High pitched "whirling" sound
Discussion in '1st Gen. Tacomas (1995-2004)' started by TacomaRyan15, Dec 16, 2019.
  1. Dec 16, 2019 at 11:30 AM
    TacomaRyan15
    TacomaRyan15 [OP] Well-Known Member
    2001 White Tacoma, Xtra Cab, 4x4, Auto, 4 cyl
    1. Toytec/Eibach 3 inch lift 2. Line-X truck bed 3. Line-X Fenders 4. Premium sound system 5. ARE Topper
    For the last year or so, I have been experiencing this crazy, "whirling" noise, coming from under the truck, right behind the cab. It is almost like a high pitched wind noise. Tough to describe.
    A couple things about it.
    1. Only happens when I press on the gas
    2. Generally only happens in morning or cold weather
    3. It doesn't seem like a mechanical noise (grinding, clunking)
    I have a sneaking suspicion it could be exhaust related, but I can't seem to pinpoint it. The truck runs fine and I don't have any real issues with it other than this.
    2001, SR5, Xtra Cab, 2.7 auto, 4x4, 190k miles.
  2. Dec 16, 2019 at 11:45 AM
    CD20H
    CD20H Well-Known Member
    Ben
    North Texas
    2004 Double Cab TRD 4x4 Limited
    Magnuson Kompressor, OME lift kit, JBA Headers, junky Sony radio.
    You have a vacuum leak somewhere.
    OneWheelPeel likes this.
  3. Dec 16, 2019 at 11:46 AM
    OneWheelPeel
    OneWheelPeel Well-Known Member
    Phoenix, AZ
    Carrier Bearing
  4. Dec 16, 2019 at 12:42 PM
    TacomaRyan15
    What would be the best way to confirm/diagnose? It does not come from the engine area. It is distinctly somewhere behind the cab.
  5. Dec 16, 2019 at 12:58 PM
    OneWheelPeel
    Phoenix, AZ
    There are plenty of "Vaccum Lines" behind the cab, just sayin.
  6. Dec 16, 2019 at 1:16 PM
    TacomaRyan15
    What would be the best way to diagnose?
  7. Dec 16, 2019 at 1:20 PM
    Martian__
    Martian__ Well-Known Member
    Southern California
    I’m with the carrier bearing. Very common. U can lift the truck on jacks stands. Put it in drive with the wheels off the ground obviously...get underneath and listen around the carrier bearing area. Might need someone inside to give it a little gas or slowly push the brakes. Be careful not to slam on the brakes when slowing down.
  8. Dec 16, 2019 at 1:57 PM
    CD20H
    Ben
    North Texas
    Get a couple of cans of carb cleaner. Put on the straw. With the engine running, spray all 1/4 and 3/8 vacuum hoses. Listen for the engine RPMs to change. RPMs that go up or down when you spray a particular hose.......investigate further.
  9. Dec 17, 2019 at 9:24 AM
    OneWheelPeel
    Phoenix, AZ
  10. Dec 17, 2019 at 9:29 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    A crazy friend with a walkie talkie.
