HID Projector Retrofit
Discussion in '2nd Gen. Tacomas (2005-2015)' started by chacotaco, Aug 24, 2010.
  1. Nov 29, 2010 at 9:07 PM
    #41
    yosh2000
    yosh2000 Well-Known Member
    CO
    '17 Tundra CM 5.7
    these ARE HID bulbs adn projectors...so not sure exactly what your asking. these are better than the PNP crap kits that certain venders sell here for 50-80 or whatever. this uses the HID bulb inside a projecter, therefore focusing the light properly, rather than throwing a HID bulb inside a reflector housing that is designed for a halogen bulb.
  2. Nov 29, 2010 at 9:09 PM
    #42
    schiz94
    schiz94 Thread Jacker
    Caleb
    Bellingham,WA
    08 Tacoma Reg Cab
    Morimoto Projector Retrofit, alpine cda-105,Wheelskins leather wheel cover, wet okoles,5% tint on back and 24% on front two windows,Debadged tailgate,custom sockmonkey centercap decals, xr rims pced gloss black.
    do they have projectors with regular halogen bulbs behind them?
  3. Nov 29, 2010 at 9:12 PM
    #43
    yosh2000
    CO
    '17 Tundra CM 5.7
    ^ yes, camrys and mazda3s, and im sure many other cars, come w/ halogen projectors. but there is no point for a halogen projector if youre retrofitting anyways, might as well go HID projector since your taking the time to retro...
  4. Nov 29, 2010 at 10:32 PM
    #44
    schiz94
    Caleb
    Bellingham,WA
    08 Tacoma Reg Cab
    No, I know I was just wondering cuz I kept seeing cars with projectors. But the light output wasn't great.my uncles camry. A new for fusion. Had projector fogs too
  5. Nov 29, 2010 at 11:32 PM
    #45
    chacotaco
    chacotaco [OP] Well-Known Member
    Travis
    Lawrence KS
    2011 SSM TRD SPORT DCLB
    Black Snugtop XtraVision Sleep Deck.
    Yeah the Fusion PJ fogs made me go WTF, but its probably a halogen in there.
    If your gonna go Big, gotta do the Bulbs and Ballasts right.
    This bulb is a D2S bulb running at 30W. There is a ballast in there that "drives" the bulbs.
    So it is actually brighter, better focused, and uses less energy than my stock headlamps.
    One thing I did notice is that the HID kit is interfering with my stock OTA radio (AM and FM only. Aux and iPod and CD are still money). Need to get some isolation capacitors in there I bet. I will post up how to do that once I figure out how the guys at HID planet take care of that.
  6. Nov 29, 2010 at 11:38 PM
    #46
    schiz94
    Caleb
    Bellingham,WA
    08 Tacoma Reg Cab
    whats an OTA radio? i saw this gril with a fusion and i was like.. da fuck, are those projectors for her fogs? i wanna do a retro badly and now its not the actual opening of headlights that scares me. i just dont know how to wire them up. i got a kinda complicated message.chacotaco, can you post pics of how to wire it? if you did i would love you haha
  7. Nov 30, 2010 at 8:53 AM
    #47
    chacotaco
    Travis
    Lawrence KS
    Wiring is close to idiot proof. Don't be scared. If you can hook up a TV you can do this.
    The retrofitsource gives you an awesome harness that takes care of everything, highbeams, low beams, ballast power, you name it. The ONLY difficult part of wiring the headlamps is finding a place for each ground connector on the harness (the harness could be a bit longer).
    OTA - Over the Air. When my headlamps are on, a ballast converts DC voltage form my battery to a high voltage AC (becasue HID's work on AC).
    So there is a slight issue when my headlamps are on and I am listening to my factory radio, I get noise feeding back into the radio through the truck's ground plane.
    Turn off the lights and the noise is gone.
    There is a simple fix for it, but I haven't gotten around to figuring it out, cause I don't drive every day (live on College Camps) and when I do drive at night I just listen to my iPod or Satellite radio.
    It might also be an artifact of my ballasts. Either-way, its a small issue for me.
  8. Nov 30, 2010 at 10:03 PM
    #48
    MarlaSinger
    MarlaSinger Member
    SoCal
    PreRunner
    I named my truck after one of the Golden Girls...Blanche. muhahahahahaha
    I can't wait to see the night shots. My left front bulb just went out...time to replace.
    I'd rather no halogen, then again...I need to research and see what I can do out here in SoCal to avoid fix it tickets. meh.
  9. Dec 24, 2010 at 1:24 PM
    #49
    chacotaco
    Travis
    Lawrence KS
    Bump for first post update. (begins at [Final Update]).
    I am in the process of getting a new Tacoma, and well, can't get these headlamps back. But that is ok!!
    I'm still open to answer any questions.
  10. Dec 24, 2010 at 3:52 PM
    #50
    pinktaco808
    pinktaco808 Hot Steppa
    got pic of the difference??? also is it easy to put back the stock ones???
  11. Jan 28, 2011 at 5:34 PM
    #51
    chacotaco
    Travis
    Lawrence KS
    Sorry, didn't see this.
    I never got a chance to get difference pics, or output pics, because I replaced this tacoma with a 2011, and let the headlamps go with the old one.
    But the results are typical of what you see at hidplanet and are very nice.
    I plan to do this mod again on my 2011. (maybe then I wil get some good comparison shots)
    also a conversation I just had:
  12. Jan 30, 2011 at 1:28 PM
    #52
    pinktaco808
    so can you put back the oem ones if you want to
  13. Jan 30, 2011 at 6:38 PM
    #53
    chacotaco
    Travis
    Lawrence KS
    In order to do this retro I had to remove the stock bulb shrouds. This required some metal tab bending. So that is probably reversible.
    So no modifications were made to the actual housings in this version of the mod.
    So yes, I believe it is possible to return them to stock.
  14. Jan 30, 2011 at 7:50 PM
    #54
    pinktaco808
    unless i just another stock headlight housing right???but my main concern was about the wiring??? how would that work???
  15. Jan 30, 2011 at 7:58 PM
    #55
    AzogSS
    AzogSS Well-Known Member
    Andy
    Soda City, SC
    2008 Tacoma / 2011 FJC
    Do what I did, buy a set of headlights off here and run them while you mod yours.
  16. Jan 30, 2011 at 10:27 PM
    #56
    chacotaco
    Travis
    Lawrence KS
    Wiring from TRS is plug in play. If you give me 10 minutes and the right wrench, your back to stock no problems at all.
  17. Feb 9, 2012 at 11:03 AM
    #57
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    subbed for doing mine later
