High RPM Misfire
Discussion in 'Technical Chat' started by jmtrap, Nov 2, 2007.
  1. Nov 2, 2007 at 10:49 PM
    jmtrap
    jmtrap [OP] Member
    My 99 (4x4, Automatic, 5VZFE engine)Tacoma has developed a misfire at high RPM that limits it to about 4300 RFP. It ONLY happens when the engine is warm and occurs under any engine loading condition (in Park, pulling a load, going downhill with no load, etc). There are NO engine codes. I have changed the plugs, plug wires, coils, PCV valve, fuel filter, air filter, gas types, etc. The dealers have NOT been able to isolate the problem and found no problems with fuel pressure. They offered to "experiment" by replacing the computer, fuel pump, or "other" components. I don't want to pay for anyh more of their play time. When cold the engine will rev to red line with no problem but once warm it misfires. I have even exchanged the plugs, coils, etc with another 5VZFE engine and mine continues to misfire with the "new" parts while the other engine functions properly with my "suspect" parts. Any suggestions????
  2. Nov 3, 2007 at 3:34 AM
    AUDITECH
    AUDITECH Carolina Alliance: LAZY DIVISION
    charlotte nc
    07 double cab prerunner
    none
    Do you have points and have you checked under the distributor cap lately. What is the milage on the 2 trucks is it close to the same.
  3. Nov 3, 2007 at 6:54 AM
    jmtrap
    jmtrap [OP] Member
    No points, no distributor cap. Both engines have about the same mileage.
  4. Nov 3, 2007 at 1:50 PM
    AUDITECH
    charlotte nc
    none
    you want to make this hard. Have you checked to see if its from one cylinder or random cylinders.
    Check your injectors might be dirty
  5. Nov 4, 2007 at 1:07 AM
    jmtrap
    jmtrap [OP] Member
    Cannot isolate the problem to a single cylinder. Disabled each one in sequence by disconnecting plug wire/coil connector. No clear difference in the overall performance in any once cylinder (of course, the engine ran badly with a plug disconnected). The dealers' computers could not isolate it to a single cylinder either. They did confirm that fuel pressure remainded adequate (don't remember the figures) when the problem occurred. I would think a clogged injector would perform about the same whether warm or cold. By "warm" I mean the engine has to run at least 10 minutes at highway speeds before the "miss" occurs. Thanks for the suggestion....other ideas?
  6. Nov 4, 2007 at 6:42 PM
    AUDITECH
    charlotte nc
    none
    How old is your cat and is it getting very hot. If its getting very hot it could be getting pluged up could be causing issues when its getting hot. The o2 sensors reading the exhaust wrong but i think that would set a check engin light. Have you gotten any codes read yet cause with the miss fire it should set a check engine light
  7. Nov 4, 2007 at 10:00 PM
    jmtrap
    jmtrap [OP] Member
    I can't tell the difference in the temperature of the cats in the two trucks (the one that is misfiring and the one that runs normally). I will see if I can find a way to measure them. There are NO engine codes. I had two dealer repair shops check when they were "experimenting" with repairs. There were no codes either before the misfires happened (while the engine was cold) and after the misfires (once it warmed up). Thanks again for the suggestions. I will work the cat temp now........
  8. Nov 4, 2007 at 10:10 PM
    pivitol
    pivitol Well-Known Member
    Colorado
    99 SR5 TRD Off-Road V-6 4WD de-flapped
    What brand of plugs did you put in?
  9. Nov 5, 2007 at 11:27 AM
    jmtrap
    jmtrap [OP] Member
    Currently using Denso but have tried NGK and others.....no change. I pulled nearly new Denso plugs for a similar engine with no problems and put my "suspect" plugs (and wires, and coils, etc) on the "good" engine. The result was that mine still missed at high RPM and the other engine with "suspect" parts ran fine. Beginning to think it is the ECU but need to do more work to check that out. Thanks for the suggestion......
  10. Nov 8, 2007 at 2:32 AM
    AUDITECH
    charlotte nc
    none
    yea you might want to swap ecu that would help with ut spending 1500 bucks for a new one you dont need
  11. Nov 8, 2007 at 11:38 AM
    jmtrap
    jmtrap [OP] Member
    Thanks AudiTech. Will do the ECU swap and check the cat temp. My company sent me to the Middle East for a couple of weeks so my troubleshooting has been put on hold until I return. The folks on this forum have been very helpful. Will update when I get back to the States.......
  12. Nov 11, 2007 at 3:01 AM
    AUDITECH
    charlotte nc
    none
    be safe
  13. Feb 28, 2013 at 11:17 PM
    ob3135
    ob3135 Member
    Alaska
    2002 Tacomma Pre-runner V6 Automatic
    None
    JMtrap. sorry to resurect a old post. But man I am banging my head on the wall. I have changed everything under the sun and still a high rpm miss. Bout to pull my hair out... So, did you ever find a solution? I have the exact same dang problem and am to a point of having to buy a new computer just to try it but wont be able to send it back :-(
    Any ideas?
  14. Feb 28, 2013 at 11:23 PM
    MGMTacolover55
    MGMTacolover55 Well-Known Member
    Orygun
    2013 MGM Taco TRD Off Road
    floor Mats
    Unfortunately he has not been in 5 years going on 6 now sorry dude
  15. Mar 1, 2013 at 6:20 AM
    jmtrap
    jmtrap [OP] Member
    Just getting back from 5 years in Saudi Arabia. Truck survived being stored that long. My misfire turned out do be a crack in a vacuum line. Sorry I don't remember just which one it was. $2 worth of rubber hose ended the problem!
  16. Mar 1, 2013 at 8:37 AM
    Vstrom30
    Vstrom30 Well-Known Member
    Midwest
    Tacoma Access Cab 4x4
    Lol, thanks for coming back and verifying the repair!
  17. Mar 11, 2013 at 3:37 AM
    ob3135
    ob3135 Member
    Alaska
    None
    WOW, Thanks for coming back. Well I'm well over a thousand$$$ now... :mad::mad::mad::mad::mad::mad:
    So, maybe I'm crazy but I was thinking a vaccum issue would become less of a problem at higher RPMs so I've somewhat ignored it... Am I nuts? I thought you'd see the vaccum issues at the lower RPMS???
    I'm bout ready to set it on fire :confused::confused::confused::confused:
  18. Mar 14, 2013 at 6:35 AM
    BamaToy1997
    Bill
    Navarre, FL
    Check all the vacuum hoses as he mentioned, just to be safe. After that the way we always zoned in on a potential cylinder was to use a scope and check the Kv on the coil wires. If memory serves me correctly, the 5VZ uses a waste spark system, so you should be able to narrow down the misfiring cylinder IF it has anything to do with spark. Once you rule that as the failure or still good, then you can go from there. I have seen poor grounds cause some strange things like you have mentioned as well.
