Homemade skid plates?
Discussion in 'Off-Roading & Trails' started by NC15TRD, Feb 10, 2013.
  1. Jul 11, 2016 at 9:28 AM
    #121
    cynicalrider
    cynicalrider #NFG
    Jersey
    3/16"
    MatthewMay1 likes this.
  2. Aug 4, 2016 at 9:22 AM
    #122
    TK4R
    TK4R Member
    2008 T4R LTD V6 4WD
    Where do you guys buy the blank sheets from? a 2x4ft 3/16 steel sheet from McMaster is over $300, it's almost more expensive than buying ready-made skids.
  3. Aug 4, 2016 at 9:28 AM
    #123
    cynicalrider
    cynicalrider #NFG
    Jersey
    mark1285 likes this.
  4. Aug 4, 2016 at 9:29 AM
    #124
    gordi
    gordi Only had a wheel fall off once
    Josh
    North Idaho
    2011 DCSB trd sport
    Fox 2.5 extended travel, dakars, rear 5125 255/80/17 cooper maxx ST
    I just went to local metal distribution company. 50 bucks for the 3/16 sheet
  5. Aug 4, 2016 at 2:05 PM
    #125
    TK4R
    TK4R Member
    2008 T4R LTD V6 4WD
  6. Aug 4, 2016 at 5:37 PM
    #126
    Overkill07
    Overkill07 Tacoitis
    Warren
    Texas
    14 TRD O/R DC MGM
    A few audio upgrades, tinted windows, remote start because it f'n hot in Texas! 6in Fabtech DB lift, 17x9 Fuel Trophy wheels, 315/70/17 Duratracs,BAMF 80in sliders w/kickout, Prinsu cab rack w/30in Heretic light bar, custom bedside decals, custom hi-lift jack brackets, US Offroad front bumper w/winch, bed rack with RTT, CB, Short wave base station, Ultra gauge, color matched grille surround, an ungodly amount of recover gear, ARB fridge, hood struts, RotoPax, traction pads.
    I'm pretty lucky as I have a buddy with a fab shop so I get material at cost.
  7. Jan 11, 2017 at 1:39 PM
    #127
    exportexp
    exportexp Well-Known Member
    Fred
    2013 Taco 4x4 - TTC#069
    Little here and there & ChadsPride Likes This Sticker
    My next mod after my bed rack.
    Thanks for all the info.
    gordi and jjsul like this.
  8. Feb 28, 2017 at 2:45 PM
    #128
    mark1285
    mark1285 Well-Known Member
    Mark
    2017 Tacoma TRD Off-Road
    So I'm thinking of doing this, I have a pretty well stocked home shop Miller TIG, MIG, and Plasma, w/ spool gun. I also live near fazzio's in jersey. Any reason i shouldn't be strongly considering making these out of 304 Stainless? If i'm going to spend all that time fabricating......
  9. Feb 28, 2017 at 7:16 PM
    #129
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    Just curious why stainless?
  10. Feb 28, 2017 at 7:20 PM
    #130
    Box Rocket
    Box Rocket Well-Known Member
    Adam
    Syracuse, Utah
    1995 FZJ80 Land Cruiser
    3xLocked, lifted, well used
    Depends on why you want skids. Are you actually planning to do much off-roading? No point in going stainless if you're going to beat them up.
  11. Feb 28, 2017 at 7:33 PM
    #131
    Reh5108
    Idaho
    Was thinking the same thing.
  12. Mar 1, 2017 at 4:46 AM
    #132
    mark1285
    Mark
    A couple reasons. I think it would be a superior material overall for this application. Wont have to worry much about corrosion, my truck is brand new and I plan on owning it a long time. Also it has a significantly higher yield strength. A-36 steel is around 250 MPa and stainless (depends slightly on variant), but is over 500 MPa, which is similar to Grade 8 Steel hardware. Basically, you can expect the stainless to deflect slightly less under load and scratch significantly less when stressed. I'm thinking this means you can definitely get away with 3/16 stainless plates which eases fabrication significantly, and still walk away with a skid plate stronger than 1/4" A36, although both materials are definitely adequate for the application. I would say long time salt corrosion resistance is the best reason to use aluminum or stainless vs steel.
