HIDs with factory headlights
Discussion in 'Lighting' started by TacoTony, Feb 17, 2013.
  1. Feb 17, 2013 at 6:20 AM
    TacoTony
    TacoTony [OP] Well-Known Member
    tony
    san antonio
    single cab rado
    Maxtrac spindles
    Ok so I wanna run HIDs with my factory headlights but I've heard it might melt the lens, is it possible the run them like this?
  2. Feb 17, 2013 at 6:26 AM
    HIst8ofMIND
    HIst8ofMIND Defend Hawaii
    PJ
    Maui
    2013 MGM DCSB TRD-OR
    Please don't. Unless you do a retrofit. Please don't run HID on the stock housing.
  3. Feb 17, 2013 at 6:27 AM
    TacoTony
    tony
    san antonio
    single cab rado
    Maxtrac spindles
    Good to know man, thanks
  4. Feb 17, 2013 at 6:36 AM
    Swank
    Swank Certified Mall Crawling Instructor™
    Steven
    Greenville NC
    SOLD :(
    If it's any help, I'm running them with my headlights I bought off ebay, pretty sure they are cheaper made than the OEM ones, no issues with them though.
  5. Feb 17, 2013 at 6:41 AM
    Tacomanator
    Tacomanator Boiling denim and bangin whores
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    Theretrofitsource if the best place to buy them. They are very high quality and come with a 4 year warranty.
  6. Feb 17, 2013 at 6:55 PM
    09DBLCAB09
    09DBLCAB09 Well-Known Member
    I have 55w in my stock headlights. Been running them for almost a year. 0 problems
  7. Feb 18, 2013 at 12:53 AM
    RipVanDango
    RipVanDango Active Member
    Cody
    Alaska
    '92 / 2012 TX Pro
    Leer 100XL Canopy, Home Made LED Bar, Lightforce Blitz 4300k 35W HIDs, Supertones Hella Horns, LED Bed Light,
    I think he (2tone33) is talking about using projectors over actual problems with the stock housing because it's, "offensive" to other drivers. Feel free to correct me of I'm confused.
    I run mine in the stock housing too with no problems. It's actually not that bad, they can be aimed to not blind people. I don't get brights flashed at me.
  8. Feb 18, 2013 at 12:56 AM
    benbacher
    benbacher Purveyor of Fun Vendor
    Anchorage, AK
    '10 Tacoma 4x4 LBDC SR5 TRD Sport
    Too many to list now.
    So you say :rolleyes: :p
    I'd do projectors over the stock housings anyway OP, if you're wanting to spend money to get more light output, spend a bit more and do it all the way. Save yourself a having to worry about blinding oncoming traffic and just put all the light you want on the road where you need it
  9. Feb 18, 2013 at 1:37 AM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    35 watt will be fine......prolly even 55 watt.
    55 is insanely overkill for onroad use without projectors tho.
    Remember, 4300k to 5000k is a good range, and id never go above 6000k....the bluer the less output, and the worse visability.
    Keep in mind that no OEM manufacturers send out vehicles with blue hid lights (6000k and above).....they are standardized 4300k philips bulbs, but the projector causes them to look blue to oncoming traffic within the cutoff line.
    Im not getting into any projector vs oem housing debate.....just giving u a lil info, since ppl like to think 8000K is brighter than 4300K just cuz its a higher number...in fact tho, the higher the number, the bluer it is and the less output.
    Happy hunting
