High temp spray paint for exhaust?
Discussion in 'Technical Chat' started by MHARMS, Oct 19, 2017.
  1. Oct 19, 2017 at 7:13 PM
    MHARMS
    MHARMS [OP] Well-Known Member
    2014 Black Tacoma TRD sport DCLB
    GoRhino Dominator D2 nerf bars, K&N air filter, LED cabin lights, Neoprene seats, Billstein 5100 front shocks 2.5" lift, ultra crusher 17” wheels w/ko2s, DIY tinted tail lights, LED reverse lights, CONDENSATE DRAIN HOSE EXTENTION!
    Thoughts on spray painting exhaust? Is it worth the effort? I spray fluid film on everything else so my exhaust is really the only thing rusting.
    GQ7227 likes this.
  2. Oct 19, 2017 at 7:19 PM
    panardo
    panardo Well-Known Member
    Taco 2000 4x4 V6 manual w/RDlock
  3. Oct 19, 2017 at 7:22 PM
    whalers25
    whalers25 Well-Known Member
    brett
    Virginia Beach
    2007 Red TRD OR
    I've always wondered about this.
  4. Oct 19, 2017 at 7:23 PM
    MHARMS
    It’s a rust/corrosion preventative film that stays wet until you wash it off. Sprayed it everywhere under the truck giving extra attention to the frame and leaf springs. If you spray it on the exhaust, it will burn off slowly and it’s pretty stinky, but not harmful.
    GQ7227 likes this.
  5. Oct 19, 2017 at 7:24 PM
    757yotas
    757yotas Well-Known Member
    Virginia
    2007 TRD Sport
    ICI Magnum front bumer Rigid LED lighting OME lift 285/70 Nitto Exos 17" Fuel Hostage TRD Exhaust TonnauPro Cover Oil Catch Can Tint Pioneer Nav system Sound System LED lighting Euro headlights Paint
    I do it with rusoleum clear high heat engine paint. Only do clear cuz i have a SS TRD Exhaust that i dont want black lol
    GQ7227 and MHARMS[OP] like this.
  6. Oct 19, 2017 at 7:27 PM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    You can paint your exhaust but I personally would not. Just replace it when the rust eats a hole. Painting it will increase temperature because the painted metal cannot radiate heat out as easily
  7. Oct 19, 2017 at 7:30 PM
    757yotas
    Virginia
    2007 TRD Sport
    Never heard anyone complain of this. Seems like a load of BS to me...engine paint is made more hight heat and engine parts. If it can take header heat im sure a cat back will be fine to.
    Canufixit and badkids like this.
  8. Oct 19, 2017 at 7:31 PM
    Toyoland66
    Toyoland66 Well-Known Member
    Colorado
    09 GX470
    Mostly stock on 35s
    That's fine, the heat should be going out the tailpipe not radiating all over your undercarriage.
    VHT makes header paint, that's what I used on the header and exhaust in my FJ40, but it's garaged and I don't put a lot of miles on it so not sure about durability.
    MHARMS[OP] likes this.
  9. Oct 23, 2017 at 9:13 AM
    stump jumper
    stump jumper Well-Known Member
    Bill
    Texas
    2017 Tundra 4x4 CM TSS
    Don't need high temp for tail pipes. I did my tail pipes in regular flat black. I was after appearance not rust protection. I wanted pipes to match tips.
    Cooldood and GQ7227 like this.
  10. Oct 23, 2017 at 9:22 AM
    Clearwater Bill
    Billy
    Largo Florida
    Do you have some infrared readings of painted vs unpainted you can share to demonstrate this?
    Obviously same pre-reading driving conditions and point of reading on the exhaust are required.
    ChemDawg likes this.
  11. Oct 23, 2017 at 9:30 AM
    zh137dz
    zh137dz Well-Known Member
    Nashville, TN
    2012 Tacoma Prerunner TRD Sport
    too many lights
  12. Oct 23, 2017 at 9:32 AM
    zh137dz
    Nashville, TN
    too many lights
    This isn't true, and even if it were possible for rattle can paint to "suffocate" radiant heat this would actually be the preferred outcome in an exhaust situation so the heat is directed outboard and not into the bottom of your truck.
    GQ7227 and ChemDawg like this.
  13. Jan 15, 2020 at 12:49 PM
    lorsteez
    lorsteez P-Town Resident (415|707)
    Northern CA
    2019 DCLB OR- Cement
    Fox 2.0 Coilovers|Fox 2.0 Rear Reservoir Shocks | Icon 1.5 AAL w/Overload | Method 305 NV 16 X 8 | Falken Wildpeaks 267/76/16 | | Diode Dynamics SS3 LED Fogs | SR Grille Surround
    Thinking about doing this soon. Have some Rust-Oleum high temp black spray paint I can use
    Anyone who’s done this- How’s it holding up after a few years?
    GQ7227 likes this.
  14. Jan 15, 2020 at 1:14 PM
    MHARMS
    I ended up doing it a couple years ago. I used VHT high heat. Did everything the manufacturer recommended and it still ended up beginning to peel off about a year later. I honestly wouldn’t try it again, but maybe you’ll have better luck with rustoleum. I’ll post pics today or tomorrow of the current state
  15. Jan 15, 2020 at 1:35 PM
    lorsteez
    Northern CA
    Awesome, much appreciated!
  16. Jan 15, 2020 at 2:43 PM
    MHARMS
    I guess it’s more so wearing off rather than peeling.
    GQ7227 likes this.
  17. Jan 15, 2020 at 2:53 PM
    badkids
    badkids Well-Known Member
    ‘83 Hilux with a 2JZ
    thank you man! I just ran out and cut all that exhaust wrapping off my motorcycle. now my pipes can breath!!
    TomHGZ and Bydand like this.
  18. Jan 18, 2020 at 2:27 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    The thermal cycling causes the paint to fail after a period of time.
    I have never seen any last very long .
    If this is something you don`t mind doing every few weeks go for it .
    The stove paint works on stoves because for the most the stove stays hot through the season redo next year before start up.
  19. Apr 29, 2020 at 7:12 PM
    Stormpeacock
    Stormpeacock IG: @storm.peacock
    Rich
    Atlanta, GA
    19 Cement Offroad
    MCB Elite Performance Tuned 5.29 Differential Gearing 35" Kenda M/T on Steelies SOS Bumpers, Skids, and Sliders Ranch Camper Shell
    Used Rust-Oleum high temp, the 2000F one today..
    We'll see how it holds up!
  20. Apr 30, 2020 at 1:37 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    Looking forward to a progress report in a few months.
    GQ7227 and Island Cruiser like this.
