High Mileage Tacoma's
Discussion in '4 Cylinder' started by dcous, Oct 19, 2015.
  1. Feb 16, 2020 at 4:38 PM
    #81
    95.jfranco
    95.jfranco New Member
    2007 Toyota Tacoma 4X4
    260K on my 2007 and still going strong, never had any problems with engine or transmission! Best truck money can buy.
    EdgemanVA likes this.
  2. Feb 17, 2020 at 2:21 AM
    #82
    JPinFL
    JPinFL Well-Known Member
    '01 Tacoma Xtra Cab 4x4
    Nice.
    If I remember correctly, mine went to 265k.
  3. Feb 17, 2020 at 4:11 AM
    #83
    Timothy Quinn
    Timothy Quinn Well-Known Member
    2001 TRD OFFROAD SR5 and 2018 TRD OFFROAD
    Yes, I have a 37 mile commute one way to work and about 10 of those miles are interstate. Even with the miles it has on it the 2.7 4 banger still get 19-20 mpg with the 265/75/16 Generals which are 54 lb. each, but I am on the East coast in NC so it is flat land not hill and mountain country.
  4. Feb 17, 2020 at 4:28 PM
    #84
    Tacotruck7
    Tacotruck7 Well-Known Member
    SoCal
    04 Prerunner Dbl Cab 2.7L
    That sounds pretty good. My truck gets about the same. 20-21mpg freeway. 17 city. Not bad.
  5. Apr 5, 2020 at 1:45 AM
    #85
    BananaMan
    BananaMan Well-Known Member
    Bumfrick nowhere Maine
    06 2.7 RC 2wd manual "squattytruck"
    250k miles on my 09 automatic 2wd, bought it with 200k for $600. It sees full throttle through every gear every day at lest twice. Burns a quart of oil every 600 miles, so I've got a spare engine I'm prepping for boost. As far as I'm concerned, keep oil in it and I'll keep driving it for another 50k at least.
  6. Dec 25, 2020 at 8:43 AM
    #86
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
  7. Dec 25, 2020 at 8:48 AM
    #87
    george3
    New Jersey
    I'm curious - you guys burning oil- what was you previous maintenance schedule leading up to burning oil ? OCI ? Type of oil used ? Filter used ? Did you own from new or buy used not knowing for sure of OCI by previous owner. I now have 130K OCI 5K fully synthetic . Thanks for any information and all replies.
    DGXR likes this.
  8. Dec 25, 2020 at 9:11 AM
    #88
    BananaMan
    Mine was an ex fleet truck from a security company, which I bought with 210k on the clock. So who knows what their maintenance was like. After realizing how much oil it was using, I was running stp basic 5w30 non Synthetic due to the price. Changed the oil and filter at 5k and used the stp "gold" filter.
  9. Dec 25, 2020 at 10:12 AM
    #89
    george3
    New Jersey
    ir
    Thanks for the reply confirming what I thought - you do the correct maintenance but the security company probably did not. Merry Christmas if possible.
    BananaMan[QUOTED] likes this.
  10. Dec 28, 2020 at 4:33 AM
    #90
    Noza
    Noza Active Member
    I have a 2008 Tacoma base model with 202k miles! Runs like a charm.
  11. Dec 28, 2020 at 11:18 AM
    #91
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    Yeah I think part of the issue with oil burning is stuck / carboned piston rings. It's not necessarily engine wear. I think running synthetic oil will help prevent this problem since it is better at tolerating the high temperatures seen on the piston and rings/lands. But if you're already burning a lot of oil, I don't think there is a lot you can do. I recently read a thread on another forum about a guy with a Lexus burning 1 quart every 700 miles -- he says the rings were stuck with carbon deposits. He added Seafoam to the engine oil and fuel, and did a series of short oil change services (all with Seafoam in the oil). The oil got dirty very quickly between each service. In the end, oil consumption dropped dramatically, to 1 quart every 3000 miles IIRC. I'm not advocating the use of any additives, just relaying a related story.
    BananaMan likes this.
  12. Dec 28, 2020 at 11:25 AM
    #92
    BananaMan
    I recall seeing quite a few posts on here at some point pointing the finger at the oil control ring specifically, I tried every additive/oil treatment/fuel treatment I could find and never got mine to improve.
  13. Dec 28, 2020 at 12:25 PM
    #93
    Fast1
    Fast1 Well-Known Member
    Minneapolis, MN
    2021 TRD Off-Road Access Cab
  14. Dec 28, 2020 at 1:26 PM
    #94
    george3
    New Jersey
    I use Techron B 4 every oil change - synthetic oil OCI 5k 130K Hope it works.
  15. Dec 28, 2020 at 1:38 PM
    #95
    Boco10
    Boco10 Well-Known Member
    ADK
    My old 2001 went 429k before I hit a herd of deer. Best truck ever. Rear brakes went untouched till 200k. Frame replaced at 300k. Castrol synthetic every 5k.
  16. Dec 28, 2020 at 1:44 PM
    #96
    george3
    New Jersey
    IMPRESSIVE ! I Think the rings on the older Tacoma's were better - they made them weaker to meet some EPA BS so oil get by them.
  17. Dec 28, 2020 at 1:52 PM
    #97
    Boco10
    ADK
    I also changed the plugs on the reg. Other then that I beat the crap out of it. I am at 240k on my 14. I spent all summer doing maintenance and upgrading the suspension. Drives better then new. Frame is on wait list to be scaled. Then I plan on doing a frame restoration and repaint.
  18. Dec 28, 2020 at 4:50 PM
    #98
    george3
    New Jersey
    So much for my thought since you have 14.
  19. Dec 28, 2020 at 4:58 PM
    #99
    Boco10
    ADK
    My first post was my 2001 with 429k. My 14 is just getting broken in. I plan on keeping it awhile so its really just about keeping it lubricated and maintaining the frame.
  20. Dec 28, 2020 at 5:45 PM
    #100
    george3
    New Jersey
    Since U R replying I'd like to ask How do you put so many miles on ? I only drive 9 miles to work so 50 miles or so to work a week plus some odds and ends.
