hi-lift jack differences
Discussion in 'Technical Chat' started by tacomaman06, Jan 31, 2009.
  1. Jan 31, 2009 at 6:47 PM
    tacomaman06
    tacomaman06 [OP] Carolina Alliance: Enforcer
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    looking at hi-lifts on ebay..............they have the cast/steel, all cast and extreme.
    what makes the all cast better than the cast/steel one(if anything)? the extreme is way overkill for me i do believe!:D
  2. Jan 31, 2009 at 6:55 PM
    LonghornTaco
    LonghornTaco Can you pass the bailout please?
    Minnesota
    Black 09 4x4 TRD Off Road Doublecab
    3" ToyTec coilover lift on Bilstein 5100s, Total Chaos UCAs, ToyTec diff drop, Scangauge II, 4D MagLite mounted on the drivers seat, Painted engine cover, Painted calipers (red), Painted skid plate (red) Valentine 1 radar detector hard wired, Damplifier Pro on the floor, back wall and doors, Luxury Liner Pro on the floor and doors, Kenwood DNX8120, 2 Pioneer TS-SW1041D 10" shallow mount subs, 2 Pioneer PRS-D4200F 1200W amps, Mr Marv sub enclosure, Hybrid Audio Clarus 6.5" components in the front doors, Alpine 5.25" coaxials in the rear doors, A.R.E. LSII fiberglass tonneau cover, All Pro bumper, All Pro sliders, Wet Okole seat covers, Sockmonkey Mountain badges, PIAA 510 SMR Driving Lights, Warn M8000 Winch, Bud Built skids
    :popcorn:
    I have the same question...
  3. Jan 31, 2009 at 6:59 PM
    40204ever
    40204ever Well-Known Member
    Caldwell, TX
    4x4 taco racing development
    Cast is heavier built. The steel/fabricated "Head" does not hold up well to abuse "work".
  4. Jan 31, 2009 at 7:02 PM
    sooner07
    sooner07 1/2 man 1/2 amazing
    A A Ron
    DFW, Texas
    Debadged 2008 Rugged Trail
    Always working on the stereo, painted the front skid plate black to match the truck, debadged , toy tech ultimate lift kit, light racing UCAs, ARB bumper Looking into a supercharger and new exhaust.
    cast/steel has some stamped steel pieces, the all cast is just that. They should both have similar capacities but the all cast is slightly more durable.
  5. Jan 31, 2009 at 7:05 PM
    40204ever
    Caldwell, TX
    I just know from using hilift jacks since I could run a tractor. I don't know particular specs. I have never broken a cast hilift. I have trashed the fabricated/steel one. They all need oil or wd-40 slobbered on them to work properly and they never work right when you bend one. That is a bad day.
  6. Jan 31, 2009 at 7:06 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    That's what I need to buy is a hi-lift jack! Let me know what you go with tacomaman06. ;)
  7. Jan 31, 2009 at 7:06 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    cool....thanks for the responses. i think im gonna get an all cast hi-lift then, and the o.r.b. to go with it.
  8. Jan 31, 2009 at 7:13 PM
    40204ever
    Caldwell, TX
    When you get it, buy some clevises that fit in the holes. It is alot easier to attach a chain or strap when you need it.
  9. Jan 31, 2009 at 7:15 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    yeah, i got 4 or 5 small clevises in my tool box right now, so they will work well with the hi-lift.
  10. Jan 31, 2009 at 7:18 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Okay someone needs to school me on hi-lift jacks! I have no clue how they work?:confused: What kind do I need for my truck?
  11. Jan 31, 2009 at 7:20 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    well.....you need either sliders or a plate bumper(s) before you can use the hi-lift.............well, you can use the hitch, but that may not be too safe.
  12. Jan 31, 2009 at 7:25 PM
    40204ever
    Caldwell, TX
    what ever you jack up must be stable. If it moves you are dead or screwed.
  13. Jan 31, 2009 at 7:30 PM
    40204ever
    Caldwell, TX
    uses of a hi lift jack:
    Winch
    jack -duh
    fence stretcher
    calf puller - very desperate situation
    Large clamp - hold boards together
    load a sea container - requires two
    hold a hay rake folded together for transport.
    pull out large posts
  14. Jan 31, 2009 at 7:33 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Oh so I would use it on my nerf bars to lift the truck?:confused:
  15. Jan 31, 2009 at 7:54 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    nah.....wont work too good man....they'd bend all to hell from the weight of the truck.
  16. Jan 31, 2009 at 7:56 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Okay so bottom line.:eek: What would I need to do to make the hi-lift jack work on my truck?:confused:
  17. Jan 31, 2009 at 7:58 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    probably the cheaper solution......buy and weld or bolt on a set of rock sliders. they are cheaper than a plate bumper anyway.
  18. Jan 31, 2009 at 8:01 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Okay. Dang, now I really feel stupid. What are rock sliders?!?!
  19. Jan 31, 2009 at 8:04 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    they weld or bolt to the frame to keep damage to the rockers to a minimum when offroading..............here is a link.....
    http://www.revenge-fab.com/sliders.html
    these are the sliders im getting.
  20. Jan 31, 2009 at 8:06 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Oh okay! So they are like nerf bars!?!?
