High Mileage Tacoma's
Discussion in '4 Cylinder' started by dcous, Oct 19, 2015.
  1. Jul 13, 2016 at 7:56 PM
    #41
    UncleGri44
    UncleGri44 Active Member
    2006 single cab 2.7l 5speed manual
    Auxiliary audio cable mod
    honestly it really depends on how I drive. I have gotten a tiny bit better than 23mpg in the past but if I get into the throttle too much I don't even see a difference between standard oil and 0-20. So If you want to sunday drive then it'd prolly get you a couple mpgs.
  2. Jul 14, 2016 at 1:32 PM
    #42
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    What I meant to ask was this: How many miles were on your truck when you switched from 5w30 to 0w20?
  3. Jul 14, 2016 at 4:58 PM
    #43
    UncleGri44
    right around 50,000 when i switched.
  4. Dec 5, 2016 at 11:09 AM
    #44
    JDCPA
    JDCPA Well-Known Member
    Jim
    SW FL
    09 5 Lug Access Cab SR5
    Curt Hitch and etrailer.com wiring harness.
    208,500 on my 2009 5 lug Access Cab automatic. I drive it the same way I did when I bought it including towing my Carolina Skiff. On my second set of front brake pads. 3rd battery. Numerous tires. 65th oil change. 2nd radio antenna. No other repairs other than body work when I hit a deer in Tennessee. I use 5W-20 oil. I put 235-70-15s on it after the original factory set of tires and consistently get 20-21 mpg running 80-85 on the interstate.
  5. Dec 5, 2016 at 10:24 PM
    #45
    Tacotruck7
    Tacotruck7 Well-Known Member
    SoCal
    04 Prerunner Dbl Cab 2.7L
    187k on my 2004 prerunner. No sign of stopping.
  6. Jan 4, 2017 at 1:30 PM
    #46
    Leifmealone
    Leifmealone Well-Known Member
    San Diego/Northern California
    2005 Tacoma 4cyl 4x4
    I've got 270,000 on my 05 4x4 4cyl and I've beat the cap out of her. engine still runs OK still has power and feels tight. just makes some noises here and here and burns some oil. Planning on swapping engines when I hit 300,000.
  7. Jan 4, 2017 at 3:22 PM
    #47
    My02SC
    My02SC instigator
    Frank
    Jersey Shore ,PA
    2003 Tacoma,TRD
    2.5 lift, the usual that goes with it. Work in progress.
    I got 236000 and change. 96, 3" inch lift and 33's, 2.7 3rz, slow but runs well. Mpg is about 18 on the highway.
    Leifmealone likes this.
  8. Jan 14, 2017 at 4:58 PM
    #48
    2.7taco
    2.7taco Well-Known Member
    Texas
    2005 Tan Tacoma Base 5 LUG: Beaten , abused and still running strong.
    Fat Bobs 2.75 lift and level with short AAL, 16x8 Level 8 Guardian Wheels, 245/75R16 Toyo Open Country ATII, custom trans shift kit(home made), Trans temp. and Vac gauge, URD fuel pump upgrade(going back to stock soon).
    195k on my 05 2TR burns a little oil, plenty of brake changes, gear oil changes, trans pan clean outs, 2 fuel pumps, fuel pressure regulator and pulsation dampener, way too many shocks and struts to count and 4 sets of spark plugs. Currently running 0W-40 Mobil 1 and a Motorcraft FL400S filter. Beaten the tar out of this truck and it still has a tight front end.
    DGXR likes this.
  9. Aug 3, 2018 at 10:43 PM
    #49
    Skittles93
    Skittles93 'Member
    Novato CA
    TRD OR SB 4x4 (sold) 19 4runner TRD Pro
    Frankenstein Mid-Travel Kit, sPod, Relentless Custom Baja Bumper, Relentless: Sliders, T-case skid, rear bumper, tailgate reinforcement, Rago Fab: Bed Channel Stiffeners, SCS 16" wheels, BFG KO2 275,75,R16, Diff breather mod, A/C hose extension mod, Custom exhaust routing. (Sold)
    I'd love to start this thread up again and see where everyone is. I have heard the 5spd in the 2nd gens is pretty bulletproof but all these high milers seem to have manuals, would love to get some insight on that particular tranny. My 2012 4spd I4 4x4 work truck is going strong (although she rattles quite a bit) with 149K even being idled all day every day, 4 wheeled, and otherwise thrashed. The work taco only ever gets penzoil changes at 5K, plugs and filters every 50k. My personal 2015 TRD OR 5spd 4x4 4.0L has 44K and is, of course, as smooth as butter.
  10. Aug 3, 2018 at 10:59 PM
    #50
    Tacomamike mike
    Tacomamike mike Just that, nothing more.
    Michael
    2017 DCLB TRD OFFROAD 4x4
    Working on it, dissent offroad racks, shift sense pro, pedal commander , ARB twin, rigid SS dually's , dual batteries, ARB fridge , 2.5 Fox coil overs wResi , 2.5 Fox rears w resi Total chaos UCA , deaver packs , Nitto trail grappler's 33" .
    My 2004 has 257,000
    2017 just turned 16,000 today
    BassAckwards likes this.
