High end brakes for 15-inch wheels, or 16s with Tundra break mod?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Urban Redneck, Apr 22, 2015.
  1. Apr 22, 2015 at 9:37 AM
    Urban Redneck
    Urban Redneck [OP] Well-Known Member
    2004 3.4L V6
    I'm starting to dial in on the suspension and wheels, but I can't make up my mind on wheel size and brakes.
    I'm gonna run 33s, and like the look with 15-inch wheels. I was figuring on also getting the ECS Stage 5 kit, and possibly new calipers.
    But I can't stop thinking about 16s and tundra brake mod.
    I'm not sure, but image the Tundra brakes offer more stopping power, which is ultimately what I'm after ...
    What do you guys think?
  2. Apr 22, 2015 at 4:04 PM
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    Tundra brakes for sure. You can find a set of stock 16s pretty easily and for pretty cheap.
  3. Apr 22, 2015 at 5:23 PM
    Urban Redneck
    2004 3.4L V6
  4. Apr 22, 2015 at 9:49 PM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
  5. Apr 22, 2015 at 10:05 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    This is my exact situation. I have maybe 8-10 months to decide. Tires will need replacing then.
    ATM I am thinking Tundra brake upgrade. My truck is very heavy. Last adventure, fully loaded, it weighed ~5700 lbs.
    I think so
    edit: A lot of good info in this thread: http://www.tacomaworld.com/forum/1st-gen-tacomas/334072-banjo-fitting-seal-tundra-brake-upgrade.html
  6. Apr 23, 2015 at 7:25 AM
    Urban Redneck
    2004 3.4L V6
    Great thread. Looks like it can be done with 1. a junk yard set (cheapest) 2. sourcing your own new parts and fittings for ~$300 to $400 or 3. a complete kit pushing about $600 ...
  7. Apr 23, 2015 at 10:47 AM
    slander
    Hickory, NC
    The stock tundra brakes absolutely will have more stopping power. I used auto store parts for my swap and have had great luck. For the past year, up until i got my fj80 rear axle in, i have been stopping exclusively with the front brakes. No warpage and stopped great. I drilled the bottom of the tacoma banjo bolt to get them to work with the tundra calipers, and my stainless steel lines i bought for the swap sat on my shelf for 5yrs until i re purposed them for my axle swap.
  8. Apr 23, 2015 at 10:51 AM
    CanadaToy
    CanadaToy Well-Known Member
    Greg
    Toronto
    17 DCSB TRD OR Alpine
    TRD Pro grille & skid, OEM tonneau and roof racks
    Tundra brakes all the way. I was sick and tired of warping stock brakes.
  9. Apr 23, 2015 at 10:55 AM
    Urban Redneck
    2004 3.4L V6
    Sweet. I'm gonna have to man-up and get 16 inch wheels. With armor, 33s, and a possible SC in my future, I want all the stop power I can get ...
  10. Apr 23, 2015 at 6:00 PM
    DSMJRV
    DSMJRV Well-Known Member
    justin
    Corona, CA
    typically a larger disc will provide better stopping power than high powered calipers... geometry beats engineering/hydrolics...
