Hodakaguy's Overland Tacoma Builds - on to new adventures.
Discussion in '3rd Gen. Builds (2016-2023)' started by Hodakaguy, Jan 12, 2018.
  1. Jun 15, 2019 at 9:38 PM
    #321
    Nu2taco
    Nu2taco Well-Known Member
    J
    San Diego, CA
    2018 DCTRDOR4X4 AT
    I like how you moved yours a little to the right. I followed @p3coyote so i only had to drill 2 new holes. That works for me because I didnt want to experiment and only mess up. The tire was hugging the left side more so I have to push it to the right while I had my son crank the lift. No big deal I just love that I have my bed space back
    pc3coyote likes this.
  2. Feb 3, 2020 at 9:45 PM
    #322
    duvinclunk
    duvinclunk Well-Known Member
    Davin
    Salt Lake City, UT
    2016 DCSB|OR|QS
    Best build on the forum...even though the ADV one is more complete.
  3. Mar 9, 2020 at 1:46 AM
    #323
    Amanhowzit taco
    Amanhowzit taco Well-Known Member
    Adam
    Hawaii
    2017 sr5 4wd Tacoma
    265/75/16 tires only everything else stock.
    Can I pay you to telemechanic help me install the bp-51 system by my self? I’m in Hawaii. I have a friend that knows more then I do but not as much as you know. No one has this kit
    Here that I know of.
  4. Mar 9, 2020 at 6:09 AM
    #324
    WreckedRooster
    WreckedRooster Well-Known Member
    Jake
    Oklahoma
    2020 MGM DCSB
    Super easy to install. Take out stock (old) part and install the new one. I did it myself with basic tools.
  5. Mar 9, 2020 at 8:51 AM
    #325
    Amanhowzit taco
    Adam
    Hawaii
    2017 sr5 4wd Tacoma
    Even adding New UCAs?
    What about spring compression? Should I just leave at factory settings and add weight?
  6. Mar 9, 2020 at 8:59 AM
    #326
    WreckedRooster
    Jake
    Oklahoma
    2020 MGM DCSB
    Check out this thread here:
    https://www.tacomaworld.com/threads/ome-bp-51-install-report-and-height-adjustment.476085/
    Lots of good information on the kit. Upper control arms are an easy swap. Check youtube on how to change upper control arms on a Tacoma. Mainly, you can buy a new bolt and cut off the old one. Or, bend the weld seam back a bit (towards the fender) and slide the bolt out through the top. I chose the latter option. They come from the factory set at 5mm now. If you are not running anything, I would leave it alone. As you add weight, you can adjust the preload on them. I'm sitting at 15mm, but have a steel front bumper, winch and roof rack.
  7. Mar 9, 2020 at 9:04 AM
    #327
    Amanhowzit taco
    Adam
    Hawaii
    2017 sr5 4wd Tacoma
    Thank you,
    to adjust the coil overs for added weight or less weight do you need a spring compressor ? Or would I have to take to shop? This would suck but this seems like one of the best made set ups around.
  8. Mar 9, 2020 at 9:06 AM
    #328
    WreckedRooster
    Jake
    Oklahoma
    2020 MGM DCSB
    I took mine to a shop and had them adjust the pre-load. There are tools out there where you can do it yourself, but I didn't plan on changing mine often.
  9. Mar 9, 2020 at 9:09 AM
    #329
    Amanhowzit taco
    Adam
    Hawaii
    2017 sr5 4wd Tacoma
    Once you have the pre-load adjusted you can adjust the compression and resistance while the suspension is on the truck correct?
  10. Mar 9, 2020 at 9:18 AM
    #330
    WreckedRooster
    Jake
    Oklahoma
    2020 MGM DCSB
    Yes. I'm still playing with those settings.
  11. Mar 9, 2020 at 9:19 AM
    #331
    Amanhowzit taco
    Adam
    Hawaii
    2017 sr5 4wd Tacoma
    awesome Thankyou!
  12. Mar 9, 2020 at 7:08 PM
    #332
    urbanplanner
    urbanplanner Well-Known Member
    washington state
    Richland WA, chiming in here. Way to represent the Tri-Cities! Great build thread. I’ll be doing a tiny fraction of what you represent here in a few months with an OME Nitrocharger/888/Dakar kit. The best part of the story is the father and son stuff. Love it.
    Hodakaguy[QUOTED][OP] likes this.
