HID Install How To (For ambiguous retrofit)
Discussion in 'Lighting' started by thegreatwall23, Dec 10, 2012.
  1. Feb 18, 2013 at 11:51 AM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Reminder...
    Tapping CCFL halos into the factory DTRL on a 2nd Gen will result in premature failure. The fluorescent units can not tolerate being used as turn signals.
    I've killed CCFL units in less than 12 hours of continuous flashing on the bench.
    Plus the DTRL shuts off when the headlights or parking lights are on.
    Personally, I'd wire them to a switched-hot that is on with ignition only, not ACC, like the dash lights.
  2. Feb 18, 2013 at 3:16 PM
    AaronArf
    AaronArf Well-Known Member
    Aaron
    VA Beach
    2023 LR OR DCSB
    Good point about the DTRL possibly causing premature failure since they would be utilized as blinkers as well. Not sure how that'd effect the LED halos. maybe I should just do the add a fuse option on an ignition hot circuit. Hmmm.
    Edit: also considering tapping into my fogs as I leave them running 24/7. Then they'd also be switched.
  3. Feb 18, 2013 at 3:22 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Those aren't any better than the quick splices in my opinion. Both damage the host wire at least a little bit. A soldered connection with heat shrink at the joint would be better IMO. Eventually, those quick splices let moisture into the wire and will start to corrode.
  4. Feb 18, 2013 at 3:35 PM
    AaronArf
    Aaron
    VA Beach
    2023 LR OR DCSB
    The quick splices do harm the wire more than these positaps that's for sure. I'll take a small hole vs. guillotining the wire.
    I also plan on using some dielectric grease to minimize moisture intrusion. Not going to cut my factory wires to solder these in because even if I did that I would add some sort of quick disconnect/molex connector because unfortunately for inspection purposes in VA I may have to cut power to the HALO's.
  5. Feb 18, 2013 at 3:40 PM
    Pugga
    Massachusetts
    It's not the poke to the sheathing that does the damage, it's the prong that gets jabbed into the wire so it's not a tight spun wire but it gets split. Dielectric grease would help water intrusion. Have you considered a crimp on connector with that heat shrink stuff built in? You could put a femail side on the host wire and a male on the halo for easy disconnect.
  6. Feb 18, 2013 at 4:07 PM
    AaronArf
    Aaron
    VA Beach
    2023 LR OR DCSB
    I see....
    Anyone know a 12v ignition switched source/fuse to tap into under the hood I can just use a add a fuse on? Figured it'd be easier then going under there with a test light to see. Anyone have a readily available answer :)
  7. Feb 18, 2013 at 5:24 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Buzz out Fuse #10 <TRN-HAZ>
    Should be a 15a fuse that controls the turn signals, hazards, and gauges.
    It may be hot all the time (supplied the 4-ways), so check it. Other than that, I'm not seeing anything under the hood that would be hot only with the ignition.
  8. Feb 18, 2013 at 5:59 PM
    AaronArf
    Aaron
    VA Beach
    2023 LR OR DCSB
    Appreciate the Intel, I'll check it out tomorrow. My retros should be in :p
  9. Feb 18, 2013 at 7:45 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    You may be stuck going to one of the IGN sources under the dash, but it's not a big deal to run through the grommet. It's next to the brake booster. Cut a soda straw off at an angle, run it through the grommet, run the wire through the straw, yank the straw and dab on some RTV on the engine compartment side.
  10. Feb 19, 2013 at 6:42 PM
    Airdog
    Airdog did your Mom
    Tom
    SoCal
    https://www.tacomaworld.com/threads/airdogs-2012-prerunner-access-cab-slow-build.264263/
    Not sure if its always been this way or if its a recent TRS policy. But, your halo's should not be wired directly into the car harness if you wish to keep your warranty intact. To maintain your warranty on the halo's you would need to order a relay harness(9006 relay harness in my case) wire the halos to it and the power and control wires would then go to the car wiring. I am only speaking of the LED type halo's, i'm not sure if there is a difference with the CCFL's.