  11. Aug 21, 2018 at 9:14 PM
    #51
    TRVLR500
    TRVLR500 Well-Known Member
    Wyoming
    Tacoma SR5 4X4 2.7 4CYL
    My 2004 RC 4X4 2.7 5 speed Tacoma has a little over 175,000 miles on it. Runs like new except for a very minor slightly rough idle every now and then. Considering the mileage some get with the 2.7 I really don't consider mine a "high mileage" Tacoma. It's had mostly highway miles and a lot of very mild off-roading it's entire life. It's had 4 batteries (the first under warranty), 1 water pump under warranty, outer tie-rods, rack bushings, all new Old Man Emu suspension except for Deaver J-59 leaves in the rear.
    That's it in well over 175,000 miles with nothing but routine maintenance such as oil, gear box and spark plug changes etc. It's only had three sets of tires in that time as well and one brake job back at around 60,000 miles. Those brakes are still good at over 175,000 miles but I'm preparing for a complete brake job in the future. Not bad at all.
  12. Aug 22, 2018 at 10:28 AM
    #52
    Vrbas
    Vrbas Well-Known Member
    2013 4x4 DCSB 6speed
    2011 5-speed manual 2wd, sitting at 104k. Drive it conservatively, rarely gun it. Brake well in advance of stop lights. Here's my list:
    - Just did front brakes (pads were almost completely gone) - paid too much and probably was overcharged
    - About to put new tires on (2nd set after factory Dunflops)
    - Mobil 1 0w20 every 5-7k miles
    - Self installed a tow hitch early in its life
    - On my 2nd battery
    - K&N air filter, 2nd airbox delete
    - Seafoamed at 100k (brake booster and fuel)
    - Drained radiator (not block) and replaced w/ genuine Toyota pink @ 100k
    - Tow a jet ski a couple times a month, almost no offroading
    - 24 to 27mpg (235/70/15 Firestone Destination LE2's), 75%hwy 25%cty
    Only complaint is musty AC smell from time to time at season changes, been recently spraying Lysol into the fan under the cabin air filter and it seems to help. Front headlamps are starting to yellow a bit.
  13. Aug 23, 2018 at 9:17 AM
    #53
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    2009 4banger 5speed access cab
  14. Aug 24, 2018 at 11:34 AM
    #54
    Tacotruck7
    SoCal
    I'm about to hit 200k.
    I've already done in the past 25k:
    Rear Diff fluid change
    PCV Valve
    Valve Cover Gasket
    Timing Chain Cover Gasket
    Spark Plugs
    Coil Boots and Springs
    Coil Gaskets
    What I'm thinking I need to do:
    Oil Change (always every 3k)
    Air Filter
    Transmission Fluid and Filter
    Anything else that needs to be done around 200k? Fuel Filter Maybe? That's just a pain to get to.
  15. Aug 28, 2018 at 1:17 PM
    #55
    DGXR
    Friend
    Sacramento, CA
    Bleed the brakes if not done in the last 3 years. Change coolant (book says first service at 100k, then every 50k thereafter). Inspect and/or replace the shocks/struts... same for the U-joints. Change (or at least refresh) the power steering fluid. Also cabin air filter but that's one of those as needed/YMMV things.
  16. Aug 28, 2018 at 4:02 PM
    #56
    Vrbas
    He said going about 90mph... damn that's a steady hand son.
  17. Aug 29, 2018 at 12:53 PM
    #57
    Tacotruck7
    SoCal
    I don't have a cabin filter so I'm good there. Brakes have been done I forgot to add. I can do the coolant. The truck got a whole new OME suspension 20K ago as well.
  18. Aug 29, 2018 at 1:06 PM
    #58
    BassAckwards
    Had some help taking it! But really only like 75mph. My 4.88s make my speedo show faster than actual
  19. Nov 12, 2018 at 6:48 PM
    #59
    Fast1
    Fast1 Well-Known Member
    Minneapolis, MN
    2021 TRD Off-Road Access Cab
    Just turned 180,000. 06 4x4 manual SR5 with buckets. (pics taken within the last month)
    Front brakes at 140K
    Front wheel bearings at 150k Drivers and 175K pass
    one new battery
    Alternator (used from a salvage yard) and serpentine belt at 173K
    Drivers Rear axle seal and rear brakes at 165K
    Mobile 1 syn every 5K
    Drive-line and radiator fluid changes per service spec
    Plugs and air filter per service spec
    Engine runs like new, transmission and clutch are perfect
    Rear leafs replaced under TSB
    OME Front / Rear shocks and coils
    I'd buy the exact same vehicle new tomorrow with zero miles if they still sold them.
    Summer Mode
    Winter mode with snow tires and just added a ARE MX topper
    The last 2.7 MY99 I had was purchased back by Toyota at 200K due to frame rail rust.
    Bullet proof truck IMO.
  20. Nov 12, 2018 at 7:13 PM
    #60
    Bamagrad2002
    Bamagrad2002 Well-Known Member
    Jeff
    Hayden, Alabama
    2007 prerunner
    Stock
    My 2007 SR5 Prerunner has 194000 on it and just had to replace bypass pipe...no fun..!!!! Replaced clutch, water pump and both front spindles last couple years..mobile 1 keeps engine running smooth..!!!
