Hiatt1991's Build. (never done)
Discussion in '2nd Gen. Builds (2005-2015)' started by Hiatt1991, May 20, 2011.
  1. Sep 25, 2014 at 3:53 PM
    #1081
    JuansTaco
    JuansTaco JuanInAMillion
    Juan
    gilbert az
    2004 PreRunner SR5 stormtrooper
    ESB long travel kit, Deaver f67s with DTF 12 inch shackles.
    Ya you should come down on Saturday!
  2. Sep 25, 2014 at 7:20 PM
    #1082
    Hiatt1991
    Hiatt1991 [OP] Well-Known Member
    Hiatt
    Ventura, CA
    2022 Toyota Tacoma SR5 DCSB 4x4
    4" Bodylift 20" Offroad shock spacers Turbo Encabulator
    I wish. Got work and then homework.
  3. Dec 10, 2014 at 2:05 PM
    #1083
    Manwithoutaplan
    ID
  4. Feb 4, 2015 at 10:04 PM
    #1084
    emilminasian
    emilminasian Well-Known Member
    Emil Minasian
    Glendale, CA
    2011 Trd sport double cab
    this might be question you might not remember the answer too lol, how was the ride quality once you did the spindles? and what break lines were or are you using on them. i installed mine today, i have belstein 5100 set at 0 with OMU springs so ithink thats like a 2 inch lift. i was told to get allpro brake lines cause i bought my spindles second hand, the allpros were extremely short so idk what to get now. and also, did your handleing change once you put these on? [​IMG]
  5. Feb 5, 2015 at 9:28 AM
    #1085
    Hiatt1991
    Hiatt
    Ventura, CA
    Howdy. Sounds like you got standard length brake lines. Try getting some lines from Camburg or total chaos. The long travel length brake lines will work best. As for the handling, it did change a bit. Make sure you check your tierod ends for play and replace them if needed. Also, you will need to get an alignment after the instal because the geometry of your suspension has changed completely. It's always a good idea to get that set after any suspension work. When I had the lift, I used stock springs set at one notch above zero (.85" I think) and it wasn't harsh riding at all. The springs you got may be a bit harsh riding even when set at zero. If so, go back to stock or try toytec springs. Hope that helped.
    SoCalTRDgirl likes this.
  6. Feb 5, 2015 at 12:06 PM
    #1086
    Manwithoutaplan
    ID
  7. Feb 5, 2015 at 12:51 PM
    #1087
    Hiatt1991
    Hiatt
    Ventura, CA
    Hey champ :wave:
  8. Feb 5, 2015 at 12:52 PM
    #1088
    JuansTaco
    Juan
    gilbert az
  9. Feb 5, 2015 at 12:54 PM
    #1089
    Hiatt1991
    Hiatt
    Ventura, CA
    Hey Juan. How are you liking your LT?
  10. Feb 5, 2015 at 12:55 PM
    #1090
    JuansTaco
    Juan
    gilbert az
    Like it. But want more. Revalving the rear to hopefully fuful my needs but if not I have a back up plan.
  11. Feb 5, 2015 at 1:00 PM
    #1091
    Hiatt1991
    Hiatt
    Ventura, CA
    Nice. Yah I keep putting off building the rear. I'll prolly have LSK do something after I get a daily.
  12. Feb 5, 2015 at 1:07 PM
    #1092
    JuansTaco
    Juan
    gilbert az
  13. Feb 5, 2015 at 1:35 PM
    #1093
    emilminasian
    Emil Minasian
    Glendale, CA
    What tie rod ends would you recommend? And brake lines ?
  14. Feb 5, 2015 at 3:46 PM
    #1094
    Hiatt1991
    Hiatt
    Ventura, CA
    Moog makes pretty nice replacements but any will do. Get your brake lines directly through camburg. Just tell them you wanted the extended ones for long travel.
  15. Feb 5, 2015 at 3:47 PM
    #1095
    Hiatt1991
    Hiatt
    Ventura, CA
    Nah. Prolly the DMZ SUA with some 16" doubles or tripples.
  16. Feb 5, 2015 at 3:56 PM
    #1096
    JuansTaco
    Juan
    gilbert az
    Ah. I want links.
  17. Feb 16, 2015 at 5:48 PM
    #1097
    just2wd
    just2wd Well-Known Member
    Dan
    California
    07 PreRunner TRD Off Road
    hiatt, where did you take the drive shaft for this? my u joints took a dump it's about time i got em replaced
  18. Jan 20, 2016 at 4:47 PM
    #1098
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    You still in Flagstaff? Saw a truck that looked suspiciously like yours last week. I just moved up here myself.
  19. May 8, 2016 at 12:02 PM
    #1099
    Hiatt1991
    Hiatt
    Ventura, CA
    Hey @snowsk8air2 Im still up here. I'll be moving sometime next year.
  20. May 8, 2016 at 12:03 PM
    #1100
    Manwithoutaplan
    ID
    :ohsnap:
    How is it going sugar tits?