    Plus I like to think outside the box, and haven't yet gotten married so i can spend my money on something as ridiculous as stainless steel skid plates. Materials for Stainless should still come in much less than purchasing the steel plates, it is not that crazy expensive.
    4x4Taco09 and Reh5108 like this.
  13. Mar 1, 2017 at 4:49 AM
    #133
    mark1285
    Mark
    And to answer the other part, my hope is that my plates never take damage. I am intending to use the truck to travel some and camp. But i like the idea of protecting things in the event of a boulder....... if it were to happen.
  14. Mar 1, 2017 at 5:12 AM
    #134
    Overkill07
    Overkill07 Tacoitis
    Warren
    Texas
    14 TRD O/R DC MGM
  15. Mar 1, 2017 at 7:28 AM
    #135
    dumprat
    dumprat Well-Known Member
    Southern B.C.
    08 tacoma DCLB
    TSB leafs, weather techs, ram mount,jack&shovel mount, and more to come.
    Stainless seems like overkill. Aluminum with a lightweight tubular steel structure would be a nice blend of light weight, corrosion resistant skids.
  16. Mar 1, 2017 at 7:38 AM
    #136
    mark1285
    Mark
    I'm surprised everyone thinks stainless is overkill. If I could pay Toyota the material difference between mild steel and stainless steel for the truck frame and body, and get a truck that was built with all stainless, I would do that in a second. It would probably be a like a 2-3K up charge to never have to worry about significant corrosion in the body and frame. I figure I can at least cover my sensitive parts in stainless steel.
    I have no supporters for stainless steel skids? And before I get crucified my guess at the stainless steel up charge is probably high. Even if Toyota pays triple price of current stainless steel scrap rates (~$.15 /lb) for their bulk stainless steel, its only 1000$ at most in metal. Fabrication is most of the cost.
    Crazyhorse6901 likes this.
  17. Mar 1, 2017 at 8:01 AM
    #137
    dumprat
    Southern B.C.
    08 tacoma DCLB
    Stainless will work great for skids, but for a truck frame it has trouble with stress cracking at welds and things.
    Chevrolet made some cars out of stainless back in the 60's for European embassy cars. A friend of mine owned a used one it basically fell apart due to cracks around bolts and welds.
  18. Mar 1, 2017 at 8:44 AM
    #138
    mark1285
    Mark
    Stress cracking in stainless is a problem for sure. So is corrosion at weld seams especially with salt based contaminants, the metallurgy of weld actually can differ significantly from the rest of the plate.. These are definitely things the brilliant engineers at Toyota could overcome with different grades of stainless and different manufacturing techniques, at least I think and hope they could..... Stainless frame would be awesome, definitely tougher to accomplish though... glad someone likes my stainless skids idea finally.
    4x4Taco09 and Crazyhorse6901 like this.
  19. Mar 1, 2017 at 8:50 AM
    #139
    Overkill07
    Overkill07 Tacoitis
    Warren
    Texas
    14 TRD O/R DC MGM
    I definitely am not saying that I don't like the idea at all. I've tried to come up with many different materials for skids.
    I think steel is just the goto as it is an in between point for strength and cost. Plus more people can work with that material then the others.
  20. Mar 2, 2017 at 1:04 AM
    #140
    cynicalrider
    cynicalrider #NFG
    Jersey
    There is a guy on here that sells stainless skids for first gens and since most leave them bare metal I was always curious to see how they would look beaten up. I say go for it. Which fazzios are you near? Glassboro? Stop by and say hi in the njbs thread. Lots of dudes in there are home grown amateur fabricators working on different shit for our trucks.
