Hi I am looking for some help on camping trailers I have the Tacoma with the V6 engine.
Discussion in 'Towing' started by Seasider, Aug 19, 2020.
  1. Aug 19, 2020 at 5:28 PM
    Seasider
    Seasider [OP] New Member
    Martin
    20018 Tacoma
    3,.5 l V6 Atkinson cycle 6 speed automatic
    Anybody got recommendations for weight and maximum length of trailers they have purchased. I live near the grapevine so it’s a big pull up that hill. Any help on brands of trailers will be gratefully received. I was hoping a 22 foot trailer
  2. Aug 19, 2020 at 5:33 PM
    Clearwater Bill
    Billy
    Largo Florida
    Does your truck include the tow package?
    Are you experienced in towing, especially stuff bigger than your tow vehicle?
    Start with the owners manual re tow and tongue weights. And know folks are usually more comfortable staying under that.
  3. Aug 19, 2020 at 5:38 PM
    Seasider
    Martin
    20018 Tacoma
    Hi. Truck has got the tow package. I have Not pulled a trailer for a long time. Looks like I need an additional braking system regulater. I have read the Manual for weight distribution etc. I was looking for actual Yes I have a. Xx. Camper it weighs xxx.and it’s comfortable pulling up large hills.
  4. Aug 19, 2020 at 5:42 PM
    Clearwater Bill
    Billy
    Largo Florida
    Hang on. Some folks will be along to get into more specifics you want.
    All you said was you had a v6, and someone else would have asked anyway. I was just getting the preliminaries out on the table.
    2002Tacoma4x4 likes this.
  5. Aug 19, 2020 at 5:45 PM
    mac84
    mac84 Well-Known Member
    Alabama
    2015 Tacoma TRD Sport 4WD MGM
    Check out the Towing Bible under the Towing section on the forum. It’s got very specific info and very helpful
    Seasider[OP] likes this.
  6. Aug 19, 2020 at 5:47 PM
    EricL
    EricL Tomahawk Chopper
    Greenwood, SC
    2015 Slowmobile
    SOS Offroad Concepts Armor
    You have a Toyota Tacoma. You don't need a camper. Rocks will form themselves out of respect in a protective barrier for you and your family in the place where you decide to camp.
    I mean, they might...
  7. Aug 19, 2020 at 6:03 PM
    Seasider
    Martin
    20018 Tacoma
    Tacoma Sr5 2018 Double cab 3.5 l V6 Atkinson cycle engine. 6 speed automatic Towing receiver hitch . Engine oil cooler . Pin connector and trailer sway controller. Gvwr 5,600 lbs From the door spec sticker.
  8. Aug 19, 2020 at 6:15 PM
    Skidog1
    Skidog1 Well-Known Member
    Chicagoland
    2016 Black TRD 4x4 Sport DCLB
    Search Youtube for "2016 Toyota Tacoma takes on the extreme Ike Gauntlet towing review". It is very much like the grapevine in steepness.
    Seasider[OP] and TacoManOne like this.
  9. Aug 19, 2020 at 7:25 PM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    The total weight is the main determining factor. It’s not how heavy max you can tow, its what you and the truck are comfortable with. The towing and driving experience Is quite different between say 3500 lbs and 5500 lbs. The heavier the more stress on the driver and the truck. What ever dry weight trailer you get add 1000 to 1500lbs to it for water, propane tanks and all the other stuff you’ll carry in the trailer. I can tell you pulling 5000+ lbs over the Grapevine is a struggle for your truck and for you. I suggest you rent a trailer and pull it around on vacation for a week and whatever the weight you’ll get an idea for the max weight you want to tow.
    RolfeMobile and Seasider[OP] like this.
  10. Aug 20, 2020 at 4:56 AM
    Jimiller5
    Jimiller5 Well-Known Member
    Jim
    East TN
    '15 TRD Sport
    Tonneau cover running boards Lance 1475
    I pull a Lance 1475. 3200 lbs dry, 19’, 13 mpg. The Taco does fine but I wish it had a bigger gas tank.
    RolfeMobile, lynyrd3 and Seasider[OP] like this.
  11. Aug 20, 2020 at 8:10 AM
    gnewman545
    gnewman545 Well-Known Member
    Gary
    2013 Red DCLB
    BWG Winch Plate Teck Deck K&N Vent Filter
    I have the DCLB with tow package. I tow a Palomino Solaire 147x. It weighs 3200 lbs dry, 3800 lbs fully loaded. It's about 19' long. I try to never tow it anywhere with a load in the freshwater, grey water, or black water tanks. The extra weight of water adds up quickly.
    I use a weight distribution hitch and a clip-on towing mirror. I find the weight distribution hitch definitely helps with stability. It rides much better with it on. The clip-on mirror is a big help when changing lanes on the highway or backing up into a campsite.
    It was a bit of a learning curve for me. Especially backing up. I just took my time, took it slow, and made nice wide turns everywhere I went. There are times, going up hills, that I choose not to keep up with traffic. I know the truck is capable because I've done it, but I have to pin the accelerator. For wear and tear purposes, I choose not to do that. Also, expect your truck to burn a lot more gas. I think someone above mentioned that.
