HID Retrofit 2009 Tacoma Extended Cab
Discussion in 'Lighting' started by 95SLE, Mar 27, 2012.
  1. Mar 29, 2012 at 6:06 AM
    tatortot46
    tatortot46 Well-Known Member
    Downingtown PA
    09 tacoma
    Hey great write up
  2. Mar 29, 2012 at 6:40 AM
    95SLE
    95SLE [OP] Starting to get cold outside
    Tom
    Maryland
    09 RWD Access Cab
    Custom XM Install, Window Tint, Intermittant Wiper Install, AVS Bug Deflector, Bed Mat, TRS FX-R retrofits, CIBIE fog and spot lamps, PIAA 510 lamps, Acess LE cover, Weathertech Digital floorr mats, LED interior lighting, Pioneer AVH-2300BT HU, Boston Acoustics speakers, JL Audio Amp, shorty antenna, leather wrap steering wheel cover, Viper security system.
    TY
    This was a fun project. I am still lovin the way the front end of the Tacoma looks with the headlight changes.
  3. Mar 29, 2012 at 9:04 AM
    Oury
    Oury Texas Taco
    Oury
    Austin, Tx
    07 TRD Offroad
    stuff and more stuff
    Hey, i didn't seem too get any mounting hardware (4 screws + nuts) to mount my projector. you know the size of hardware you used?
  4. Mar 29, 2012 at 1:47 PM
    95SLE
    Tom
    Maryland
    09 RWD Access Cab
    I picked up 8 stainless steel 8/32 2in bolts, nuts and washers. Once I had everything mounted in the reflector bowl, test aimed and sealed up I cut off the excess bolt down to the nut.
    I picked these up at Lowes. I believe Home Depot would have them as well.
  5. Mar 29, 2012 at 1:52 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    Looking good Tom!
  6. Mar 29, 2012 at 2:13 PM
    95SLE
    Tom
    Maryland
    09 RWD Access Cab
    One of these days you will bite the bullet Keith and do a retrofit.
  7. Mar 29, 2012 at 2:32 PM
    TexasTacoma37
    Ha, maybe when I don't have two mortgages :laugh:
  8. Mar 29, 2012 at 2:36 PM
    Oury
    Oury Texas Taco
    Oury
    Austin, Tx
    07 TRD Offroad
    thanks!
  9. Mar 29, 2012 at 6:23 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    I was curious about that.
    So it's just a matter of installing the screws and locking them down to the projectors, then spinning a couple of nuts and lockwashers on the back and adjusting those to get the aim right and then locking everything down plus sealant?
    I'd be inclined to use red Loctite, but I have a feeling the projectors might get hot enough to soften it. More likely the high-temp silicone is a better way to "foul" the threads.
  10. Mar 29, 2012 at 8:16 PM
    AsianAnts
    AsianAnts just an AnT
    AnT
    Southern California (San Diego County)
    2011 PreRunner TRD Sport L/B Grey Metallic
    -Satoshi Grille Upper/Lower/Triangles -LED Map Lights, LED Dome Light, LED License Plate Lights -No front license -Wet Okole -Weather Techs (digi) -Running Boards -Bed Extender -AFE Cold Air Intake 2SI Dry Filter -Tailgate Hose-Clamp Mod, Tailgate washer Mod -Combi chain lock on bed extender -no chime w/ key in ignition & open door -Fog Light anytime -Slim Cubby's 3kHID fog -bumper plugs -keyhole plug -TRD license plate frame -combi-lock storage -rear TSB -window tint -camera mod -Painted radiator/engine covers -LS460 RetroFit -Bed Tie-Downs -LED Gauge Cluster, radio, clock and AC -Bed Mat -Extra DRings -Painted center console, radio unit, ac panel, overhead console.
    or its a matter of installing the projectors and locking them down with the screws... :)
    but basically, you got the idea.... i use JB weld to lock everything down. I'm sure the black hi-temp sealant works too!
  11. Mar 29, 2012 at 9:32 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    So what do you think about the E46R-Extended shrouds?
    Do they fit the Taco housings nicely and provide better coverage if the projector is not recessed more deeply than the OP?
    Like I said... I'd be blacking out the reflector bowl (and possibly even the shrouds), so I'm not concerned about reflections from behind the shroud... I just don't want the projector housing to be visible directly when viewed from an angle.
  12. Mar 29, 2012 at 9:47 PM
    AsianAnts
    AnT
    from HID planet:
  13. Mar 29, 2012 at 9:55 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    That'll work.
    Still debating on whether I want to spend the $600 or so on the mod, but I like it!
  14. Mar 29, 2012 at 9:57 PM
    AsianAnts
    AnT
    its worth it, in my opinion. but if you are satisfied with your light output and what not then you can probably spend your money on something else.... I, on the other hand, love lights....
  15. Mar 29, 2012 at 9:59 PM
    #35
    Rich91710
    Rich
    Los Angeles
    08 Base
    Ya, I can see that my stock lights are staring to haze a bit.
    SWMBO has an '04 Rav4 and they are terrible. I've polished them a few times, but the cleaning doesn't last more than a few months.
    I'll likely wait until I decide that I really NEED replacement housings, then sneak the mod in then.
  16. Mar 29, 2012 at 10:10 PM
    #36
    AsianAnts
    AnT
    you clean/wax your lights periodically?
  17. Mar 30, 2012 at 6:16 AM
    #37
    95SLE
    Tom
    Maryland
    09 RWD Access Cab
    What do you use to polish the headlights?
    I normally toss 4 to 5 coats of Zaino on the headlight after polishing. I never have had a problem with the lights fogging back up.
    I usually put Zaino on the headlights of all my vehicles when new and I have yet to even need to polish them.
    I do polish the headlights of friends neighbors and such. All are amazed at the difference.
    On the subject of securing the projector in the reflector bowl. Use the markings in the reflector bowl, the indentation lines, to make the projector as horizontal as possible in the reflector bowl. Here is where measuring 3 times and drilling once is the best policy. Take your time and do not rush this process.
  18. Mar 30, 2012 at 3:26 PM
    #38
    Rich91710
    Rich
    Los Angeles
    08 Base
    Not as often as I should.
    The Taco, I just bought last December and it's an '08, so it's already got a couple of years and 52k on it before I got it.
  19. Apr 3, 2012 at 11:57 AM
    #39
    Oury
    Oury Texas Taco
    Oury
    Austin, Tx
    07 TRD Offroad
    what is an easy way too test the lights such as the bulb and angel eyes?
  20. Apr 3, 2012 at 1:09 PM
    #40
    AsianAnts
    AnT
    just plug it all in as you normally would...
    for the angel eyes just run the positive to the positive on the battery and negative to the negative...
