Homemade skid plates?
Discussion in 'Off-Roading & Trails' started by NC15TRD, Feb 10, 2013.
  1. Apr 1, 2013 at 5:16 PM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    quoted for truth.
  2. Apr 2, 2013 at 5:23 AM
    jds0912
    jds0912 Well-Known Member
    Justin
    Baltimore, MD
    2007 Tacoma TRD Off Road
    Some shit I got on craigslist
    jagergirll likes this.
  3. Apr 2, 2013 at 5:44 AM
    Got2ryde
    Got2ryde Well-Known Member
    Ryder
    Maryland
    AC OR 6spd silverstreak
    Off Road tow pac. GTCovers wetskinz seat covers, Direct wired Escort 9500xi, Leer 180 w/ARB awning, bed mat, extra d-rings, rear dif breather relocated, Weathertec mats, Elite front with Warn M8000-s and Rigid D2's, BAMF sliders, ABS killswitch, Kicker Hideaway sub, UltraGauge, ATO rear with flush mount duallys, FJ Trail Team black rims w/Duratracs.
    Where in PA are you? I like the sound of this.
  4. Apr 2, 2013 at 10:25 AM
    Box Rocket
    Box Rocket Well-Known Member
    Adam
    Syracuse, Utah
    1995 FZJ80 Land Cruiser
    3xLocked, lifted, well used
  5. Apr 17, 2013 at 5:09 PM
    Slodgetto
    Slodgetto Über Posre
    Silas
    Same here.
    I copied Box Rocket's method for making skid plates, and I love the way mine turned out! A lot stonger and way cheaper than buying aftermarket skids...
    I found the key to making sure the skids fit well in the end is to constantly double, triple, and quadruple check the measurements, how they're applied to your blank piece of steel, and a lot of test fitting when you're making the bends and final cuts.
    I used 1/4" plate for both my skids with 3/16" angle iron bracing on the transmission skid. (Since this tends to bed first, from the pics I've seen..) I do think 1/4" is overkill for the IFS skid, and adds unnessecary weight to the front end, it was cheaper for me to go this route since all I had to do was get a giant piece of 1/4" plate.
  6. May 13, 2013 at 9:06 AM
    Benson X
    Benson X My build thread sucks...
    Ben
    Olympia, WA
    '11 MGM DC/LB
    If you don't draw blood, you're doing it wrong!
    Here's mine:
    After I added the Mid-Skid:
    Unfortunately I don't have a write-up for the skids (sorry). It mounts to the factory bolt holes and hardware (except for some Grade-8 nuts and bolts I picked up) and uses the transmission cross-member studs to bolt the rear into place.
    I basically checked out the different skids I liked (Relentless, Bud Built, ATO) and saw how they mounted to borrow ideas from. I had a rough sketch from a buddy with measurements for the front IFS skid, so that took a lot of the guess-work out of it.
    I bought a 64" x 24" piece of 3/16" thick A36 steel and used a combination square to start marking my cuts, welds, and bends. I had never welded before, but with the help of a fellow Taco buddy, we cut out each piece with the plasma cutter, and started welding it together. We test fit each piece along the way to make sure the factory mounting holes lined up.
    After we got the front skid done, we had to slot some of the holes to make it fit just right. I had originally planned to make (2) separate skids that bolted together, but simplicity and ease won in the end, and we welded them into a one-piece. I just got done mounting the whole thing up, and it was a chore. After some "persuasion" we got it mounted and it is pretty damn solid.
    I guess my best advice would be to really check out your under-carriage, note what factory holes you have available, see where you need protection, and measure, measure, measure. Use a degree finder to dial in the rough angles you need to work around. Once you have the separate pieces ready to weld together, test fit them on the truck and tack weld them to each-other after confirming they line up. Remove the skid(s) and finish welding all the seams/joints.
    Hope this helps, and gives you some ideas for your truck. Good luck! :cheers:
    Rick's 2012, bahndrvr, Marc70 and 2 others like this.
  7. May 13, 2013 at 10:26 AM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    Mech_Eng and tan-ishman like this.
  8. May 13, 2013 at 10:41 AM
    NC15TRD
    NC15TRD [OP] Well-Known Member
    Nick
    PA
    16 Sierra SLT All Terrain
    Readylift, Truxedo, Husky Liners, Carven
    I love Tacomaworld!
    PvilleJohn likes this.
  9. May 13, 2013 at 10:58 AM
    BostonBilly
    BostonBilly Well-Known Member
    Easton
    2018 Jeep Wrangler JL Rubicon
    Sub for great info
  10. May 13, 2013 at 11:18 AM
    Benson X
    Ben
    Olympia, WA
    '11 MGM DC/LB
    :thumbsup:
  11. May 13, 2013 at 1:35 PM
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
  12. May 15, 2013 at 12:45 PM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    I'm sure many folks have seen these. They have been bouncing around TTORA since time began.
    1st gen, man trans radiator (height) only
    http://www.mikeharan.net/temp/skidplate1.pdf
    http://www.mikeharan.net/temp/skidplate2.pdf
    EDIT The above links are now dead. Photos of the original PDF's added at the end of this post.
    My template with dimensions.
    https://www.tacomaworld.com/threads/homemade-skid-plates.262726/page-8#post-15542520
    The front will NOT work with an auto trans radiator. You will have to add the "Bud Built Bulge" or swap to a man trans rad and stand alone cooler.
    I made an exact cardboard template from the "front" PDF and it fit sort of ok. I would recommend doing the cardboard thing direct from the drawing and tweek that for your final piece.
    By playing with the angles of the 3 main bends and the lengths of the flats there was no loss of ground clearance and full protection of LCA adjusters. The front cut-outs are only about 1/8" below the inner ends of the control arms.
    The OEM mount locations are as light weight as the OEM skid and should be replaced. I made new rear mounts by replacing the stockers with 3/16" plate with heavy pattern nuts welded above. This allowed them to be placed higher in the cross member for ground clearance and enabled the use of "pocketed" mount bolts. The front mount "cross member", if you can call it that, is just as flimsy and should be replaced as well.
    I have about $65 in it including $15 for the 3 main bends plus paint and hardware.
    Really wimpy OEM rear mounts.
    3/16" plate drop fresh from a 15 min. improvised acid bath, I hate mill scale.
    Back from the bender.
    Back from the bender, scenic version.
    Rear bolt "pocket"
    Virgin semi gloss lacquer.
    Original PDF's
  13. Jul 14, 2013 at 8:56 PM
    venturequest
    venturequest Member
    Sacramento
    2010 Tacoma TRD SPORT DBL CAB
    BRUTE FORCE PLATE BUMPER, XRC 8 WINCH,
    I am in the process of fabricating my on front skid plate. I will post pics as I progress. Hopefully it will work and I will also attach specs.
    FloridaFree likes this.
  14. Jul 14, 2013 at 9:16 PM
    ImplicitlyAlberta
    ImplicitlyAlberta VA6DCO
    David
    edmonton
    06 SR5 Trail Rated, 16 Tundra CM TRD
    TC Uni Uppers, TC race lowers, TC shock tower gusset/ secondary shock hoop, Modified Pelfrey rear shock relocate, ATO shackle flip,radflo hydro bumps front and rear, Radflo 2.0 CO/ 14" rear, Arb rear air locker, ARB front bump/m8000, Road armor rear bump/m8000, FJ TransCase/ Twin sticks....other shit.
    Started with this.
    Came up with this. Not many build pics.
    Rear diff skid. This will be removed and modified to cover the tailstock alittle better.
  15. Jul 14, 2013 at 9:24 PM
    #35
    ImplicitlyAlberta
    David
    edmonton
    Without threads like this one, I wouldn't attempt half of what I've done.
    Couple more pics. Using my little 120v welder she came out not half bad.
  16. Jul 15, 2013 at 12:04 AM
    #36
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    well that's one way
    I've given out specs to a couple people but always ask they donate to the BRC or something similar.
  17. Jul 15, 2013 at 5:21 AM
    #37
    Southern01Taco
    Southern01Taco Well-Known Member
    Sean
    Holden, La
    01 V6 4x4 Xtra Cab SR5
    Here are my skids. 3/16" thick and bolts up just like stock. I made my bash plate and engine skid separate so that changing the oil would be easier. I also put 1" square tubing on my trans. and t-case skids as bracing. Then I just plated my factory gas tank skid.
    Slashaar likes this.
  18. Jul 15, 2013 at 1:19 PM
    #38
    FrustrationFabTaco
    FrustrationFabTaco Well-Known Member
    Luke
    Lexington, VA
    11 Duramax Grandpa Truck Special
    :spy:
    sub'd. planning on making my own as well
  19. Jul 17, 2013 at 12:58 PM
    #39
    Lumpskie
    Lumpskie Independent Thinker
    New Hampshire
    '96, 4x4, v6, manual hub
    Toytec 16" coilovers with Tundra Bilstein 5100s, Light Racing UCAs, Alcan Leafs with Orbit Eyes, 12" Bilstein 7100 short Bodies, ARB rear locker, 33x12.5 Duratracs, CBI sliders, Bushwacker fender flares, self made front bumper, M8000, Vision X 6.7" Hi/Lo Beam HIDs, full skids, Inchworm dual case setup - 15º clocking
    Here are some pics of my home made skids. They are all 3/16" like everyone elses and have see some serious abuse. Some unique details are the fact that I used 3 stand offs on the front skid instead of 2.
    Also, my IFS skid can be removed without removing the belly or front skid for easier oil changes. I'll be updating the belly skid for my flat belly some time here. I'll post up more pics thenP1040400_be6cb2f9a0703587f5b433c0d8ceb436fca4a62a.jpg
    You can see how they sit on the truck here:
  20. Jul 19, 2013 at 6:04 AM
    #40
    NC15TRD
    Nick
    PA
    I forgot about this thread lol I have been riding my Grizzly quite a bit lately and because I bought it the truck mods have essentially stopped. I'm still gonna make my skids someday, but probably not for a little while yet. Keep the info flowing so I can make even better skids haha!
    bahndrvr likes this.
