Hidden gem for cleaning your windshield
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Anothertacomaguy, Jan 15, 2013.
  1. Mar 25, 2014 at 5:23 PM
    #121
    04trd
    04trd Well-Known Member
    Cleveland Ohio
    2015 f150 lariat
    weather techs, 20precent tint, leveling kit, back flip bed cover, rhino liner
    I could have swore he said use 320 sand paper to get those really hard spots out
  2. Mar 26, 2014 at 9:14 AM
    #122
    Smashing
    Smashing Well-Known Member
    Rochesterish NY
    2017 DCLB Sport
    No it's not. Read the label.
  3. Mar 26, 2014 at 9:19 AM
    #123
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    Grinders are the quickest way to clean them :D
  4. Mar 26, 2014 at 3:42 PM
    #124
    Smashing
    Rochesterish NY
    2017 DCLB Sport
    Apply a 2x4 to them and take advantage of no deductible glass coverage.....
  5. Mar 26, 2014 at 3:45 PM
    #125
    Smashing
    Rochesterish NY
    2017 DCLB Sport
    You wrote this? Aren't you the same person that recommended using Bon Ami - an abrasive product- on glass?
  6. Mar 26, 2014 at 4:00 PM
    #126
    XXXX
    sKiP
    05 Prius
    Yes. I personally wrote it.
    Yea that's me. What's wrong with it?
  7. Mar 26, 2014 at 7:18 PM
    #127
    Shane84
    Shane84 Member
    Shane
    McKinney, TX
    12 DCSB TRD-OR 4x4 MGM
    Rear diff breather mod, Billy 5100 shocks. eibach coils at 2.5" front lift, Icon progressive AAL 2" rear lift, hypertech 730117 speedo corrector, cmc
    +1, clay bar works great on the windshield and no risk of damage. It takes the microscopic contaminates off the glass which show up when the sunlight is in your face.
  8. Mar 27, 2014 at 4:23 AM
    #128
    itsakeeper
    itsakeeper Well-Known Member
    nova scotia
    2012 SR5
    Brake Clean - best cleaner ever, cleans off everything including paint :)
  9. Mar 27, 2014 at 6:16 AM
    #129
    XXXX
    sKiP
    05 Prius
    considering your screen name - sounds about right
    I was kidding...yes I wrote the above cleaning info and no I never looked into Bon Ami nor recommended it. It sounds bad to me.
    "some glass"
    In my experience if it isn't safe for ALL glass it shouldn't be used on any glass.
    That's like the dipshits in here saying cook top glass cleaner is OK for your windshield. If that's the case and the glass is the same (it's not even close) lets heat our windshields up to 500* and start dropping hot pots and pans on them and see what happens. :laugh:
    Personally I only use glass cleaners and polishes that are safe to use in OPTICAL applications.
    What is it with people using incorrect products on glass? Are there not enough glass products already on the market that people need to think they are scientists and come up with new ways to clean glass?
    Clay baring your windshield is retarded. For example - Next time you want to wash your truck use Windex on the paint. Why not? If you use paint products on glass that should work just fine right :facepalm:
    Clay will only fill in the tiny gaps and clevises in your windsheild thus attracting more dirt and thus breaking down your glass even quicker. Also last time I checked clay is also not clear so the gaps and crevices you just filled with it are now opaque.
    This is glass......
    I agree.
    Seems people are truly clueless about what they look through all day every day..... no one has any idea about the chemical composition of glass or what they do to it when they use products not meant to be used on it. These people are chemically altering the surface of the glass and while they don't give a shit because it's only a stupied truck windshield they need to stop telling others shit they know nothing about.
    Glass is a term that can be applied to many different materials, but is usually taken to mean silica-based amorphous materials. Glass objects are commonly formed from a mixture of silica (SiO2), the alkali oxides soda (Na2O) or potash (K2O), and alkaline earth oxides such as lime (CaO).
    The proportions of silica, alkali and alkaline earth may be varied to form glasses with different properties; a high-silica glass will tend to have a high melting-point (and hence be hard to work at moderate temperatures).
    Increasing the amount of alkali chemically disrupts the silica network, and lowers the working temperature of the glass also making it less durable to chemicals.
