HID failure
Discussion in 'Lighting' started by supremetaco2, Jan 15, 2010.
  1. Jan 15, 2010 at 8:22 PM
    supremetaco2
    supremetaco2 [OP] Well-Known Member
    concrete jungle, oahu
    04inacoma
    +hp, lifted, lights, dif breather mod, debadged, shorty antenna...
    ok so i just got my shipment in of HID's from ddmtuning yesterday, so i went to the shop to get the 6k hi/lo beams installed and they worked perfectly fine when the car started up... DRL's came on, hi/lo worked fine. then when i went to fill up gas and turned the engine off then back on, none of the lights went on... I tried fidgiting with it and got the right side to work, but the left side didnt wanna come on.... then stopped at another store, turned off the engine, then turned it back on and now the right light went out as well.... could it be the connections? i was checking to make sure everything was plugged in correctly... and it didnt want to light up :(
  2. Jan 15, 2010 at 9:19 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    I think you need to disable the DRLs for the HIDs to work.
  3. Jan 15, 2010 at 9:32 PM
    dually
    dually Low and slow
    Interstate underpass
    '16 Inferno SR5 DCLB
    265/75R16 Falken Wildpeak AT3 LED Bulbs Access Lorado
    make sure the ballasts are humming. I got a bad ballast from DDM... have yet to get my replacement! Bastards!
  4. Jan 15, 2010 at 9:51 PM
    Toph
    Toph Addicted to V8s
    Dirty South
    90 Mustang Notch, 06 CTS-V
    one of mine from ddm has issues...first couple of times wouldn't fire up...now it fires up but flickers every now and then.
  5. Jan 15, 2010 at 9:52 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2014 DCSB TRD 4x4
    sounds like this is a common problem...Martie is having major issues dealing with them too
  6. Jan 15, 2010 at 9:55 PM
    JimBeam
    JB
    2014 DCSB TRD 4x4
  7. Jan 15, 2010 at 10:19 PM
    humanoid
    humanoid bite me
    Sunny SoCal
  8. Jan 15, 2010 at 10:49 PM
    gouge44
    gouge44 $DO WORK$
    FloRiDa
    08 prerunner TRDsport DoubleCab
    Tinted windows, toytec ultimate 3inch lift- front c/o rear aal, 18" black rockstar rims, 275/70/18 toyo opencountry mt's, BLUE dome light, 6000k H4 HID bixenon, kenwood kvt-514 headunit,black badges, satoshi grill :] sold it and now have a wrangler....
    try swapping the ballast's around. i had a problem with one of my lights not firing and switched the balasts around it it works fine now
  9. Jan 16, 2010 at 6:08 AM
    Bellis
    Bellis friggin rad
    Ben
    mass southshore
    pyrite 6-speed 2012 offroad
    driver mod
    check your grounds this happened to me once would turn on one time and not the next, they should be tight and have a clear path to the body or frame
  10. Jan 16, 2010 at 12:25 PM
    WATacoRider
    WATacoRider Well-Known Member
    TRD Sport 4x4
    buy cheap shit, expect cheap quality.
  11. Jan 16, 2010 at 1:26 PM
    supremetaco2
    04inacoma
    shit im in the shop right now, we gonna try switch the ballast and did everything in the book and i dont want to cut that wire to the DRLS... cmon people IDEAS NOW!
  12. Jan 16, 2010 at 2:57 PM
    supremetaco2
    04inacoma
    ok disregard this... ok so everything is good now.. thanks for the input.. the ballasts were both okay, switched the ballasts around and seemed to be good.. now i just have to turn on the lights before i start the engine to enable the DRLs. thanks for the input guys.
  13. Jan 17, 2010 at 2:04 PM
    supremetaco2
    04inacoma
    ok so it stopped working again, i think one ballast is bad.. so would it be okay to swap in a different ballast by a different company with the same power? or could i swap both? or would i have to change the wiring again?
  14. Jan 17, 2010 at 2:08 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    the wiring should be the same, swap out the ballasts.
  15. Jan 17, 2010 at 2:13 PM
    supremetaco2
    04inacoma
    ok cool thanks, well i just submitted a ticket to DDM but who knows how long that will take....
