Homemade skid plates?
Discussion in 'Off-Roading & Trails' started by NC15TRD, Feb 10, 2013.
  1. Jul 10, 2019 at 1:46 PM
    #381
    Twoshakejake
    Twoshakejake Member
    Jake
    Wyoming
    2009 TRD offroad
    Is this for a 1 gen?
  2. Jul 10, 2019 at 1:56 PM
    #382
    jahulgan
    jahulgan There and Back...
    James
    Central Georgia
    '09 SBDC Green TRD Off-Road 4x4
    Old Man Emu 886 Springs, 255-85-16, ARB Front Bumper w/ Warn 8K Winch, SOS Sliders, Custom Skid Plates
    2nd Gen
    Twoshakejake[QUOTED] likes this.
  3. Jul 10, 2019 at 1:57 PM
    #383
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    He's got a 2nd gen.
    There are several posts earlier in this thread of guys with first gens. I'm also (VERY slowly) in teh process of fabbing some skids for my 1st gen, so I'll post some pics, maybe a separate thread. But don't hold your breath, I've been a busy man with non-truck stuff lately....
  4. Jul 11, 2019 at 4:36 PM
    #384
    Twoshakejake
    Twoshakejake Member
    Jake
    Wyoming
    2009 TRD offroad
    Yeah 2nd gen is what I’m looking for
  5. Jul 11, 2019 at 5:07 PM
    #385
    jbrandt
    Justin
    I'm sorry to hear that... :D
  6. Jul 11, 2019 at 6:15 PM
    #386
    Li0nel1234
    Li0nel1234 Well-Known Member
    Lionel
    Denver
    14 TRD OR DCSB SSM
    This is some amazing work!
    Slashaar likes this.
  7. Jul 21, 2019 at 8:32 PM
    #387
    unti
    unti Member
    JC MO
    '11 ACLB
    How much clearance did you end up with between the skid and the front diff?
    I finally decided to burn through my stash of cutoff wheels this weekend and give this a try. So far so good. My intention was to mount this flush to the bottom of the crossmember and make the legs just long enough to make up the gap to the bolt holes but I’m ending up with super tight clearance between the skid and the front diff. Like I could get a credit card in there but probably not much more and I’m wondering if I should be concerned.
    I’ll probably just go for it and add some washers if I hear shit banging around down there I guess.
  8. Jul 22, 2019 at 3:54 PM
    #388
    jbrandt
    Justin
    I would think you'd want more than a credit card width, though. Even if the diff doesn't move at all under torque (pretty sure it does), you also don't have any "flex" clearance, so if (when) you bash it on something, you'll flex the skid and hit your diff. Even if the skid doesn't permanently bend, it does flex a bit.
    With my first gen, I have a diff drop, so that lowers it by about an inch. When I modified my stock skid plate, I just added that same length to the skid using some 1" square tubing, lowering the whole thing by 1". Basically just maintaining whatever the clearance was originally.
    With the skid I'm making now, I'm working on something very similar. I'm going for at least 1/2" clearance from my diff. Maybe a little more. More clearance will allow you to get a reinforcement brace under there, too, if you choose that type design...
  9. Jul 24, 2019 at 9:22 AM
    #389
    jahulgan
    James
    Central Georgia
    Can't really tell from this picture, but it is somewhere around 3/8" gap between the skid and diff.
    MolonLabeTaco and jbrandt like this.
  10. Aug 6, 2019 at 3:51 PM
    #390
    4x4Taco09
    4x4Taco09 Well-Known Member
    Dane
    Louisiana
    09 TRD Sport 4x4 BSP DC LB
    Kings, Deavers, Brute Force, Prinsu, Lights, all the stuff
    About to go and buy some foam board and start mocking up my skids finally
    jbrandt, jpereira2 and jahulgan like this.
  11. Aug 18, 2019 at 4:54 PM
    #391
    jbrandt
    Justin
    I just scored a Hobart 210mvp for $500! (NEW!)
    I was lurking around on Amazon because I had been eyeing a Lincoln 180 for a while, and they had some random deal on the Hobart. Normal price is like $900. I'm glad I ordered it on the spot then asked "permission" from the wife later, lol. I went back just a few minutes after I ordered it and it was back up to normal price, and they had the 190 on sale instead - also for $500 so not as good of a discount.
    Anyhoo, this will much much easier work of the skids that I *still* haven't gotten beyond some initial cuts from raw material. Oh well, life gets in the way sometimes.
