HID Flicker
Discussion in 'Lighting' started by thebigsmit, Mar 16, 2013.
  1. Mar 17, 2013 at 1:59 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    It's not an issue of quality, it's an issue of TRS offering a proper retrofit, and TRS is one of the few companies that does.
    Most of the kits out there, including everything on eBay, are H4 plug-in replacements that are dangerous to other drivers. That's where the ragging on other vendors comes from. FWIW, TRS also sells the plug-in systems, and I really wish they wouldn't, but they are in business to make money, and there's a market for it, and I'm not their CEO, so they will continue to sell them, and I'll continue to drive with a rag hanging over my mirror.
    If other companies offer proper retrofits, more power to them.
    IMHO, all of the electronics are Chinese base quality production unless you get a retro that uses an OEM ballast.
  2. Mar 17, 2013 at 2:07 PM
    Ronn
    Ronn Well-Known Member
    Ron
    Northern Ontario
    2007 DCLB 4x4 SR5
    Westin bullbar, KC slimlites, Mini D2S headlight retrofit, 5100 front @ 1.75 and 5100 rear, Wheelers HD leaf pack
    This. It's what I concluded aswell and if all the wiring is spot on then the issues point to the ballast. OEM kits for some vehicles range up into thousands of dollars. Were talking about a 300 dollar kit here. Point is, it didn't come standard with the truck, it's aftermarket and we all know that aftermarket is never perfect.
  3. Mar 17, 2013 at 2:21 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    On this "candle flame" issue, I'm thinking it's the Morimoto burner.
    I'm running the upgraded Philips 4300k burner, but the same ballast as everyone else.
  4. Mar 17, 2013 at 3:16 PM
    Ronn
    Ron
    Northern Ontario
    2007 DCLB 4x4 SR5
    Could be worth a shot to see if it fixes the problem, even if it doesn't those are a little brighter aren't they?
  5. Mar 17, 2013 at 6:59 PM
    Tacomanator
    Tacomanator Boiling denim and bangin whores
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    Definitely get in touch with TRS. Have them send you new bulb's and ballasts, should be covered under their 4 year warranty.
    I have a Morimoto mini H1 setup with their XB35 bulbs and 3Five ballasts - zero problems.
    Good luck.
  6. Mar 17, 2013 at 7:29 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Ya, when I get some things ironed out and things get settled.
    Right now I've got too many damned projects going and none are getting done. It took me 3 months to get to installing the retros (the new Depo housings sat in the garage COMPLETED that long), I never have installed the power door locks that I bought almost a year ago.
  7. Mar 17, 2013 at 7:36 PM
    KenLyns
    KenLyns 8-in. Third Member
    Belly of the Beast
    4x4 TRD Off Road Full-Auto
    All-Pro Bumper, CBI Sliders, Icon Coilovers, BudBuilt Skids, aFe Intake, Icon VS Rear Shocks, Timbren Bumpstops, All-Pro UCAs, JDM Steering Wheel, ViAir Compressor, Klearz LED 3rd Brake Light, Pop-N-Lock Tailgate Handle, Husky Front Flaps
    Do you use a relay harness that draws power directly from the battery?
  8. Mar 18, 2013 at 5:20 PM
    thebigsmit
    thebigsmit [OP] Well-Known Member
    Brent
    South Carolina
    2013 Tacoma TRD Off Road
    3 inch Toytec lift, Westin E series bull bar, HID/Halo retrofit, sway bar disconnect
    Yea
  9. Mar 18, 2013 at 5:27 PM
    David K
    David K Well-Known Member
    San Marcos, Alta California
    2010 4WD Off Road DC
    Following up... understand that the lights work, and do the job... you would never know it 'candle flickered' unless you drove up to a wall or in your garage and stared at the wall to see the movement. It doesn't get darker it just 'moves' within the lighted pattern.
