Highlander Steering Wheel Swap 2nd Gen?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DistortedAxis, Nov 15, 2016.
  1. Nov 15, 2016 at 6:41 PM
    DistortedAxis
    DistortedAxis [OP] Well-Known Member
    Toronto
    Desert Sand Mica, 2006, V6, 6SPD Manual, SR5, DCSB, 4X4
    STOCK
    Has anyone swamped a steering wheel over from a Highlander into a Tacoma?
    The base wheel and clock spring are the same from Tacoma / Highlander according to part numbers.
    Looking at part numbers, the main difference being the covers, switches and airbags.
    Just wondering if anyone has tried this?
  2. Nov 17, 2016 at 9:53 PM
    duvinclunk
    duvinclunk Well-Known Member
    Davin
    Salt Lake City, UT
    2016 DCSB|OR|QS
    Not a fan of that wheel particularly but have always wondered if this would work for the newer Tacoma wheel.
  3. Nov 17, 2016 at 10:41 PM
    TacomaTrav
    TacomaTrav Well-Known Member
    Travis
    07' Tacoma SR5, 4.0L 6spd, ELocker
    NONE
    My main concern would be airbag compatibility and function, pretty sure you could get the controls to work.
  4. Nov 17, 2016 at 11:06 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Interesting. Personally. I hate the late gen 2nd gen steering wheel myself. It's good to have some options and this could always be a pretty viable solution for the future if it actually does work!
    bluezzy likes this.
  5. Nov 18, 2016 at 7:39 AM
    duvinclunk
    Davin
    Salt Lake City, UT
    2016 DCSB|OR|QS
    Agreed. I'd assume all Toyota airbags have them same connector and wonder if it would function normally once plugged in...
  6. Nov 18, 2016 at 11:57 AM
    rossk35
    rossk35 Do Work Son!
    hawaii
    07 TRD Sport Supercharged
    TRD S/C/TRD Intake/TRD Boost Gauge/DT Headers/OEM TL/ZKW retro/Pioneer DVD w/Ipod/Magnaflow/20% Tint/BHLM/JL 10" sub, JL VR components, JL 450/4 amp/Helwig Sway bar/Viper 791/ 18" limited 4runner rims
    I have a 13 camry se steering wheel in my truck. My truck didn't have steering wheel controls to begin with before so I didn't care to swap clock springs, and re-pin the wires. Its such a nicer wheel. Airbag is plug and play.
  7. Nov 18, 2016 at 12:12 PM
    orezona
    orezona title unspecified
    satan's skillet
    2006 TRD OR DCSB OMGWTFBBQ TL;DR
    WARRANTY VOIDED
    ^^^ Did you go to a salvage yard to get that? Looks pretty nice.
    12TRDTacoma likes this.
  8. Nov 18, 2016 at 12:15 PM
    rossk35
    hawaii
    Got both on ebay from 2 different sellers. I think I paid $300 so not to bad. I also added a leather wheel cover afterwards. It made the wheel a bit thicker which I liked.
  9. Nov 18, 2016 at 12:33 PM
    duvinclunk
    Davin
    Salt Lake City, UT
    2016 DCSB|OR|QS
    Woah, nice. The horn works fine?
  10. Nov 18, 2016 at 12:38 PM
    Shwaa
    Shwaa Well-Known Member
    Bay Area, CA
    '13 DC Prerunner TRD Off-Road
    What don't you guys like about your 2nd Gen steering wheel? I think it's kinda nice, far better than the steering wheel on my Matrix previously.
  11. Nov 18, 2016 at 12:39 PM
    duvinclunk
    Davin
    Salt Lake City, UT
    2016 DCSB|OR|QS
    The second generation has two different wheels. The early second gen and the late gen. The late gen's wheel is great. The early gen's wheel feels like a Corolla wheel from the early 2000's.
    ExplorHer likes this.
  12. Nov 18, 2016 at 12:40 PM
    Shwaa
    Bay Area, CA
    Ahh gotcha. Now that you mention it I do know what you are referring to. Yea, not as nice as the later 2nd Gen's
  13. Nov 18, 2016 at 12:54 PM
    orezona
    satan's skillet
    WARRANTY VOIDED
    Did you get one of those leather sew-it-yourself kits, then? Looks factory so you did a great job!
    Surprised you were able to get the wheel with the airbag intact. I thought you couldn't do that for some reason. Whole, "exploding components" issue and all that...
  14. Nov 18, 2016 at 1:36 PM
    oneworden
    oneworden Active Member
    Joe
    Wauwatosa, WI
    2015 DCSB TRD Sport 4WD Mag Gray
    None yet
    I had a 2012 Camry SE before the truck and would kill for that wheel again. Everything was in the right place.
    I am not a fan of the wifes steering wheel in her Highlander, but she says its fine.
  15. Nov 18, 2016 at 1:37 PM
    oneworden
    Joe
    Wauwatosa, WI
    None yet
    What do you have the paddles hooked up to?
  16. Nov 18, 2016 at 1:40 PM
    orezona
    satan's skillet
    WARRANTY VOIDED
    Ejection seat would be my guess.
  17. Nov 18, 2016 at 1:41 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    If it were me I would see what I could do about utilizing them as "kill switches."
  18. Nov 18, 2016 at 1:41 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Holy shit. :O I just found a new project!!
  19. Nov 18, 2016 at 2:31 PM
    rossk35
    hawaii
    I got the cover from aliexpress.com Comes from china. I put the cover on about 6 months ago, and so far its holding up great. The wheel has been installed since January of 2015. It goes over the existing leather with double stick tape to hold in place then just stitch it up. In that pic the area around the 9 and 6 grip lifted up and have since fixed that, so its smooth now.
    None of the buttons work only because I didn't want to change the clock spring. Cruise and horn are fine. Plus I would also have to get the harness to work with my aftermarket deck which I wasn't about to do. I just really like the way this wheel looks and feels which was why I swapped it.
    If someone with a newer truck that already had wheel controls it would be easy to make them work. You would have to swap connectors and re pin the wires, but its doable.
  20. Nov 18, 2016 at 6:11 PM
    DistortedAxis
    Toronto
    STOCK
    I looked at the Camry wheels and was very close to pulling the trigger because the Type S models have a flat bottom race style wheel. That flat bottom would really help with the leg room for a Sasquatch like myself when getting in and out of the truck!
    I do plan to make the steering wheel controls work on this one pin at a time, the slow painful way.