    EDIT:
    No I didn't. Seller is a douche and apparently makes a habit out of posting $500 items then cancels them. I knew it was too good to be true...
    oh well, still getting the 210, just not as good of a deal on it as I thought.
  12. Aug 18, 2019 at 7:57 PM
    #392
    MolonLabeTaco
    MolonLabeTaco Well-Known Member
    Dude
    N. Texas
    '12 DC 4x4 OR
    I use the Hobart MVP210. Make sure you use a dedicated 120V receptacle with a 30A breaker. I never use the 120V option anymore but for $500, that’s a steal!
  13. Aug 18, 2019 at 8:15 PM
    #393
    jbrandt
    Justin
    Oh I've got a dedicated 220v in my shop I just built.
    I actually was skeptical at first, I was like that's TOO cheap, what's wrong with it?? But then I knew I'd kick myself if I missed out. I guess I'll have to wait and see if it's the real thing when it shows up this week, lol
  14. Aug 21, 2019 at 12:12 PM
    #394
    sonoran
    sonoran Big Loop
    Brob
    Flagstaffrica, AZ
    Tacoma 4X4 3RZ
    Tires: BF Goodrich TA KO2 235/85-16 Matching Spare (in rotation) Rear Suspension: King 2.5 shocks Custom Alcan springs OME greaseable shackles Front Suspension: King 2.5 coil overs Total Chaos UCAs New OEM LCAs Total Chaos Steering knuckle gussets Total Chaos Steering rack bushings Rear Diff: ARB locker (Zuk-Built diff) ARB HD Compressor Rear diff breather extended Armor: Custom full-coverage skid plates Stubbs sliders CBI rear bumper CBI Frame plates Engine: 3RZ Custom over leaf spring exhaust LCE Heavy Flywheel, Pro clutch LCE Stage 1 Head LCE Stage 1 Cams LCE Balance Shaft Delete Bed: Flip-PAC Camper Spray-in bed liner Footman’s loops Canyon Cooler KIST bottle opener Recovery: Custom and very complete tool/service kit including angle grinder and impact HiLift (I know how to use it) and/or Solo skid floor jack depending on trip Glock e-tool (shovel) Strap Interior: Fire Extinguisher Saddle Blanket seat cover Alpine sound Exterior: Anza Headlights WeatherTech wind deflectors “One Less Sprinter” bumper sticker
    What ever you do be sure to beef up the mount on the crossmember near the LCAs. The stock nut plates don't even hold up to stock. Here's mine...
    Slashaar and 03_taco_IN like this.
  15. Aug 22, 2019 at 3:34 PM
    #395
    jbrandt
    Justin
    For sure.
    This is on my list for this weekend.
    I have some plate that I bent on 2 sides and is tapered on one end so when it's mounted, the bottom of the plate will sit level/flat - making bolting the skid plate to it a little easier.
    Just make sure you have plenty of room for the LCA to droop all the way down without hitting that plate.
    Slashaar and sonoran[QUOTED] like this.
  16. Aug 23, 2019 at 2:48 PM
    #396
    YamaDirtrider
    YamaDirtrider Custom bumpers @FORT-ifyRigs
    Josh
    Elizabeth CO
    06 DCLB sport postrunner
    What hasn't been modified?
    I like this idea. Will have to do it on my truck soon
  17. Aug 25, 2019 at 2:39 PM
    #397
    jbrandt
    Justin
    Finally made some progress on my skids:
    Made a few whiskey bends for the front piece of the IFS skid,
    And made up a jig to hold the mount plates. I welded nuts to the top of the plates, and I'll use this same jig to place the holes for the skid, too.
    Ready to burn the mounting plate to the frame, but it's 107 right now, too damn hot to keep welding...
  18. Sep 16, 2019 at 10:20 AM
    #398
    jbrandt
    Justin
    My solution for recessed bolts and the bottom plate:
    Once the frame mounts were welded:
    I bolted this "C" channel to the mounts, and lined up the bottom plate, tacked the two main pieces together, then carefully marked the location of the "c" channel on the bottom plate.
    Took a bit of careful measuring and placement of this "c" channel, by marking the location on the skid, then drilling the holes and tacking in place. A test fit showed it lined up perfectly!
    sonoran, Slashaar and irayfz6 like this.
  19. Sep 16, 2019 at 10:26 AM
    #399
    cynicalrider
    cynicalrider #NFG
    Jersey
    sonoran and irayfz6 like this.
  20. Sep 16, 2019 at 10:34 AM
    #400
    jbrandt
    Justin
