High Pitch whistling noise?
Discussion in '1st Gen. Tacomas (1995-2004)' started by FalloutMaster, Jun 9, 2013.
  1. Jun 9, 2013 at 11:57 PM
    FalloutMaster
    FalloutMaster [OP] Well-Known Member
    Phoenix, AZ
    04 PreRunner TRD SR5
    Grillcraft insert, partial debadge, Toyota tailgate decal, Fog light mod, Anzo headlights, '98 tail lights
    Hey guys, so just today, 2nd day of owning truck, tonight actually, I started hearing this strange whistling noise coming from the front of the truck. It starts to fade in at 40mph and gets a bit louder at 46ish mph. I'm really worried since I just bought the truck that there might have been some unseen transmission problem. Drove great and sounded normal and quiet during the test drive. It seems louder when I have the windows down, actually it is much louder. Windows up I can barely hear it. Anyone have the same problem or know what it might be?
  2. Jun 10, 2013 at 5:36 AM
    magog45
    magog45 Well-Known Member
    Canada, just south of Santa
    98 tacoma 4x4 extended cab
    5100's all around, 2.75 inch lift, polyurethane body mounts, gibson exhaust, variation of the deckplate mod, intake resonators removed 285-75-16 goodyear AT
    I had a random whistling sound and it turned out to be a siezed caliper. Try gently applying the brakes when you hear it and if it stops that will at least narrow it down if it stops.
  3. Jun 10, 2013 at 6:01 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    wow yeah this can happen. went mudding once, then drove home. after 20
    or so miles on highway as my calipers dried up an insane screech and high
    pitch from the front. t'was dirt jammed in my front caliper pistons
    what kind of sound ? wind, mechanical ???
  4. Jun 10, 2013 at 11:13 PM
    FalloutMaster
    Phoenix, AZ
    Huh I will have to check that out. I also figured it might be wind noise too, maybe through a window seal. I'll check the brakes out for sure though.
    -Edit-@127.0.0.1 yeah it really sounds like wind to me but it is hard to say
  5. Jun 10, 2013 at 11:23 PM
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Ugh. Ok so if I remember correctly it's a small issue, something to do with the weatherstripping around the hood/grille. Apparently some of the trucks being pumped out have a little gap that causes a "whistling" noise.
    I say ugh because there was a thread some guy had brought up about this and said the dealer couldn't fix it, so he had a lemon, and wanted to sue Toyota about it.
  6. Jun 10, 2013 at 11:27 PM
    VolcomTacoma
    Jeff
    NorCal
    Oh, good call, my bad. No idea then :/, check the caliper thing. Stupid second gen owner.
  7. Jun 11, 2013 at 1:22 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    x10.......:p
  8. Jun 11, 2013 at 9:17 AM
    VolcomTacoma
    Jeff
    NorCal
  9. Jun 11, 2013 at 4:28 PM
    FalloutMaster
    Phoenix, AZ
    Alright so checked the brake caliper thing and nothin'. Still whistles when the brake is in at over 40mph. It really sounds like wind more than anything. The truck came with an ARE hard tonneau cover; could that be making the noise? Its possible the truck has been making the noise all along and I just never turned the radio down and listened until a day ago.
  10. Jun 11, 2013 at 5:27 PM
    tacomataco2
    tacomataco2 Well-Known Member
    Eastham Mass
    02 Dbl cab Silver
    Bilstein 5100's, eibach coils, u bolt flip, Dakars/d6xl, Ome shackles, Poly sway bar bush, Poly rack bush, voltmeter, led guage lights, magnaflow stainless catback, stainless cats, deckplate mod, afe filter, tundra brakes,PIAA fogs behind grillecraft, color matched grille, soft topper, Projector retrofit, Allpro bumper , Blitzpro light bars, Alpine/ rock fosgate sound system, 35% tint, Some derped stuff
    If its a whistling noise it's probably a gap somewhere on the body.. Mine makes it too but I don't care about it haha. Try masking tape over different seams until it goes away.
  11. Jun 17, 2013 at 7:12 AM
    REB
    REB Member
    Robert
    Virginia
    2013 PreRunner, SR5, DCLB
    I just picked up my new Tacoma on June 8. It also has a random whistling noise I haven't been able to track down.
  12. Jun 17, 2013 at 8:10 AM
    Taylor
    Taylor Wants to learn all about his Taco.
    Taylor
    Lynchburg/Harrisonburg Virginia
    03 4x4 TRD SR5 College build
    Extra badges, painted skidplates, grey wire mod, Kenwood double-DIN headunit, pioneer amp, 12 inch MTX sub, playstation 2 under seat, Uniden CB with 5 foot Wilson 1000 antenna, deckplate mod, 4xinnovations sliders, diff breather mod, bilstein 5100s at all 4 corners, OME Dakar Leaves, BAMF BPV bracket, Wheelers greasable shackles,
    I used a pressure washer to clean my truck about 2 weeks ago and I accidentally got too close to my cowl with it. My truck whistled for about 2 days and then went away. Check to see if there are any rocks or anything in the cowl that may cause the whistle.
  13. Jul 7, 2013 at 10:08 PM
    jspyke
    jspyke New Member
    la
    2013 4x4 sport DC
    tint, hid, snug top w/yakima
    Got the idea from another post but it worked. 1/4" poly tubing from Home Depot inserted in the top channel of all three hood/grill rubber seals stopped the noise for me. I had the exact same symptoms. This cure makes the hood slightly harder to shut but no more whistle, and that thing was annoying, especially for a brand new truck.
  14. Jul 7, 2013 at 11:46 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Wow first post & he did it right !! Welcome to TW....:)
  15. Jul 8, 2013 at 9:21 PM
    Clown Baby
    Clown Baby Well-Known Member
    Eric
    NorCal
    '00 prerunner
    Not sure if this is your issue, but my truck used to squeal like mad when I was coasting at higher speeds. Like a metal-on-metal squeal. Took it to three diff mechanics and they couldnt just figure it out. One of the guys just changed my brake pads.... I was almost at the point where I was just going to sell the truck.
    Turns out, I just needed to grease my zerks...... Solved the problem instantly... Not sure whens the last time you did it, but it might be worth a shot.