  10. Mar 18, 2013 at 6:25 PM
    thebigsmit
    Brent
    South Carolina
    I have another question. I also ordered halos and installed them. I was so eager to get them working I never read the directions and just kinda guessed how to wire them. Long story short, I didnt use a relay and wired them directly to my dtrl. Now, they wont turn on and Ive determined that its the little black cylinder voltage regulators that came with the halos. I assume that because I didnt use a relay (my bad). Will TRS replace the little black voltage things or can I buy them locally?
  11. Mar 18, 2013 at 7:34 PM
    noSKills858
    noSKills858 battlescars
    Alex
    Escondido, CA
    2003 5-lug Prerunner
    Couple shocks, some old tires, and a bad paint job
    Well as many who don't like DDM Tuning ballasts or any other product from them, I am a firm believer in their products for the price. I have had 0 issues with any of their products and will continue to buy parts from them.
    As far as the flicker goes, does it stop when the brights are on or is it constant?
  12. Mar 18, 2013 at 8:23 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    If you wired CCFL halos directly to the DRL, the flashing from the turn signal blew them.
  13. Mar 18, 2013 at 8:32 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Have you dealt with their customer service?
    I used DDM products in a number of vehicles, and other than one ballast, I had no quality problems that couldn't be traced to bad grounding.
    And I apologize to the other people on the road that had to deal with my splattering headlights.
    Anyways, in 2009, they actually yanked their phone number. Posted on the web site they did it so their reps could take care of customers in the order problems were reported.
    Toward the end of 2010, they announced that they were no longer selling retrofit systems as of March 2011... March 2011 came and went and they didn't stop selling them, so I'm assuming there was a management change, or perhaps things went better for them after they relocated to Huntington Beach from San Diego.
    I had a ballast replaced during the time their phones were "off" and it was a major hassle.
    OP reported it's on both, which would be expected since burner power is not switched.
  14. Mar 19, 2013 at 9:55 AM
    David K
    It doesn't start until they are warmed up, and continues as long as I had them on in my garage.
  15. Mar 19, 2013 at 11:15 AM
    #35
    taco47001
    taco47001 Newborn
    Aurora, IN
    LX470
    My passenger side did the same thing except it only lasted about 15 mins. I spoke with andrew regarding this and he stated "they've been having numerous prob's with the quality of the latest batch of V. Regs". They sent me new ones the same day....no questions asked. I don't know if the CCFL halos have the voltage reg. but I'm assuming that you have the LED ones..... Either way, give them a call... Great customer service in my book.
    Oh and I too have the flikr described....It's identical...like a candle waving in a very slight breeze. I can see it while driving though and it's pretty annoying.
  16. Mar 19, 2013 at 1:00 PM
    #36
    thebigsmit
    Brent
    South Carolina
    They are led halos and they dont flash with turn signal anyway
  17. Mar 19, 2013 at 7:44 PM
    #37
    Rich91710
    Rich
    Los Angeles
    08 Base
    LED should not have been a problem even flashing.
    And I'm not sure where this "relay harness required for halos" came from... Andrew said that it was not required for warranty, so if they have failed, you're in good shape.
  18. Mar 20, 2013 at 4:24 PM
    #38
    thebigsmit
    Brent
    South Carolina
    So would you recommend wiring with the relay or just splice them back in like they were before?
  19. Mar 20, 2013 at 4:37 PM
    #39
    Backinblack03
    Backinblack03 Well-Known Member
    Brian
    VT
    2003 Xtra cab 4x4 2.7/5spd
    ABS? What ABS?
    The candle effect is the arc flickering in the HID envelope. It may go away after a good long burn time as the electrodes wear a little, or if it doesn't probably time to replace them. I've seen this in a few of the really cheap HID burners in the past when retrofitting rechargeable spotlights. Easy to spot there. Sometimes hard to spot on the car with the engine running...
  20. Mar 20, 2013 at 7:34 PM
    #40
    Rich91710
    Rich
    Los Angeles
    08 Base
    A relay is never a bad idea.
    So what's the breakdown on flicker...
    Morimoto?
    Philips?
    Osram?
