High Transmission fluid temperature, wtf just happened
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 50ShadesOfTaco, Apr 27, 2021.
  1. Jan 18, 2023 at 4:45 PM
    prerecordedlive
    prerecordedlive New Member
    2016 White Tacoma SR5
    Nope. My only aftermarket part is a head unit and I haven’t toyed with the fuse box.
    I’m reading up on the crank position sensor recall that I took it in for in October. I did that proactively without experiencing any of the telltale signs, but what I’m reading about seems to be everything I’m experiencing now.
  2. Jan 18, 2023 at 6:40 PM
    rzathagza
    rzathagza Active Member
    Simon
    2017 Tacoma TRD
    shiiittt
    What a nightmare, good luck man. Keep us posted
  3. Jan 19, 2023 at 12:23 PM
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    from the service manual:
    i would clean the connections on your battery and replace the ETCS fuse. fuses can go bad even when they look fine and dirty battery connections can cause all sorts of weird electrical issues. make sure it's the correct fuse.
    bulalo likes this.
