Homemade skid plates?
Discussion in 'Off-Roading & Trails' started by NC15TRD, Feb 10, 2013.
  1. Aug 6, 2013 at 10:45 PM
    #41
    Revco
    Revco Got that PMA
    Austin, TX
    '01 Reg Cab 4x4
    stock-ish
    No pics of mine, they aren't finished or installed yet, but they are 1/4" 6061 Aluminum. I built mock-up pieces at work out of thin gauge aluminum to figure out the fitment and clearance, then transferred that info to the 1/4" plate aluminum. All bends, holes, and notches done on an Ironworker. I still need to weld up the mount spacers and add some sectional support on the topsides before installing them. I'll post up pics and more info when I get them wrapped up.
    I built them with aluminum for two reasons. 1. I had a few 4x8 sheets of 1/4" 6061 Aluminum that have been taking up space in my shop for the last several years, 2. It's way lighter than Steel and I want to keep my little Reg Cab as light as I can.
    The 1/4" 6061 Aluminum weighs 3.5 lbs/sqft, where 3/16" Mild Steel weighs 7.65 lbs/sqft and 1/4" Mild Steel weighs 10.2 lbs/sqft. So the weight savings are massive when compared to steel. I won't be doing any hardcore crawling, so I'm sure they'll suit my needs just fine.
  2. Aug 20, 2013 at 2:47 PM
    #42
    Steve W
    Steve W Member
    Great posts, pictures and ideas. Thanks!
  3. Oct 8, 2013 at 8:39 AM
    #43
    NC15TRD
    NC15TRD [OP] Well-Known Member
    Nick
    PA
    16 Sierra SLT All Terrain
    Readylift, Truxedo, Husky Liners, Carven
    DO YOU HAVE A TOTAL COST ON THEM?
  4. Nov 10, 2013 at 6:32 AM
    #44
    Steve W
    Steve W Member
    Thanks for this idea, I used this idea to build a rear diff skid. I would not have taken on that project without this method of making bends because there are so many angles. I only have a stick welder and table vise and some clamps. Thanks again, Box Rocket
  5. Nov 10, 2013 at 6:35 AM
    #45
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    I made my own tranny skid. Really simple design though.
  6. Nov 10, 2013 at 10:03 AM
    #46
    Box Rocket
    Box Rocket Well-Known Member
    Adam
    Syracuse, Utah
    1995 FZJ80 Land Cruiser
    3xLocked, lifted, well used
    :headbang: Glad I could help.
  7. Nov 10, 2013 at 11:31 AM
    #47
    ImplicitlyAlberta
    ImplicitlyAlberta VA6DCO
    David
    edmonton
    06 SR5 Trail Rated, 16 Tundra CM TRD
    TC Uni Uppers, TC race lowers, TC shock tower gusset/ secondary shock hoop, Modified Pelfrey rear shock relocate, ATO shackle flip,radflo hydro bumps front and rear, Radflo 2.0 CO/ 14" rear, Arb rear air locker, ARB front bump/m8000, Road armor rear bump/m8000, FJ TransCase/ Twin sticks....other shit.
    Pics?
  8. Nov 10, 2013 at 7:04 PM
    #48
    Spoonman
    Jamie
    Alberta
    Re routed exhaust, smoothed out the hump on the Allpro skid. Then attached the long tranny skid from the ifs to the tcase skid.
    Flat belly is great
  9. Nov 15, 2013 at 6:23 AM
    #49
    NC15TRD
    Nick
    PA
    I'm definitely going to have a reroute done. I don't want that ridiculous pipe hanging down that low.
  10. Nov 15, 2013 at 7:08 AM
    #50
    BradyT88
    BradyT88 Well-Known Member
    :jellydance:
  11. Feb 27, 2014 at 9:39 AM
    #51
    cynicalrider
    cynicalrider #NFG
    Jersey
    Subbing for future reference. Thinking about having a buddy of mine work with me to fab up a skid.
  12. Feb 27, 2014 at 7:39 PM
    #52
    Dj318
    Dj318 Well-Known Member
    Dylan
    Concord, NC
    02 Tacoma
    bilstein 5100, wheelers AAL, Trail gear bumper, SOS sliders, RAT skids, 35" Mtr/k
    Subed!
    Are y'all welding the cross supports to the frame?
  13. Feb 27, 2014 at 7:40 PM
    #53
    Box Rocket
    Adam
    Syracuse, Utah
    I didn't weld any of the skid to the frame. The rear crossmember on my belly skid is part of the skid. there are brackets welded to the frame that it bolts to.
  14. Feb 27, 2014 at 8:01 PM
    #54
    Dj318
    Dylan
    Concord, NC
    02 Tacoma
    Oh!! I see what ya did there! Did you custom make the brackets or order them?
  15. Feb 27, 2014 at 8:02 PM
    #55
    Box Rocket
    Adam
    Syracuse, Utah
    I used some I got from Ruffstuff
  16. Mar 3, 2014 at 6:34 AM
    #56
    FrustrationFabTaco
    FrustrationFabTaco Well-Known Member
    Luke
    Lexington, VA
    11 Duramax Grandpa Truck Special
    :spy:
    does yours cover the T-case too?
  17. Mar 23, 2014 at 9:45 AM
    #57
    01tacoprerunner
    01tacoprerunner 01 4WD Prerunner
    Brian
    Raleigh, NC
    01 4WD Prerunner
  18. Mar 23, 2014 at 10:05 AM
    #58
    TRD 09
    TRD 09 Well-Known Member
    Alberta
    09 TRD sport
    I built my front bumper for $350 my rear bumper for about $85, tire carrier for another $60, roof rack was $80ish and rock sliders for about $125, skids and bed rack are on the list, definitely cheaper than buying, front bumper alone with shipping would put me out $1800 or more
    Saucetheboss likes this.
  19. Mar 24, 2014 at 11:09 PM
    #59
    HBtaco02
    HBtaco02 Well-Known Member
    Allen
    Huntington Beach
    02 4wd SR5 TRD
    ARB Front Locker grey wire mod Camburg UCA's Extended Kings All-Pro expo's 10" Bilstien Brute Force Hybrid front bumper Smitty XRC8
    I built this all 3/16" plate and 1" X 2" tubing. Rear mounting is similar to Box Rocket's.
  20. Jun 9, 2014 at 8:37 AM
    #60
    FrustrationFabTaco
    Luke
    Lexington, VA
    :spy:
    bump for next project :popcorn:
