homemade add leaf
Discussion in 'Suspension' started by MarkC, Oct 14, 2007.
  1. Oct 14, 2007 at 8:13 AM
    MarkC
    MarkC [OP] Carolina Alliance: Warheads On Foreheads Division
    Mark
    Yokota AB, Fussa-Shi, Japan
    99 4x4 SR5
    2 inch spacer in the front, and homemade add a leaf in the rear, billet grille, bull bar
    So I aquired a set of used leaf springs a couple of weeks ago to replace my sagging rear end. I install the new springs and my truck still wasn't level!!! So after a couple days of thinking and looking at my old springs BAM!!! use an old leaf as a ad leaf!! so i cut 2 inchs off each side of the last leaf and BAM custom add leaf! so I get some longer bolts and install them and I am very pleased with the final result my truck is level and i didn't have to pay 80 bucks for an add a leaf kit!! pics on the way
  2. Oct 23, 2007 at 11:39 PM
    LRH
    LRH Well-Known Member
    GA USA
    '07 2.7L PreRunner
    Thats the way I have been doing it for years, I usually use a long soft leaf and put it mid pack, or on vehicles with long bottom leafs, I cut it longer than the overload, but shorter than the bottom leaf (non overload). It is even better when you can find a leaf the correct length that has the nylon anti friction pads.
  3. Oct 24, 2007 at 4:53 AM
    2003greenbean
    2003greenbean Carolina Alliance Costal Div
    socaste,sc
    03 trd
    cold air intake, step bars, custom grill, 3in lift,12 in audiobahn sub, 285/75/16 procomp tires, 20% tint,
    that was a good idea does it ride ok
