HID problem.
Discussion in '1st Gen. Tacomas (1995-2004)' started by 2004Taco, Feb 19, 2010.
  1. Feb 19, 2010 at 6:13 PM
    2004Taco
    2004Taco [OP] Financially Irresponsible
    Lou
    Lakewood, CA
    04 Double Cab PreRunner SR5 TRD
    I bought some HID's with the High/low bulb everything worked fine but sometimes either the right or left light doesnt come on. I have to turn the switch on and off to get them back on.
    Anyone else having this problem? Im thinking its the ballast.
  2. Oct 10, 2010 at 7:47 PM
    fubar718
    fubar718 Well-Known Member
    Jose
    NJ
    2010 double cab, TRD offroad
    i seem to be having this problem now. Have you found a solution?
  3. Oct 11, 2010 at 3:10 PM
    2004Taco
    Lou
    Lakewood, CA
    Ya, I gave up and put them back to stock. I'm tired of messing with them.
  4. Oct 11, 2010 at 3:17 PM
    ST77
    ST77 Wandering doesn't mean you're lost
    Brian
    Sandy, Or
    2018 TRD OR DCSB
    Bone Stock
    it's most likely your ground... If you re-install make sure your ground is good and solid.
  5. Oct 11, 2010 at 5:06 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Donahoe CO, Donahoe Rear Resi, Deaver J59, 16" Pro Comp, 33" BFG AT, Hayden Trans Oil Cooler, Oil Filter Relocator, FM 40, ES Bushings, Beefed CB Drop, Deckplate, K&N Drop-In, DO Bed Bar, Cobra 75 WXST, Firestik Firefly, Philips D1R, Clarion Remote Start, Husky Liners
    I've never had an issue like this with my set ups & I'm not even running a relay harness, plugged right into the stock HL plugs.
    My first setup with a cheap kit that I took off my Integra. We sold lots of these kits at my old work & most of them failed. I think I was the last one with a working set, mine lasted for 4 years with a few sets of lamps. One of the external starters failed so I replaced the ballasts with some Hella type clones from ebay. Ran those for about a year with no problems & just swapped them out yesterday for a Philips D1 system but only to cut out interference with my CB.
    You should check your connections. Power them up directly off the battery & see if you have issues, that way you'll know if your ballasts are good. Also the cheap lamps don't last long either, they start to flicker as they come to end of life. Ever since I switched to Philips lamps I've had long life on lamps.
  6. Oct 11, 2010 at 5:14 PM
    ruler
    ruler Well-Known Member
    SoCal - Los Angeles - SGV
    08 Tacoma, TRD Sport, DC 4x4
    Fox Extended Travel Coilovers 2.5 (front), Fox 2.0 shocks (rear),Total Chaos UCA's, AllPro Expedition leaf pack, AllPro front plate style bumper,BHLM, GrillCraft MX series Grill, ATX Thug 17inch rims, Toyo Open Country MT (295,70,17), TRD CAI,Rear smoked LED tail lights, slimcubby HID Head Lights (50w 1200k), ADVMonster 60 Series 3600 Lumen LED Off Road Lights , Pioneer Avic-F700bt (navigation,head unit)
    Which HID's are u guys using?I got the ones from one of the Group buys on here, I had the same exact issue sometimes one light worked,sometimes neither one worked, now only one works so I put my stocks back on after I gotta ticket.
  7. Oct 11, 2010 at 5:20 PM
    TanSR5x4
    TanSR5x4 Hold my beer and watch this
    William
    Houston TX
    00 Tacoma SR5 4x4
    Deckplate mod, black KC slimlight fogs, hurculined bed, NRA sticker mod, painted rear chrome bumper black, black fender flares and front grill surround, HIDs, All-pro rear leafs and UCAs, Eibach coilovers, billys all around, flat black pro comps, 31x10.5x15 BFG KM2s
    i noticed one of mine was out the other day. ive been watching them now and ive seen the same one out probably 2 more times. i havent had time lately but i was gonna trace all the lines down soon to make sure everythings good but idk sometimes they are working flawlessly and sometimes i catch the driverside headlight out
  8. Oct 11, 2010 at 5:24 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Actually, I take that back. That's exactly what was happening to my my first set when they started failed.
    Left side would sometimes not come on. Turn them off & on & the right side would turn off & the left side would come on. I thought it was my battery since I never replaced it & accessories would run slow. With the new battery it didn't do it as often but eventually got worse. Then I could only get the left side to turn on after I've been driving for a while then turn them off & on. Eventually the left side completely stopped working. It ended up being one of the igniters.
    Also with the headlight switch on, when I start the truck, one side would not come on & was random on which side would not turn on. After I got new ballasts (with internal igniters), I never had any of those problems again.
  9. Oct 11, 2010 at 5:27 PM
    atmospheric
    atmospheric Active Member
    stock
    i'm going to chime in my opinion here.
    You won't get a reliable quality hid if you're not willing to pay for it. I have bought ddm tuning hids and slim's hids which have both failed me multiple times.
    both came with defects when i initially got them...i have taken my hids off from frustration. i would get glitches from one side not working, to high beam on/off glitching (holy shit was that annoying)
    and sorry to burst anyone's bubble but the ddm tuning kits are exactly identical to the group buy kits. so if you don't care about the quality, just save yourself a buck and buy ddm.
    and if you have a defect, both do not replace the whole kit...they just replace one part...
  10. Oct 11, 2010 at 5:36 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    I agree 100%. I'll probably get flamed for this but IMO anything that is not OEM is not quality. I've heard lots of talk about DDM, Morimotos, etc but all those inexpensive kits are not all that better but they are sold by sellers who warranties them.
