HID trouble
Discussion in 'Lighting' started by dwsalley95, Apr 8, 2012.
  1. Apr 8, 2012 at 5:04 PM
    dwsalley95
    dwsalley95 [OP] Well-Known Member
    Dylan
    Columbia
    07 TRD SPORT
    Hey everybody just ordered and installed my 55w 6000k HID hi and lo beam kit from ddmtuning.com onto my 07. They look great but for some reason my passenger side hi beam won't work but my driver side does. Anyone know what could be causing this problem? Both work fine on lo beam but when I flip it to hi beam only my driver side goes to hi beam and the other stays on lo. Any help or ideas would be MUCH appreciated...
  2. Apr 9, 2012 at 8:34 AM
    Oury
    Oury Texas Taco
    Oury
    Austin, Tx
    07 TRD Offroad
    stuff and more stuff
    Contact DDM, I've read a few ppl having the same problem. Could be the relay or the harness.
  3. Apr 9, 2012 at 11:03 AM
    Hii
    Hii Well-Known Member
    Have you checked that your ground is good on the side that isn't functioning properly?
  4. Apr 11, 2012 at 11:17 AM
    dwsalley95
    Dylan
    Columbia
    07 TRD SPORT
    I tried re-grounding and that didn't work, so I guess my next step is to contact DDM.
  5. Apr 11, 2012 at 5:17 PM
    nammer
    nammer Well-Known Member
    Nam
    Bradenton, Florida
    Wishing I had a Taco
    switch the ballast to make sure it's a problem with the side or the ballast?
  6. Apr 11, 2012 at 5:19 PM
    nammer
    Nam
    Bradenton, Florida
    are these the kind that have a separate ground or does it plug right into the oem harness? because if your equipment is fully functional maybe you accidentally didn't properly wire the power to the high beam (cause 1 is high, 1 is low, and 1 is ground on the oem harness)? i know i've made that mistake before