  11. Feb 19, 2013 at 6:46 PM
    Tacomanator
    Tacomanator Well-Known Member
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    ^ Interesting.
    How would they know how you have them wired, though?
  12. Feb 19, 2013 at 6:49 PM
    Airdog
    Airdog did your Mom
    Tom
    SoCal
    They don't but the harness is only 25 bucks. Considering how much you paid to get them sweet lights done on your truck it may be worth it. All I can say is they may ask questions when you have a warranty claim...one wrong answer could cost you a few bucks. Though TRS has awesome customer service and I dicked up something 100% my fault and they gave me 50% off the replacement part.
  13. Feb 19, 2013 at 7:27 PM
    AaronArf
    Aaron
    VA Beach
    2023 LR OR DCSB
    Hmm. If I buy the harness, how would I wire it into my factory fogs as the power source. Will def have to order this harness. Wish Burt would have included that as an option. Didn't realize they required a voltage regulator. Shoulda done more reading on TRS. :p
  14. Feb 19, 2013 at 7:28 PM
    AaronArf
    Aaron
    VA Beach
    2023 LR OR DCSB
    BTW, this thread is a life saver. Definitely helped me on my install tonight !!!!
  15. Feb 19, 2013 at 7:31 PM
    #35
    thegreatwall23
    thegreatwall23 [OP] Well-Known Member
    Danny
    Mt. Juliet, TN
    2009 TRD Off Road
    Armor Shrockworks front bumber Shrockworks Rock Sliders Brute Force Rear Bumper XRC8 with synthetic rope Relentless Full Skid Pack Suspension Icons 2.5 extended travel all around with King 14" 700# Springs Icon Tubular UCA's All Pro Standard Leaf Pack 3 degree axle shims Wheelers front bumpstop U bolt flip kit Timbren rear bumpstop Mods rear diff breather fog light anytime ABS Disable TPMS disable Door Chime disable Seat Belt Chime Disable Cab Mount Chop Pinch Weld Mod BHLM Other 4.56 Nitro gears FX-R Retrofit HID's with Halos PIAA fogs and driving lights Wet Okole seat covers Weather-Tech floormats Access LiteRider bed cover AMP bed extender Viair 450P-A Rocky Clutch SD mounts Pop-n-lock tailgate lock Aux rear lights Rear sliding window security bar B.A.M.F Light Bar Ultragauge 48" Hi Lift Jack with Bed Rail Mount Bushwacker Fender Flares ECGS PTFE Bushing SS Brake Lines Brembo Blanks Hawk HPS In cab winch control (12voltguy) Tint
    Cool, glad it helped! I was lucky enough to have some of Burts lights early on and was hoping it would help some more people down the road.
  16. Feb 20, 2013 at 6:04 PM
    #36
    Tacomanator
    Clam Slammer
    Southern Cali
    How would I wire the Halo's to turn off when the headlights turn on? Right now I have them tapped into the side marker lights, which stay on when the headlights are on.
  17. Feb 20, 2013 at 9:13 PM
    #37
    thebaker
    thebaker Well-Known Member
    Byron
    NorCal
    Upgraded to a 3rd gen
    Never ending......$$$
    sub'd...thx for the write up!!!
  18. Feb 21, 2013 at 8:20 AM
    #38
    thegreatwall23
    Danny
    Mt. Juliet, TN
    2009 TRD Off Road
    That is a good question... I don't know, but maybe someone could help us out. I know you could just directly wire it with a switch in the cab, but it would be awesome if it was tied into the the existing wiring and automatically did that.
  19. Feb 21, 2013 at 12:05 PM
    #39
    Tacomanator
    Clam Slammer
    Southern Cali
    Would be nice. Never wired a switch before.
  20. Feb 21, 2013 at 5:02 PM
    #40
    AaronArf
    Aaron
    VA Beach
    2023 LR OR DCSB
