HID from Slims - Driver side will not turn on
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Madchild, Nov 20, 2014.
  1. Nov 20, 2014 at 9:18 AM
    Madchild
    Madchild [OP] Well-Known Member
    Bloomington MN
    Slim's HID, Tonnau Cover
    Has anyone experience this with their HIDs from Slim?
    The left headlight would sometimes come on and most of the time it would not turn on. Before when I turn the car on the headlight would not turn on. When I shut it off and then turn it on again, the light would come on.
    During the winter the symptoms seems to happen more often than it did in the summer.
    This only happens to the left (driver side) headlights.
    I swapped ballast, bulbs, and re-installed everything. The symptoms still occurs only on the driver side.
  2. Nov 20, 2014 at 9:19 AM
    xtyfighterx
    xtyfighterx Master Shredder
    Ty
    CDA Idaho/ Deadhorse Ak
    09 DC SW TRD OR/ 2015 tundra CM off road sr5
    3in lift, 5100s front and rear, OME 887 springs 2in aal, 285 75 16 Duratracs, mb 352 black wheels, white sport grill, derp'd lower valance, derp'd front toyota emblem white, tinted windows, tinted tail lights, trd shorty antenna, trd hitch cover, trd valve stem caps, trd neoprene covers, trd all weather floor mats, kenwood double din, stampede window visors, flyzeye interior leds, anytime fog light mod, flashlight mod, kool vue intake, LED dome light, Lund bug shield, TRD shift knob,front mud flaps removed, Debadged, truxedo roll up bed cover, led fog light bulbs, led parking light bulbs, led dtrls bulbs, led headlight bulbs, led back up light bulbs, led license plate bulbs, tinted license plate covers, 18" magnaflow muffler, 32in ebay, light bar, coverking neoprene resr seat cover, oem trd skid plate, trd decal on center caps, oem trd exhaust tip, blacked out pinch welds, color matched mirror covers.
    How are the connections maybe clean them and inspect them
  3. Nov 20, 2014 at 9:23 AM
    snowgod06
    snowgod06 UG legend wannabe
    Rob
    A farm field, OREGON
    06 Access Cab
    crap bolted and welded together....
    If you swapped a ballast and it did the same, swapped bulbs and it did the same. I'd expect their to be a connection problem somewhere. Double check all that jazz and should solve the problem.
  4. Nov 20, 2014 at 9:26 AM
    Yota Bird
    Yota Bird Active Member
    Johnathan
    North Carolina
    99 White Prerunner 2.7L
    6K HIDs,6K LED Foglights,Magna Flow Hi-Flo Cat,Flowmaster 40,Tinted Brake Lights,Clear Corner and Turn Light Housings
    Try plugging the plugs in backwards...that works for me when I have people saying there HIDs wont turn on
  5. Nov 20, 2014 at 9:40 AM
    Capt. Obvious
    Capt. Obvious Fearless Keyboard Warrior
    Darrick
    Gig Harbor
    '12 DCLB TRD
    6" body lift, LEDs errwhere, Jesus mural on the hood
    Sounds like you're powering the ballasts with the factory headlight harness. This is the wrong way to do it. The wire is too small of a gauge and the path is too long, causing voltage drops that are enough to prevent the ballast from firing.
    You need one of these: http://www.ebay.com/itm/Xenon-HID-C...Parts_Accessories&hash=item3cd58c6e31&vxp=mtr
    It's plug and play and will take about half an hour to install.
    Additionally, I'm guessing you have drop-in HIDs in your factory halogen housings. Do yourself and the rest of the world a favor and do a proper projector conversion. You are blinding oncoming traffic, and any "improvement" in light output you get from the headlights is coming at the expense of those around you. Don't be an asshole, do it right.
  6. Nov 20, 2014 at 10:27 AM
    Madchild
    Bloomington MN
    This is the Group Buy kit from Slims on this website. The kit came with a similiar harness that's in the ebay link.
    Yota Bird what do you mean pluging it in backwards?
  7. Nov 20, 2014 at 11:46 AM
    itzyoboipaul
    itzyoboipaul Well-Known Member
    Paul
    PFville, TX
    2020 TRD OR Cement
    i dont have a kit from Slim but I do have a full HID projector retrofit. I had that issue before and found out that TRS re designed their ballasts and the ignitor inside the ballast are defective.. it doesnt give enough spark when it gets cold. so like you, i had to turn it on and off twice for it to stay on. so to me it sounds like a ballast issue...try switching the ballasts
    how did i fix my issue? upgraded to OEM Denso ballast
  8. Nov 20, 2014 at 11:47 AM
    Large
    Large Red
    Ditch them and put your OEMs back in.
  9. Nov 21, 2014 at 8:21 AM
    Yota Bird
    Johnathan
    North Carolina
    Plug the connectors in the opposite way, like upside down, flip them
