HID kit help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TRDsportacoma, Jul 2, 2012.
  1. Jul 2, 2012 at 8:06 AM
    TRDsportacoma
    TRDsportacoma [OP] Well-Known Member
    Brian
    Low Country, SC
    Tacoma Sport
    3in Pro Comp Lift
    so im looking at doing a HID kit swap for the headlights and fog lights does anyone have a good place to look at getting them. i ordered them from carid.com but they keep sending me the wrong bulbs and its ridiculous. so if anybody has a different company or website i can get these from that wont give me such a problem i would really appreciate it.
  2. Jul 2, 2012 at 8:13 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    If you really must go with an HID kit, check out DDM tuning. There are better options out there though...
  3. Jul 2, 2012 at 8:18 AM
    Hii
    Hii Well-Known Member
    PM sent
  4. Jul 2, 2012 at 9:01 AM
    TRDsportacoma
    Brian
    Low Country, SC
    Tacoma Sport
    3in Pro Comp Lift
    Pugga what would you suggest other then HIDs
  5. Jul 2, 2012 at 9:04 AM
    Pugga
    Massachusetts
    A good set of halogens would give you a better usable light pattern for road driving. I've had great luck with Philips Xtreme bulbs and PIAA bulbs. I believe another one is Narva. If you want HID's, I'd suggest doing the responsible thing and at put them into projectors otherwise you get a lot of scattered light.
  6. Jul 2, 2012 at 11:55 AM
    The Traveler
    The Traveler Desert Chief
    SoCal
    1991 Toyota Pickup 4x4 Prerunner
    DDM tuning gets my vote. I live 20 min from their shop in Huntington Beach, and I've always bought all my exterior lighting from them. They warranty their ballasts for life!
  7. Jul 2, 2012 at 1:19 PM
    mbrogz3000
    mbrogz3000 Well-Known Member
    Northern NJ
    '11 TRD Off Road
    Mine are from DDM, are 6 months old and are very very good. I'd recommend them to anyone who has prior experience with HID kits since they are purchased a la carte style...that is you pick the bulbs, ballasts, and harnesses all separately. When they arrive, its a box of HID 'stuff' without any wiring diagrams (mainly needed for hi-low relay) . I didn't have too much of a problem connecting everything since I've worked with HIDs before...it took longer to determine my wire routing that it did to connect everything.
    If you need more of a 'kit' approach, it may be worthwhile calling them up before you order otherwise choose another vendor. Also, HID discussion here is generally frowned upon unless you are converting the headlamps to projectors...even then you'll receive some comments about reduced light output...