    This poor durability manifests itself in a number of ways, but one of the most distressing is crizzling. A crizzled surface will become covered with minute surface cracks, which over time will grow and penetrate the whole body of the glass and lead to its physical collapse. Before cracks are seen to form, the initial stages of the processes may be identified by the production on the surface of the glass of a wet surface that feels 'slippery'. Droplets of moisture may be seen to form and these droplets lend the term 'weeping' to glasses exhibiting this behavior. This wetness occurs at higher humidities (usually above approximately 50% relative humidity). When the humidity falls, the surface can dehydrate, and crystals may form on the surface of the glass.
    As the glass dehydrates further, moisture can be lost from the sub-surface layers of the glass itself and it is this cycle of hydration and dehydration that occurs during environmental fluctuations which leads to the formation of surface cracks. The surface swells as it absorbs moisture, and shrinks as it loses moisture. The effect can be seen in figure 1 which shows an image of the glass surface taken with an optical interferometer, capable of high resolution three-dimensional surface imaging. The swelling of the surface has caused the surface to 'buckle' and rise in ridges along the line of the cracks.
    Figure #1
  10. Mar 27, 2014 at 6:56 AM
    #130
    CVYota
    CVYota Yarrr, me be Captn Andy
    Andy
    Crescenta Valley
    2011 DCLB V6 4WD
    How did I miss this thread? Amazing.
    OP, Next time you post a thread for a great new product, ask if anyone thinks it is a bad idea, not "you should use this". There are many great resources here and they are willing to help, that is why it is a popular site.
    Skip:
  11. Mar 27, 2014 at 8:43 AM
    #131
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
    :notsure:
    TACOMA GNOME likes this.
  12. Mar 27, 2014 at 9:49 AM
    #132
    Frogsauce
    Frogsauce Well-Known Member
    Chesapeake Bay
    16 TRD Offroad
    Stole from funny pics thread...seems applicable
  13. Mar 27, 2014 at 9:59 AM
    #133
    XXXX
    sKiP
    05 Prius
    Personally I hate squeegees but it's in the GANA guide to cleaning that was written by many people far smarter than I so included it in my instructions.
    My issues with them is they pick up abrasives and than you drag them across the surface scratching the glass.
    I had a job with about 4,000 sqft of 1/2" thick low-iron tempered glass in a high end lawyers office and about (30) doors of the same. We finished the job and I got a call two weeks later after the final cleaning was done about a day before it got turned over to the client. The GC told me all the glass was scratched and I needed to replace it. I immediately jumped in my truck and drove to the job site to inspect it. Within 5 minutes I figured out the cleaners had not washed the jobsite dust (drywall from sanding, concrete from slab coring, etc.) off the glass before using the squeegee so they ended up dragging all the abrasives and scratching each and every piece totaling over 100k in damages.
    I am sure someone lost their job after that one.
    :D
    :laugh:
  14. Mar 27, 2014 at 12:40 PM
    #134
    jethro
    jethro Master Baiter
    Geoff
    Southern NH
    2020 Ford F-150 Lariat 5.0L V8
    Subbed. I'm going to masturbate to this thread later.
  15. Mar 27, 2014 at 1:19 PM
    #135
    XXXX
    sKiP
    05 Prius
    use oven cleaner.... I do and it works great :D
  16. Mar 27, 2014 at 1:24 PM
    #136
    JDMcQ
    I'm masturbating right now!
  17. Mar 27, 2014 at 1:28 PM
    #137
    XXXX
    sKiP
    05 Prius
    Did it make the paint shiny :D
    is that why you called me huffing and puffing? I feel dirty now
  18. Mar 27, 2014 at 1:47 PM
    #138
    chickdr
    chickdr Well-Known Member
    Atlanta, GA
    Tacoma 2.7l
    Have to disagree on the negatives of using 0000 steel wool. It is soft enough to use on your skin and certainly has never damaged my glass. It is great for removing paint over spray. I wouldn't use anything more course, but 0000 works fine.
  19. Mar 27, 2014 at 2:13 PM
    #139
    XXXX
    sKiP
    05 Prius
  20. Mar 27, 2014 at 5:30 PM
    #140
    CVYota
    Andy
    Crescenta Valley
    2011 DCLB V6 4WD
    Aim for the windshield, it makes a great cleaner
    I knew you would
