I saw the TSB about it, but is this really an issue I can walk in to the dealership and have them cover? It's obvious there's a asthetic problem, but I've always owned Mazdas in the past and their service centers would laugh at covering something like that under warranty.
    2. This is my first automatic transmission vehicle (of course, I've driven tons of other AT's), but I've noticed what seems to be a few oddities in the way the truck shifts. Upshifting from first from a stop happens extremely early (within 5 mph). There is also what feels like a thunk(?) when the truck first starts to move. I've had other cars that did some sort of ABS check at about 7mph, but this seems different as it occurs every time I move from a stop and before my foot is completely off the brake pedal. Also, I noticed that at light acceleration on an upwards incline, the transmission will hunt for a gear briefly. These issues are all very minor and my only concern is that these issues will effect the long-term life of the transmission.
    3. I plan to do some towing with the truck as well, and I do not have the factory tow package. I will be towing two jetskis and occasionally a small boat, a car, or similar load. I've read the towing guide on here (which was awesome!) and am also aware of the rear suspension TSB. I do not know if this has been performed, but judging by the condition of the truck, it has never been used for hauling any heavy loads. Is there a way I can check for this, or are there some magic words I can use at the dealer to encourage them to perform it? I've got less 1000 miles left of the warranty, and I doubt I'll have time to haul a load and see if I experience the symptoms.
    Other than that I absolutely love this truck! I can't keep myself from modifying cars, so I'm getting some ideas of what I can do with the tacoma. I've already ordered some parts to upgrade the audio system, and I plan to eventually fab a panel to mount a large touchscreen in the dash to use with a car pc setup. I will document this to the best of my ability to help out the rest of the community. Looking forward to talking with some of you!
  2. Dec 7, 2008 at 12:44 PM
    oldtacomaguy
    oldtacomaguy four forty four
    Dave
    SE Conn.
    08 SR-5 4WD Impulse Red Pearl
    Alpine deck and amp, Polk speakers front and rear, Kenwood subwoofer, windows tinted to 20%, Sockmonkey decals, TSB, Eibach springs and Bilstein 5100's
    Hi, welcome to TW. As far as the suspension TSB goes, check the rear leaf springs. If there are 3 leafs, the TSB has not been done. They install new leaf spring assemblies that are 4 leafs. If the truck is not a TRD, they will also install 4 new bilstein shocks. There is a thread on here describing how to go about getting it approved. Since you're at 35000 miles, you should look into it asap. Sometimes the dealer will try to stall for a bit. It's definately worth having it done, the truck will ride nicer and handle better. As far as the tranny goes, I can;t give you any advice, but there are some members here who are very good with those things. Good luck.
  3. Dec 7, 2008 at 12:46 PM
    duckcmdr
    duckcmdr If it flies it dies!!
    Joe
    New Jersey
    06 DCLB 4x4
    ARB Winch Bumper, Cabelas trial gear 2 mats, Wade vent shades, rear TSB, Toytec TSB AAL ,5100's set to 0,886 coils w/top plate 285/75/16 Treadwright at on Raceline Raptors, Toytec Diff drop, Bud Built Skids,Total Chaos LCA Skids,Devil horns,LED Dome Light,Scan Gauge, Rear Diff Breather, Revenge Fab Sliders. XRC 8 winch, Safari Snorkel, KC Daylighters 100 watt, Redline hood Struts & ez-down tailgate, G-stop extended SS brake lines,Homeroshi front grill and snorkle grill, relentless fab hc rear bumper
    Welcome!
  4. Dec 7, 2008 at 12:47 PM
    duckcmdr
    Joe
    New Jersey
    06 DCLB 4x4
    This site support your addiction :D:D
  5. Dec 7, 2008 at 12:50 PM
    silver07taco
    silver07taco Well-Known Member
    COIL
    Maryland
    13 Tundra RCSB 5.7 4x4,07 Tacoma AC 4.0 4x4
    2013 Tundra RCSB 5.7 4x4, 2007 Tacoma AC 4.0 4x4
    Welcome to TW!
  6. Dec 7, 2008 at 12:59 PM
    longbow
    longbow I see you now..................
    Bill
    Indiana
    05 Tacoma Silver Mica TRD 4 Door
    Toy-tec Coil over lift, Eibach 700 lb springs, Sway bar relocate, Total Chaos UCA's, Moto metal wheels, BFG mudterrians, HID, custom 3 piece grill, Highlift jack w/custom mount, Highlift jack cover, bed matt, de-badged 100%, storage box lock mod, using defrost w/o AC mod, short antenna mod, horn re-locate, Tire Gate flat spare tire mount, engine cover painted, bed light (1) mod, wreck bar carrier, Blue Sea 5026 fuse block, center console outlet, flash light mod, Blue Sea inline fuse, Shrockworks sliders, All-Pro front bumper, Piaa 510 driving lights, Warn shackles front, Kennesaw rear bumper, "Tag Boltz" plate lights, Warn shackles rear, Warn M8000 winch, devil horns, BHLM, weathech liners front and rear.....T.W. sticker of course. Custom Sock bed decal for Michele
    Welcome to TW
  7. Dec 7, 2008 at 1:25 PM
    8th sin
    Tampa, FL
    2015 DCLB 4x4 Sport
    Thanks for the swift replies! Looks like it's 3 leaves for me. I found some good threads on convincing the dealer to do it without hassle, so I'll call a dealer this week.
  8. Dec 7, 2008 at 3:33 PM
    Ridingontrd
    Ridingontrd Well-Known Member
    Richard
    Laughlin,N.V
    trd sport 4x4 w/towpkg
    aFe prodry,Dynomax ultra flo ss,Scangauge2,Demello front bumper,BudBuilt skids,sliders(local)AllPro rear bumper,Wet O's cobalt blu,w/halfpiping,TRD logo in gold,R/L hood struts,5150's@10"aal 3 pack,T/C uca,Light racing c/o,1"diff.drop,de-badged,
    Lots of great info here.Welcome to TW.:)
  9. Dec 7, 2008 at 3:40 PM
    SocalMan22
    SocalMan22 Well-Known Member
    Steve-0
    So*Cal
    06 PreRunner Dbl Cab
    What Mods!
    Welcome to TW!
  10. Dec 7, 2008 at 4:36 PM
    gator16
    gator16 Member
    Mount Dora, FL
    Silver 06 Prerunner SR5 4 door
    I had the rear TSB done on mine a while back at David Maus in Sanford. They did it wrong the first, long story there, but after a week convincing them that it was wrong they fixed it right up. They were very sorry for messing it up though.
  11. Dec 7, 2008 at 4:39 PM
    8th sin
    Tampa, FL
    2015 DCLB 4x4 Sport
    That's a bit of a hike for me, but I'll give them a call. I've only got 785 miles left before I'm out of warranty lol. Thanks for the heads up!
  12. Dec 7, 2008 at 4:42 PM
    gator16
    gator16 Member
    Mount Dora, FL
    I actually had to go to Toyota of Orlando to ask them if it was done wrong and they said yes it was. They were going to fix it right for me, but Maus finally came through for me. So maybe Toy of Orlando can help ya.
