High Beam Indicator not working after LED headlight upgrade
Discussion in '1st Gen. Tacomas (1995-2004)' started by JasonLee, Dec 2, 2014.
  1. Jan 17, 2016 at 9:58 PM
    bellassaiw10
    bellassaiw10 Formally afroman5015
    Currituck NC
    09 LMM 2500HD Duramax
  2. Jan 19, 2016 at 1:00 PM
    alphabravo
    alphabravo Well-Known Member
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Supercharger AntiDark Hood Light Redline Tuning Hood Struts Morimoto Projectors Grey Wire Mod Tundra 13WL Brake Conversion EBC ED Pads and GD Rotors Mean Green Starter DC Power 250A Alternator Odyssey PC2150 Battery, Artec Cage ADS shocks Total Chaos UCA ComeUp Winch, Factor 55 Splicer Relentless bumpers OTRATTW Switches, Bussman 15304-2-2-4 RTMR, Paranoid Fabrication switch brackets Jensen JHD3630BT Morimoto XB LED Fogs Deaver Custom Springs Ivan Stewart TRD Wheels, Pro Series TRD Wheels
    I just got one of those blue/black box ones but I haven't installed/tested it yet.
    The first ones I got (the ones with the yellow insulation from ebay) burned through and probably could have started a fire.
    Be sure they don't get hot.
  3. Jan 19, 2016 at 1:02 PM
    alphabravo
    Christopher
    Canada via FL
    2003 Tacoma TRD
    btw, has anybody heard of way to defeat/bypass the load/error sensor so that these resistors aren't needed?
  4. Jan 19, 2016 at 1:56 PM
    Sicyota04
    Sicyota04 Slowly but surely.
    Morgan
    California
    04 DC 4x4
    Damn dude! Good thing your truck didn't burn up!
  5. Jan 20, 2016 at 12:00 PM
    JasonLee
    JasonLee [OP] Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    You would need to get into the ECM and either tweak the hardware or the software to fix it. Most people don't have that knowledge and people that do (like me, a Computer Engineer) don't see the point in spending so much time with no reward ($ for the time put in).
    Also, the LED headlights I tried were a safety hazard so I went back to halogens.
  6. Jan 20, 2016 at 12:13 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
  7. Jan 20, 2016 at 2:26 PM
    alphabravo
    Christopher
    Canada via FL
    2003 Tacoma TRD
    That makes sense. I was hoping it would be an analog relay or something.
  8. Jan 20, 2016 at 5:55 PM
    JasonLee
    15 TRD OffRoad
    from my memory, when I was in that position I remember everything being inside the ECM or another box that does the logic. The details of the innards of these is not published and to reverse engineer would take time.
    I am opposed to load resistors because part of the reason to use LEDs is to use lower power. Having to out in a load resistor just create unnecessary heat and continues to waste power and draw from the electrical system (and battery when off).
  9. Feb 14, 2016 at 6:36 PM
    alphabravo
    Christopher
    Canada via FL
    2003 Tacoma TRD
  10. Feb 15, 2016 at 5:51 PM
    leibbrand
    leibbrand Well-Known Member
    Seattle WA
    3rd gen 4runner, 1st gen tundra
    3rd gen runner: ICONs, Light Racing, Camburg, TRD SC, URD, ARB, Thorley, etc . 1st gen tundra: LT, Solo/MCM Canti , King, ARBs, etc
  11. Oct 29, 2016 at 9:31 PM
    Snowman
    Snowman I have a problem for your solution…
    Craig
    Somewhere in Canada
    Check out my build
    I know, old. But I figured out why my indicator light didnt work, even when using one of those ebay loads.
    Apparently the indicator isnt directly wired to the high beam (ie high beam on, indicator on). It works on a resistance system and that ebay load adds resistance to allow the indicator to work. Problem with my set up was I didnt have enough resistance even with that load because the cluster/dash bulbs are also in that resistance circuit. I am currently running LED dash bulbs and they dont have enough resistance (even with the ebay load) to make the indicator light up. So after an enormous amount time frigging with everything I noticed if I put a couple stock 194 bulbs in line with the HID harness the indicator would work.