    I never had a problem with the cheap Hella clones I got from ebay. They worked flawlessly but causes crazy interference with my CB so I ditched them. If it wasn't for that I probably would of kept them. If you want real quality, go with OEM, Philips, Hella, Valeo, Denso, Matsushita, etc. & OEM lamps.
    My last setup: Hella clones & Philips 85122CX
    My new set up: Philips D1 & Philips 85126+ (no more CB interference)
  11. Oct 11, 2010 at 6:03 PM
    KStacoma
    KStacoma Member
    AL
    TRD OFF ROAD
    Where did you get your current setup?
  12. Oct 11, 2010 at 6:28 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Got the ballasts & igniters from ebay. The lamps I had sitting for a couple of years, forgot where I got them.
    The Philips ballasts are from a Cadliiac XLR, the igniters are made by Valeo & are from a Volvo to allow D2 lamps to be used with a D1 system. The plug in harness I made from a left over relay harness I had (male H4 connectors soldered to the plugs for the ballasts with two ferrite cores on each harness).
  13. Oct 11, 2010 at 6:48 PM
    fubar718
    Jose
    NJ
    Have to throw my 2 cents in as well. coincidently spent Saturday morning messing around with a brand new kit from VVME. Couldn't even get them to turn on, tried everything in the book, install a set on my boss's car two weeks ago and only lasted a week. You do get what you pay for 45-65$ is exactly what it is. Want something nice that is identical to OEM go with Phillips or Osram from Sylvania (these are the only company that make them for BMW,Mini,Audi,Mercedes,Acura I know because Ive worked for all of them) Only problem is these kits are around 300$
  14. Oct 11, 2010 at 7:42 PM
    IamTacO
    IamTacO red balls got me!
    adam
    QC az
    01 Prerunner SR5 TRD-Offroad
    4x2 Prerunner. Hankook Dynapro ATM rf10 265-65-16, e-locker FTW! Morimoto d2s bi-xenon HID projectors, Philips 85122+ 4300K, Cobra 75 w/ 3' firefly, Kenwood KDC-MP342U w/ SIRIUS, Line-x bed liner, 4' coretrax(black)
    so you are saying that oem's are the best, yet you have hella clones? not oem. with that being said, my morimoto d2s projectors had a better spread compared to my old fx35 retro on my wrx. not as wide, but more intensity and better foreground. sometimes oem isn't always the best. the fx-r's are much better than the fx35's. now, a hid projector will always take the cake compared to a halogen projector too. bottom line, you get what you pay for. cheap=cheap
  15. Oct 11, 2010 at 8:03 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Didn't say anything about what's the best, that would be an opinion. If you read the posts & look at my pics you quoted you will see that I do have OEM ballasts & lamps. I'm a fan of Morimoto projectors too but then again none us here were talking about projectors or headlights. :cool:
  16. Mar 27, 2012 at 8:57 AM
    pikuptruk
    pikuptruk Well-Known Member
    Vallejo
    01 4x4 2.7 Lifted
    6" Fabtech Lift 33" Tires Flowmaster Cold Air Intake
    I agree. My 55w DDM h4s showed up with one bulb fried already. They have a lifetime warrantee however, which is pretty dam cool. I felt compelled to post the lifetime warrantee part because I feel that may appeal to many of retrofitting out headlights....
  17. Mar 27, 2012 at 8:59 AM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    Holy thread revival Batman! I was planning on being helpful in his thread too... Lol
  18. Mar 27, 2012 at 10:23 AM
    hulkit
    hulkit Well-Known Member
    sacramento ca
    2000 tacoma 2.4l automatic
    umm dont know if anyone said this but if you have DLR (daytime running lights) it only allocates a certain amount of power to the lights so thats why only one turns on at least this was the case with my hids i just cut the DLR wire and now both work flawlessly u can google a guide on where to find the wire under the steering wheel
    hope this helps u out
  19. Mar 27, 2012 at 12:20 PM
    bellassaiw10
    bellassaiw10 Formally afroman5015
    Currituck NC
    09 LMM 2500HD Duramax
    I had the same problem mentioned above when I didn't have a Relay Harness after that I never had the problem until one ballast blew but ddm is replacing it anyways
  20. Nov 10, 2012 at 10:09 AM
    Tunajoe13
    Tunajoe13 Well-Known Member
    Joe
    Parrish, FL
    05’ Base V6 4x4 extended cab
    20'' wheels, 34''x11" Toyo Open Country A/T II tires, 4.88 Gears, ARB Locking Rear Diff, ARB compressor, Fiberglass bed cover, Weathertech floor liners, Weathertech side window protectors, Allpro Apex front bumper, Allpro Apex rear bumper Allpro 3'' Expo rear leaf kit, Allpro hidden hitch receiver, 10'' aluminum drop hitch, Camburg 4'' spindles, Allpro uniball uca's, Ottonavi 6.5'' touch screen G.P.S, 09' Tailgate with factory reverse camera, Stampede hood protector, Raptor style grill and hood mesh (Homertaco), Piaa 5100 Fog lights, Volt HID's, Viper5704 Alarm with remote start, Limo tint, Scangauge II, TRD cai, URD 3'' Mk2 exhaust, Doug Thorley LT headers, URD Y-pipe, Unichip PnP Pcm, Unichip Flux2 display, Factory Sport hood....
    just had a similar thing happen to me. I noticed my right high beam wouldnt work... now both dont work. I have the vold kit with h4 hi/low. Could use a hand please. was told my high beams solenoid might have gone
