HI LIFT jacks
Discussion in 'Off-Roading & Trails' started by 05tacoSPORT, Jun 19, 2010.
  1. Dec 18, 2015 at 11:04 AM
    #41
    C0d3M0nk3y
    C0d3M0nk3y Well-Known Member
    2008 Tacoma Sport DCSB (silver)
    I am driving a 2008 DCSB. I had to pull off the foot, but that mounts below the Hi-Lift (not in any of the pictures, but you can see one of the mounting bolts). I use a 48" Hi-Lift. The real trick isn't the length (for me) but the depth. The wood helps act as a stop so that the lifting mechanism doesn't rub against the rear of the truck.
    I did pull out the plastic organizer behind the seat to get it to fit.
  2. Dec 18, 2015 at 8:02 PM
    #42
    Wolftaco0503
    Wolftaco0503 Well-Known Member
    Adam
    Chicago
    2013 Super White LONG BED TRD SPORT 4x4
    Maglite mod Bottle Opener in bed Weathertech Mats Front & Back
    Does anyone have a write up of mounting it in your bed?
  3. Dec 18, 2015 at 8:03 PM
    #43
    Skootter14
    Skootter14 Upon my signal, unleash Hell
    Jeremy
    '11 TRD Sport 4D LB 4x4 Metallic Grey
    "a lot of stupid stuff" -Wife
    see my sig
  4. Dec 21, 2015 at 10:53 AM
    #44
    Srice57
    Srice57 Well-Known Member
    Steven
    Dacula, GA
    2013 TRD Off-Road MT
    Nope, 48".
  5. Dec 21, 2015 at 10:57 AM
    #45
    PaulK
    PaulK Life is hard. It's harder if you're stupid.
    Paul
    Pittsburgh, PA
    2013 Black Baja Access Cab
  6. Jan 4, 2016 at 8:39 PM
    #46
    TommyG
    TommyG Around
    Grouch
    MELTING POT
    21 MAX
    No mods
  7. Mar 2, 2016 at 11:36 AM
    #47
    4WDTrout
    4WDTrout Perpetually dreaming of tall trees & rivers
    Theo
    08 4WD SR5 DCSB
    Total Tacoma nOOb.
  8. Feb 5, 2018 at 5:32 PM
    #48
    andrewtheadventurer
    andrewtheadventurer Well-Known Member
    Andrew
    Somewhere probably
    Off-road Tenthouse
    an empty wallet
    What toolbox do you have? I have been looking for one to fit between and below the wheel wells.
  9. Feb 8, 2018 at 7:06 AM
    #49
    #1pumper
    #1pumper Member
    2010 Crew Long Box DRK GR
    Me too! Weathergard has some but they say only a couple fit with wheel wells and stuff. I want a good size one, because I carry a small shop in my pickup. Never know what or when you need something farming
  10. Feb 8, 2018 at 7:13 AM
    #50
    andrewtheadventurer
    Andrew
    Somewhere probably
    Off-road Tenthouse
    an empty wallet
    It is a true struggle. I am very suprised these dimensions aren't common.
    Here is the closest i have found but it sits 1" above the wheel wells.
    https://www.amazon.com/International-TB-20D-31-Inch-Utility-Box/dp/B00DJQI2K2
  11. Feb 8, 2018 at 7:19 AM
    #51
    #1pumper
    #1pumper Member
    Thanks I ll look into it
  12. Apr 17, 2023 at 2:23 PM
    #52
    YE2KA
    YE2KA Well-Known Member
    JB
    19 Cement Grey Tacoma Offroad
    This is the exact spot I want to mount mine at
  13. Apr 28, 2023 at 1:52 PM
    #53
    Theforbiddentaco21
    Theforbiddentaco21 New Member
    Or you can use the hi lift wheel attachment
