Hole in Muffler - What should I do?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by wrtoyota, Nov 13, 2022.
  1. Nov 13, 2022 at 10:33 PM
    #41
    Tacodriver13
    Tacodriver13 Well-Known Member
    Raleigh, NC
    2022 Grey Tacoma TRD Sport
    Doing a little bit at a time.
    Just buy a new muffler it will be a lot cheaper than a welder...lol Plus if you do not repair or replace the new truck will not pass state inspection. Get it fixed and move forward!
    Speedbird likes this.
  2. Nov 13, 2022 at 11:37 PM
    #42
    tw0leftskis
    tw0leftskis Well-Known Member
    0xApes
    Meta Verse
    Can't weld Aluminum to steel
  3. Nov 14, 2022 at 4:10 AM
    #43
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    Because a new OEM muffler costs way more then you think and some generic muffler from the typical muffler shop lasts about 3 years because they are made of cheapo carbon steel.
    Stuck in VT and Big tall dave like this.
  4. Nov 14, 2022 at 4:49 AM
    #44
    That one old guy
    That one old guy Well-Known Member
    Chuck
    08 Base 4x4 2.7 Access 5spd
    Stockish
    Red Green that bioch!
    :eek::D
  5. Nov 14, 2022 at 4:52 AM
    #45
    wrtoyota
    wrtoyota [OP] Well-Known Member
    In your state a patched muffler will not pass state inspection? In CO we just need to pass emissions, but a new vehicle doesn't need to do emissions for almost a decade. A patched muffler would certainly be fine, maybe it would catch attention if it looked like shit.
  6. Nov 14, 2022 at 10:02 AM
    #46
    CalcityRenegade
    CalcityRenegade Well-Known Member
    Calgary, Alberta, Canada, Earth
    2023 T4R ORP KDSS
    Perfect excuse for a new muffler. I got a Flowmaster and nice black tip for $300 installed from a local muffler shop.
  7. Nov 14, 2022 at 12:54 PM
    #47
    wayne0
    wayne0 Well-Known Member
    Hornet? OMFG!
  8. Nov 14, 2022 at 1:08 PM
    #48
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    2021 Tacoma TRD Off-Road 4x4
    You don't happen to be located in AZ do you? I have the stock catback off my 2021 available that I'd sell ya for cheap.
    eurowner likes this.
  9. Nov 14, 2022 at 1:55 PM
    #49
    Clearwater Bill
    Billy
    Largo Florida
    Green too. :rofl:
    Had a pair of CIBIES in that baby for running the back roads of the Florida panhandle w/o killing deer and graded roads in piney woods to get to canoe only fishing holes.
    And some KMart fog lights under the rear bumper on a toggle to make easy Whaler trailer connections at night when fishing the coast.
    Plus it had working AC and only 70k miles, well ahead of the un-airconditioned '67 Comet I sold to buy it. :cool:
  10. Nov 14, 2022 at 2:02 PM
    #50
    eurowner
    eurowner Duke Sky
    Scoty
    Repost
  11. Nov 14, 2022 at 3:03 PM
    #51
    wrtoyota
    I'm in CO but appreciate the thought. Give me some time to think about my plan. People on here drive 40k trucks but think a welder is expensive.
    Stuck in VT and Delta09 like this.
  12. Nov 14, 2022 at 3:06 PM
    #52
    Kwikvette
    Fresno County
    4 run, 2 don't
    Mufflers have nothing to do with emissions.
    That's what your catalytic converters are for.
  13. Nov 14, 2022 at 3:08 PM
    #53
    wrtoyota
    Yeah but for emissions they check around the vehicle for holes in exhaust. I think in part because this is a way to cheat the detection devices they put by the tailpipe. Tacoma doesn't need emissions for 7 years though I think.
  14. Nov 14, 2022 at 3:10 PM
    #54
    Kwikvette
    Fresno County
    4 run, 2 don't
    Just noticed you're in CO.
    Man, and I thought CA was bad.
    Vehicles don't require smog for the first 6 model years meaning 2016 models are only now going to require smog this coming year.
    No inspection though, unless something prompts a tech to do so and it's usually on a vehicle that's subject to modification IE Camaro, Mustang, Challenger, etc. and only if you bring attention to yourself.
  15. Nov 14, 2022 at 3:15 PM
    #55
    eurowner
    eurowner Duke Sky
    Scoty
  16. Nov 14, 2022 at 3:18 PM
    #56
    BamBeds
    BamBeds Founder/Designer Vendor
    Ben
    Central Coast, CA
    '09 Access Cab TRD OR
    Bilstien 8100, 8112, Snugtop w/ windoors
    Get some thin sheetmetal cut into a patch then use a wire brush and brake cleaner for surface prep, then use JB weld to bond patch over it.
    joeR6 likes this.
  17. Nov 14, 2022 at 4:01 PM
    #57
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    Look on Craigslist or FB marketplace. Get a take off exhaust for next to nothing and move on. If you were thinking of a new exhaust prior to the hole them=n focus on that. Just do it.
  18. Nov 14, 2022 at 5:02 PM
    #58
    erok81
    erok81 Well-Known Member
    Imposter
    This would probably work as well as gluing a piece of cheese to the muffler using mustard.
    :cheers:
  19. Nov 14, 2022 at 5:05 PM
    #59
    Borracho Loco
    Borracho Loco My truck identifies as a Prius.
    DFW, Texas
    2021 Voodoo Blue - Tacoma TRD Offroad DCSB
    Oh look, another mod....
    Would you use cheddar, gouda, brie or limburger cheese?
    erok81[QUOTED] likes this.
  20. Nov 14, 2022 at 5:10 PM
    #60
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Either way it's gonna be "smoked" after all that... o_O
    erok81 and Borracho Loco[QUOTED] like this.