    Even though my truck is rated to tow 6400 lbs, I'm not sure I would want to tow something much bigger than my current trailer with my current truck. It's not just tow capacity but payload capacity that you have to consider. With my modest sized trailer, I think I'm close to the payload capacity of my truck even though I'm nowhere near my tow capacity.
    Consider my comments and those of Sprig, and you have some strong guidance.
    2002Tacoma4x4 and Seasider[OP] like this.
  12. Aug 20, 2020 at 8:12 AM
    NV_Spencer
    NV_Spencer Well-Known Member
    2020 CREWMAX / 2017 OR DCSB
    You're coming at this all wrong. Buying a travel trailer should not just picking the largest size your truck can handle. You need to visit local dealers to see them in person to decide what you'll be using it for, how many beds you need if you have kids, is wet bath vs dry important to you, rear bed or front bed, etc. Find a brand/floorplan you like and then you can determine which model or size trailer from there.
    If you're just going to read the door sticker....sure, go buy a 5500# trailer and let us know how that works out for you
    gnewman545 likes this.
  13. Aug 21, 2020 at 11:51 AM
    openspace4x4
    openspace4x4 Well-Known Member
    SF Bay Area
    2017 TRD OR DCSB
    OV Tune
    I have a Keystone Hideout that is 3,600 pounds dry. I have towed it with a full water tank and a loaded Yeti in the bed. 3,600 pounds is a weight I think you would be ok with going over the Grapevine.
    Get an anti-sway weight distribution hitch and a Tekonsha P3 beaker controller and you will be good to go.
  14. Aug 21, 2020 at 2:46 PM
    Aquatic Tacoma
    Aquatic Tacoma Well-Known Member
    Odessa, Fl.
    2019 Tacoma TRD Sport 4x4 Dbcb , 2004 Tacoma S-Runner
    Both are Stock - built correct from the start.
    Most experts recommend a dry trailer weight no more than half of tow vehicle capacity. This allows for loading of both trailer and tow vehicle and a safety factor. This puts most Tacoma’s trailers staying below 3200-3500 lbs. I’ve trailered a 3300 lb travel trailer thousands of miles through out the se US. I wouldn’t go any bigger.
    Before taking anybodies advice and buying, rent. Set you truck up for towing. Springs or airlifts and a brake controller. Then get online, RVShare.com or Outdoorsey.com. Rent one or more. Try different ones out. You’ll learn a lot before making a financial loss division. Purchasing a travel trailer is always a terrible financial decision. Try to get it right the first time.
  15. Aug 25, 2020 at 12:38 AM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    U might be lookin for permission
    ive been on grapevine 1 of the longest pulls west coast
    there are many a vehicle has issues on grapevine
    U wont be the first
    the combo U end up with wont be like anyone else
    depends on what shape U taco is in they dont all run the same year to year
    borrow from a friend or rent a similar trailer make it a day
    then U will know
  16. Aug 25, 2020 at 4:02 AM
    EchoDeltaSierra
    EchoDeltaSierra Well-Known Member
    Georgetown, TX
    2020 TRD Off-Road
    Nitro 4.88 gears OME suspension ST/Maxx 255/85R16s
    Take a look at my thread here. I've Tacoed for many years and we have been trailer shopping for about three. I've pulled lots of different trailers with lots of difference vehicles over the course of my life. Most people want to focus on tow limit when GCWR is the number that should be the focus.
    Finally decided on a travel trailer: 2021 R-Pod 192
  17. Aug 25, 2020 at 4:36 AM
    lynyrd3
    Bill
    East Central Upstate NY
  18. Dec 20, 2020 at 12:07 AM
    bigsky911
    bigsky911 New Member
    bob
    2018 taco mt6
    Fab Four bumper
    I have towed many different trailer with this truck all different sizes I would not go bigger than 21 feet plus I tow with a manual if urs is a auto I would stick to a 19 foot or u will be sorry
  19. Dec 20, 2020 at 11:34 PM
    BCfishTaco
    BCfishTaco Well-Known Member
    Beautiful BC Canada
    2019 DBL TRD Sport Silver
    2015 Dbl TRD Sport - 20' Jayco 4200lbs dry, airbags, WD hitch, brake controller. Towed fine just not fast. First year we drove from Vancouver BC to Drumheller, AB over the Rockies. Our average trip is 1500-2000 miles
    Traded in >
    2019 Dbl TRD Sport - same setup but no airbags but will be installing helper springs. Tows the rig easier than the 15. My only gripe is the tank size. I have all the gas stations mapped out before hand. Both trucks have upgraded trans cooler Hayden 678
  20. Dec 24, 2020 at 7:48 AM
    Toyanvil
    Toyanvil Well-Known Member
    I have a 178 R Pod 3200 lbs. ready to camp and live in Bakersfield, my Tacoma pulls it great over the grapevine and up to Huntington Lake. The R Pods are not wide so your stock mirrors work, just add a bigger trans cooler. The Tacoma's don't like wind, pulling my 3200 lbs. R Pod it feels good at 55 to 60 mph @ 10 mpg, pulling my 3300 lbs. car trailer it feels good up to 65 to 70 mph @ 14 mpg.
    openspace4x4 and strider98 like this.