  13. May 23, 2020 at 4:46 AM
    #333
    Hodakaguy
    Hodakaguy [OP] Well-Known Member
    12 Tacoma/Vagabond Drifter
    I often get asked about different tools I'm using in our builds and figured I would highlight a few of my Must Have tools in a short video series.
    This video highlights my Deburring tool...this tool is soooo handy to clean up edges when drilling holes for Rivetnuts, Plusnuts or just running wires etc.
    Hope you find these videos handy for your builds
    Aluminum Shaviv Brand Tool Available Here: CLICK HERE
    Plastic Shaviv Brand Tool Available Here: CLICK HERE
    Royal Products Tool (The Shaviv tools above are a better value) Available Here: CLICK HERE
    Replacement Blades: CLICK HERE
    Hodakaguy
  14. May 23, 2020 at 4:54 AM
    #334
    Hodakaguy
    Plus Nuts & Rivet Nuts. I made up a video showing the difference between a Rivet Nut & a Plus Nut...when to use each and an overview of the different installation tools.
    Plus Nuts are super handy and I've been using a lot of them. I've been asked several times recently about the differences in a Plus Nut and a Rivet Nut so decided to make up a video and demonstrate the tools in action.
    Note that the Pneumatic tool is now available under $200.
    Astro 1450 Plus Nut Tool: CLICK HERE
    Pneumatic Rivet/Plus Nut Tool: CLICK HERE
    Standard Rivet Nut Tool: CLICK HERE
    Plus Nuts: CLICK HERE
    Hodakaguy
  15. May 23, 2020 at 9:47 PM
    #335
    Hodakaguy
    Marine Grade Wire & Heat Shrink Terminals vs Automotive Grade.
    In this video I highlight the differences between Marine grade wire & heat shrink crimp terminals vs standard automotive grade. I also cover the difference between standard crimping tools and specialized heat shrink crimp tools.
    I use marine grade crimps and wire almost exclusively in all of my builds. This is the 3rd video in a series where I'm highlighting tools, materials and techniques I use while building out our vehicles.
    Hope you find this information useful in your builds as well.
    Titan Heat Shrink Crimp Tool - On Amazon here: CLICK HERE
    Wirefy Heat Shrink Terminals - On Amazon here: CLICK HERE
    Ancor Brand Duplex Marine Wire - On Amazon Here: CLICK HERE
    Ancor Brand Primary Marine Wire - On Amazon Here: CLICK HERE
    Split Wire Loom - On Amazon Here: CLICK HERE
    Hodakaguy
  16. May 24, 2020 at 7:49 AM
    #336
    Beancooker
    Beancooker Alea iacta est
    The middle of Arizona
    2021 Jeep Wrangler Rubicon
    Lots, straight from the factory.
    This is by far one of the coolest build threads I have read. Very impressed with the quality of the builds.
    Your father’s welding skills are incredible. Those welds are magical and absolutely incredible.
    @Hodakaguy is that a railroad engine piston in that picture that holds the vice?
  17. May 24, 2020 at 8:58 AM
    #337
    Hodakaguy
    Thanks, We had a lot of fun building them out. I'm currently building a 17 4wd Sprinter (Link in my sig line below)....it's been a ton of fun as well :)
    The piston is out of a 1955 Ingersol Rand KVS 6 cylinder engine. The engine is rated at 1000hp at 330rpm and runs two double acting integral compressors. The bare piston weighs 400lbs.
    Here's a few shots of the engine itself, they are a kick to work on!
    Hodakaguy
  18. Jan 2, 2021 at 8:40 PM
    #338
    uploadadventure
    uploadadventure It’s all @ColoradoTJ’s fault
    Dixon, Mo
    2019 Cavalry Blue Tacoma TRD OR (sold) 05 Duramax
    Was just sent this thread.
    Really solid stuff here. Great information.
    What size tires are you running? Need to figure out what the largest tires that can fit under the bed.
  19. Mar 17, 2021 at 9:52 AM
    #339
    DustyTaco31
    DustyTaco31 Well-Known Member
    2018 Quicksand Taco TRD Sport
    i am so glad i found this thread. I will be doing some of the exact mods to my truck. Nice build
  20. Feb 13, 2023 at 9:17 AM
    #340
    bullpen58
    bullpen58 Well-Known Member
    Peoria, AZ
    2021 Tacoma PRO 4x4
    Lift, wheels, tires, sliders, and skidplates...so far.
    Thanks for the instructions on relocating the spare. I did that to mine yesterday.
    eurowner and RyanDCLB like this.
