Hidden Winch Mount Closeout!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by chase6616, May 24, 2014.
  1. Jun 11, 2014 at 7:25 AM
    AlanLoshbaugh
    AlanLoshbaugh Well-Known Member
    Alan
    Columbia, MO
    2013 Tacoma Double Cab 4x4
    I'm probably wrong about this, but:
    I think, with the Undercover, you leave the front valance in place, and trim to fit; and, retain the factory "skid plate."
    I think, with the US Offroad, you entirely remove "the offending portion" of the front valance, and, it has sort of a built in bash plate, to a degree.
  2. Jun 12, 2014 at 8:52 PM
    Misl
    Misl Member
    Kevin
    Midwest
    TRD
    I was doing some more research and I seen this video on UndercoverHWMS.com... Are there any video of U.S Offroad being trail tested? I'm really concerned of the build quality of U.S Offroad. The metal looks really thin compared to Undercover HWMS.
    https://www.youtube.com/watch?v=1rhVkeTwkQs
  3. Jun 13, 2014 at 8:12 AM
    usoffroad
    usoffroad TEXAN Vendor
    Brad
    Hico, Texas
    1998 4Runner and 1970 FJ40
    Not sure how you can ascertain the metal thickness by looking at pictures but our winch tubs are .250" steel with a .130" fascia/skid plate overlay that is fully gusseted. The video you reference above is not a trail test and lifting a few thousand pounds from a tree should not come close to the maximum rating for any winch bumper... but it looks neat. If you have a 5000lb truck with a 10,000 lb winch the bumper better be able to withstand that 10k worth of winch force.. not just 2-3000lbs of weight when you lift the front end a few inches off the ground. It's not a trail test.
    There's a video or two on our G+ page along with many customer install photos: https://plus.google.com/u/1/+BradGalbraithusoffroad/posts
    Do a little more research and I think you will have your 'concerns' of our build quality relieved.
    I also addressed your second post on this here: http://www.tacomaworld.com/forum/2n...-mount-bumper-development-12.html#post8784987
  4. Aug 17, 2014 at 7:51 AM
    EdinCincinnati
    EdinCincinnati Well-Known Member
    Ed
    Ohio
    2014 4x4 TRD OR
    Anyone have any firsthand user reviews and pictures for this winch setup yet?
  5. Aug 17, 2014 at 8:17 AM
    usoffroad
    Brad
    Hico, Texas
  6. Aug 17, 2014 at 9:14 AM
    EdinCincinnati
    Ed
    Ohio
    2014 4x4 TRD OR
    I am indeed and have money to spend!!
  7. Aug 18, 2014 at 2:45 PM
    chase6616
    chase6616 [OP] Member
    Chase
    Jacksonville,FL
    06' PreRunner TRD OR SR5
    bilstein 5100's, maxtrax spindles, dealer springs, Thule Rack, 285/75/16 BFG KM2's, ARB awning, all pro bed cage, tepeui RTT, spidertrax spacers
    Yea man, I've been running this one for a few months now. It's very strong. Install wasn't that bad. I put a Smittybilt XRC comp on mine, which mounted easily. It has these two tabs on each side that prevent the front bumper from wobbling around once the center section is cut out. I'll post some pics up later.
