High Pitch Noise coming from windshield
Discussion in '2nd Gen. Tacomas (2005-2015)' started by photosbyrex, Dec 14, 2010.
  1. Dec 14, 2010 at 1:49 PM
    photosbyrex
    photosbyrex [OP] New Member
    Baltimore
    07 Tacoma 4x4
    Whenever I go 70mph or more on a really windy day there is a really high pitch noise that comes from the windsheild. I was told by the dealer that it was bad wipers but the problem persists now for 2 years. Another 07 owner told me he had the same problem. I suspect it is a bad windsheild seal. Any suggestion? I have a 07 dbl cab shortbed.
  2. Dec 14, 2010 at 1:52 PM
    Hunter500ky
    Hunter500ky Well-Known Member
    E-Town Ky
    06 Tacoma 4x4 SR5
    Weathertech Mats, Toolbox, 6k HID fogs, Hardwire Escort 8500 x50,
  3. Dec 14, 2010 at 1:59 PM
    roadking1
    roadking1 Well-Known Member
    n.j.
    2023 Solar Octane TrdPro 6-speed manual
    I had it fixed on my 2005..The dealership did a really sloppy job on it.they put silicone under the windshield molding.It did take care of the noise.There is a TSB on this known problem.
  4. Dec 14, 2010 at 2:02 PM
    bowstoy
    bowstoy New Member
    harry
    okeana ohio
    05 tacoma
    mine does the same thing i have an 05 reg cab i changed wipers still did it i sealed windshield still did it but i did notice that when you sprayed the windsheild washer it would quit until it dried
  5. Dec 14, 2010 at 2:11 PM
    Hunter500ky
    E-Town Ky
    06 Tacoma 4x4 SR5
    +1 everytime from now on, when I hear a new sound just going to crank the radio.
  6. Dec 14, 2010 at 2:21 PM
    ::childstoy::
    ::childstoy:: Hi-Tech Rednek
    Southeast, PA
    Black 2010 TRD Sport
    TRD Exhaust, Tint, Stubby Ant., Debadged, Weathertech Mats, Grillcraft... Currently collecting donations for a New Tires Fund.
    Friend of mine had an 05 that the windshield seal started to go and he would only notice it at 65mph+. He had to have his windshield reseated.
  7. Dec 14, 2010 at 2:38 PM
    Ferg350
    Ferg350 Member
    Mississippi
    2010 Sliver TRD-OR 4x4
    5100s set at 2.5, 2" Toytec AAL, Nitto Tera Grapplers
    My 2010 DC did the same thing and i had to have a new windshield. Since the new windshield it doesn't make a sound.
  8. Dec 14, 2010 at 2:57 PM
    WNYTACOMA
    WNYTACOMA Well-Known Member
    Clarence, New York
    09 Metalic Grey TRD OFF ROAD
    Toyota Nerf steps Bugflector 2 Tool box Weathertech floor liners Wet Okole F/R - Bk/Char
    The dealer replacing the lower corner exterior trim piece fixed mine. (Warranty item)
  9. Dec 14, 2010 at 3:12 PM
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    Ah yes, the old "reed" sound from the windshield. I was really glad to get a new windshield last year. Try taking I-5 at 75+ mph (speed limit is 75) and listen to that for 800 miles!!!!! I sure don't miss it.
    I attached the TSB in case it's easier to just look at it here.
  10. Dec 14, 2010 at 3:22 PM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear and all wheel bearings front /rear Yukon 3.73 ring/pinion rebuild Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 in 2024
    TSB NV006-07 fixes.
    Simply apply masking tape to the upper rubber windshield seal to roof (do not cover/tape over the glass) and see if that solves it. If not try the sides. The dealer usually calls a glass shop (if not under warranty go directly to a windshield glass shop) and they use a plastic pry tool to lift the windshield lip to body and apply sealer (look at it and it has none now and vibrates in the wind stream and different directions, crosswinds, etc cause it to vibrate or actually hum like a kazoo and it drives you crazy).
  11. Dec 14, 2010 at 4:15 PM
    uscg2008
    uscg2008 Well-Known Member
    coby
    San Diego, CA originally from Huntington Beach, CA
    06 trd sr5 four door 4x4
    CLICK ON SIGNATURE>>>>
    im having that same problem on my '06 when i hit 75-80 on the hwy. does anyone knw about how much it is to get this problem fixed?!?!?
  12. Dec 15, 2010 at 6:14 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    My 09 does the same, but it's only with a left to right crosswind. Haven't done anything about it yet though.
  13. Dec 16, 2010 at 5:25 AM
    photosbyrex
    Baltimore
    07 Tacoma 4x4
  14. Feb 12, 2011 at 8:04 PM
    rsbmg
    rsbmg Well-Known Member
    Rob
    Vista,CA
    2011 Tacoma Doublecab TRD Offroad
    Front Aluminum bumper by Relentless Fab. Smittybuilt Winch Complete set of skids by ATO TC UCA's Fox Ext. Travel Front Reservoirs.
    Going through this problem with my 2011. Dealer sent it to a glass shop for new sealant but that did not fix it. Since there is no tsb for the 2011 I have to go through a bit of a process but the dealer seems to be working with me at least at this point. It only has 900 miles on it so hopefully we get to the fix soon.
  15. Feb 12, 2011 at 10:28 PM
    island808
    island808 Me l've got brains.
    Jedediah
    hawaii
    '10 6speed 4x4 access cab
    Just be glad the days of chrome trim around the windshield has gone by. Everything used to buzz after a few years.
  16. Feb 13, 2011 at 7:16 AM
    Rocketball
    Rocketball If The World Didn't Suck, We'd All Fall Off
    Scott
    Westminster, MD
    08 Speedway Blue DC Sport 4x4
    Pioneer head unit, PAC steering wheel control modual, Hard wired Sirius radio, Hard wired radar detector, Hella Supertone horns, Blacked out badges, Smoked Tails, BHLM (color matched Speedway Blue), T-Rex Eyelids, Black Powder Coated Billet Grill, Color Matched Engine Cover, Lund in channel vent visors, FJ Cruiser wheels, Leer 100XQ shell, OEM bed mat, Piezo beeper for locking doors, Tinted front side windows, Black Westin bull bar, Aires tube steps, Mini Maglite Mod, D-Cell Maglite Mod, Weathertech Digifit Floor Mats
    Subed....
  17. Feb 13, 2011 at 8:37 PM
    rsbmg
    Rob
    Vista,CA
    I applied by own silicone today between the glass and the seal. Now I have to drive 115 before I can get any sort of noise. I have it narrowed down to a small space between the center of the windshield and the driver side edge. A bit more silicone and I should be good to go. I didnt want to keep screwing around at the dealership. 9-10 times I can figure things out and fix it myself saving me hours of driving the truck in an out of the dealership while they try to figure it out. Its to bad dealerships don't hire real mechanics that are able to diagnose and figure things out for themselves.
  18. Feb 14, 2011 at 4:13 PM
    Rocketball
    Scott
    Westminster, MD
    Has anyone had this done that is out of warranty?
    My 08 is doing this and I'm way over the 36,000 miles.
  19. Feb 14, 2011 at 4:16 PM
    rsbmg
    Rob
    Vista,CA
    You dont need a mechanic to put silicone on your window seal just go buys some at any auto parts store and apply it at the edge of the seal and the window its not difficult.
  20. Feb 14, 2011 at 5:23 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    I used to get a similar sound (sounds like interference when you put a cell phone next to speaker) above 80 mph. After I installed my All-Pro bumper, the sound disappeared. Maybe the distinctly unaerodynamic bumper changed the turbulence characteristics.
