hid problem help please
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kauai808boy, Oct 17, 2010.
  1. Oct 17, 2010 at 9:51 PM
    kauai808boy
    kauai808boy [OP] Active Member
    icon/fox 3inch lift, flow-master super 40, jba shorty headers
    ok i got my hid lights and was installing it on my fog lights and i effin touched one of the bulbs with my hand and some sealent so i tried testing it out too see if it would work and when i ran it straight to the battery the light started flickering on and off then shut off everytime i remove and put back on the power to the batter it does this im thinking its the bulb or the ballast i hope its not the ballast cause ill be super pissed
    so please help tell me wat u think
    its a 55w ddm slim ballast
  2. Oct 17, 2010 at 9:55 PM
    mountainwolfpup
    mountainwolfpup Ford Guy (Formerly known as a Toyota Guy)
    Vancouver, WA
    2015 Ford F150 Lariat FX4 3.5l Eco
    First month of ownership... This month I'm removing front air dam, and also Rhino lining the bed.
    Sounds like loose wiring to me.. The bulb should explode if you get contaminants on it.. or work normally.
    The ballast could be going bad I guess but also is unlikely given the symptoms.
    My guess is a loose connector.
  3. Oct 18, 2010 at 5:56 AM
    KPT
    KPT sees what you did there.
    09 Prerunner
    x2....they tel you not touch the bulbs because getting the oils from your hands on the bulb can create a hot spot...so once the bulb is lit for a while it can blow out.
    Touching the bulbs wouldn't prevent them from turning on initially.