    So the fix (for me) was either swap my cluster/dash bulbs back to stock 194s (not happening) or add a few in line under the hood. Now everything works and I have a little bit of "diagnostic" light under the hood when the high beams are on.
  12. Oct 29, 2016 at 9:33 PM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    can you post a pic of your diag lights? ;)
  13. May 9, 2017 at 2:23 PM
    mixxman
    mixxman New Member
    Placerville, CA
    1999 tacoma SR5 4x4 3.4lv6
    HID, Roof mount Spots,
    I finally got my high beam indicator to work! I purchased 2 load resistors 6ohm/50watts. You have to wire one between the low and high beam wires (the vertical spades)and another between the horizontal connector and the high beam. You only have to do the passenger side. Hope this is helpful.
  14. May 28, 2017 at 3:25 PM
    Seagull233
    Seagull233 Well-Known Member
    Tom
    Upstate New York
    2004 DC 4x4 V6
    BMW seats, OME Suspension, CBI and NWTI plates front and rear, 13,000 winch, LED light bars, Ham Radio, topper with roof rack added, stainless exhaust, 2nd battery, inverter, sound deadener
    I found a fairly economical way to solve this issue. I purchased a pair of H4 wiring extensions from Amazon https://www.amazon.com/gp/product/B009NYH9YE/ref=oh_aui_detailpage_o05_s00?ie=UTF8&psc=1, cut them in two, and spliced two females to one male. You just plug one of your old bulbs into the second female plug, and presto, indicator is back working. I put mine on the drivers side, put the bulb into an old 6 oz V8 juice can and tucked it through a hole out into the fender cavity, out of the way, and no strange lights under the hood. $10 and a little time to solder it together. My kind of fix! And I have a spare bulb for the future.
  15. Dec 17, 2017 at 12:51 PM
    #35
    SOMD_Digger
    SOMD_Digger New Member
    2001 Tundra
    In addition to the above issues High Beam Indicator not working and automatic shutoff. What did you all do with the boots that keep moisture from getting in the lens bodies as they are not useable with the new LEDs?
  16. Dec 17, 2017 at 1:15 PM
    #36
    Seagull233
    Tom
    Upstate New York
    2004 DC 4x4 V6
    I trimmed the boots as best I could to fit the LED's. Not perfect, but better than nothing at all. So far, so good, but just now getting into the wet season.
  17. Dec 17, 2017 at 1:55 PM
    #37
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    I never put them back on :notsure:
  18. Sep 11, 2018 at 7:11 AM
    #38
    b.m.kelly
    b.m.kelly Active Member
    Ben
    York Pennsylvania
    1997 Toyota Tacoma LX 3.4l V6
    eibach shocks w/ toytec 3in springs OME Dakar leaf pack w/ shackle lift Pro comp 52 series wheels 33x12.5 r15 BFG Mud-Terrains
    How is working now that the thread is a little only. I need to do something about my lights as I have the same problem as everyone else. I found this exact product online but it says that it is a kit and will come with 2?? I assume I only need 1? seems weird they would send 2 if only 1 is needed. Thoughts anyone?? Thanks!!
  19. Sep 11, 2018 at 7:16 AM
    #39
    1997tacomav6
    Denver
    You only need one, I had one for my high beam indicator but ended up removing it as it must
    have gotten up to 150 -200 degress. Not sure if that was normal but didn’t want to take a chance of a fire.
    It’s essentially a big resistor
  20. Sep 11, 2018 at 7:22 AM
    #40
    b.m.kelly
    Ben
    York Pennsylvania
    That's not cool. Definitely do not want to burn my truck down lol. My only issue is that for PA inspection that will be flagged if it is not working and the possibility of it not passing is large just due to that (or so I have heard at least). I know I can just change out lights before inspection but I have a 97 so taking the grill off is a pain plus the front bumper of mine is smashed a little making everything that much harder. If possible I need a solid solution that will allow me to just leave it how it is and make the light work. I do not mind that is doesn't work. It never bothered me. I am just afraid of inspection. Suggestions??
