Honda Accord help - stalling when hot
Discussion in 'General Automotive' started by MTgirl, May 29, 2011.
  1. May 29, 2011 at 7:21 AM
    MTgirl
    MTgirl [OP] too many frogs, not enough princes... Moderator
    Weesa
    Bob's secret mod lair
    So my folks went out of town for the weekend and took mom's 99 Accord. After being on the highway for 4+ hours they were in town and while stopped at a traffic light the car stalled. It started back up again but in order to keep it running while stopped it has to be in neutral and revving the engine. This has happened once before, recently, and under the same conditions - after being out on the highway for an extended period and then stopped in traffic. They stopped and parked the car for a while, once it cooled down a bit it ran fine, no stalling. Mom recently had the timing belt, seals, water pump, etc replaced; this problem started after that work was done.
    Any ideas what could be causing this? Seems to only happen when the engine is warm and has been running for extended periods. Mom and dad are a little worried that they will be stuck out of town if its something serious.
  2. May 29, 2011 at 7:25 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Could be a cracked vacuum hose....
  3. May 29, 2011 at 7:30 AM
    MTgirl
    Weesa
    Would that be the most likely cause with the hot engine=stall, cold engine=fine scenario? She's thinking that it has something to do with the timing belt, etc since that work was just done and that's when this problem started....
  4. May 29, 2011 at 7:57 AM
    95SLE
    95SLE Starting to get cold outside
    Tom
    Maryland
    09 RWD Access Cab
    Custom XM Install, Window Tint, Intermittant Wiper Install, AVS Bug Deflector, Bed Mat, TRS FX-R retrofits, CIBIE fog and spot lamps, PIAA 510 lamps, Acess LE cover, Weathertech Digital floorr mats, LED interior lighting, Pioneer AVH-2300BT HU, Boston Acoustics speakers, JL Audio Amp, shorty antenna, leather wrap steering wheel cover, Viper security system.
    I would think that a timing belt problem would be all the time.
    Another possibility is the fuel filter.
    I am just guessing here. If you are trying to fix the problem I would start with the basics, clean and regap the plugs, check the spark plug wires, clean the throttle body and maybe clean the MAF.
  5. May 29, 2011 at 8:01 AM
    TacoDawgfan
    TacoDawgfan Hunker Down You Hairy Dawg!
    Georgia
    2011 Silver 4x4 TRD Sport w/JBL
    5100's at 1.75, Rear leaf TSB, Moto Metal 951 16x8, BFG TKO2 265/75/16, AFe Stage 2 CAI w/pro dry filter, Kenwood DDX374BT installed with Idatalink Maestro kit, Access Loredo tonneau cover, N-Fab steps, Tinted windows, EGR in channel vent visors, UGA drink coasters in the front cup holders, and a Graco car seat in the back seat
    I had a Dodge Dakota years ago :eek: that did this. Turned out to be a sensor that went bad. Cant remember what sensor but turned out to be an easy and cheap fix. Of course diagnosing it was the problem.
  6. May 29, 2011 at 8:03 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    check all the vac. lines, but sounds to me like the iacv needs to be taken apart and cleaned and screwed all the way in(the valve part on the bottom).
  7. May 29, 2011 at 8:19 AM
    MTgirl
    Weesa
    Thanks guys...mom wasn't exactly forthcoming with info. She was more into cussing out the mechanic that did the timing belt work :rolleyes:
    The car just hit 100k and dad keeps an eye on regular maint. so whatever the problem is is likely to be mysterious and hard to diagnose
    Fuel filter - possible, I don't think its ever been changed
    Spark plugs - dad just changed those out not too long ago
    Spark plug wires - not sure if those got changed out with the plugs or not
    Vac lines - I will have them check those out
    Sensors, etc - CEL has not been on so I'm thinking that its not likely to be the problem
  8. May 29, 2011 at 8:29 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    wish i was closer...i'd get them squared away. if later they cant figure anything out.....pm HondaGM(james)....he's damned good with hondas. has helped me with the prelude i had and alse my wifes 02 accord.
  9. May 30, 2011 at 3:13 PM
    95SLE
    Tom
    Maryland
    09 RWD Access Cab
    In a GM world the crank position sensor will cause the problem you are describing.
    The good news if it is it will break totally in a short while and the car will not start.
    The bad news is you will not know where you will be when it breaks.
    Hope you get the problem fixed quickly.
  10. May 30, 2011 at 3:34 PM
    jdmdcfan
    jdmdcfan Well-Known Member
    east WA
    dcsb
  11. May 30, 2011 at 3:36 PM
    ryanrocket
    ryanrocket Member
    Rocket
    Murrieta CA
    Tacoma Double cab
    tint, I race motorcycles therefore I have no time for this stuff.
    Bad temp sensor
  12. May 30, 2011 at 3:39 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    That would throw an CEL
    So would this
    And this....
  13. May 30, 2011 at 3:50 PM
    TRDKenE
    TRDKenE DAMN GOOD DEAL!!
    Kenny
    Richmond, Virginia
    '10 D-CAB OFF-ROAD 4X4
    TRD CAI, GrillCraft.
    sounds like it could be a Mass Air Meter..or some other type of sensor as when the vehicle is cold also referred to as Open Loop the engine is running off of computer presets after it reaches operating temp. or Closed Loop the engine then runs off of sensor readings. also not every sensor will set a check engine light...it could be skewing enough to cause a problem but not enough for the computer to recognize a problem and throw a CEL..and it could set a fault with no CEL
  14. May 30, 2011 at 3:51 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    also would throw an CEL.
  15. May 30, 2011 at 3:57 PM
    MTgirl
    Weesa
    Mom and dad made it home safely a little bit ago and the car was fine today! :notsure: I gave mom a list of the things you guys have mentioned; dad will check out what he can and go from there.
  16. May 30, 2011 at 4:00 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Similar thing happened in my 91' Accord way back when but the radiator took a dive so thats what the problem was.
  17. May 30, 2011 at 4:07 PM
    TRDKenE
    Kenny
    Richmond, Virginia
    Not everything throws a CEL Chris...had a Subaru the other day with a bad MAF meter and did not have a CEL..belive me I wish thing were cut and dry it would make my life easier
  18. May 30, 2011 at 4:08 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    What year was it?
  19. May 30, 2011 at 4:11 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Agreed, sounds like an idle air control valve issue. Also, when I used to sell auto parts, the older Hondas seemed to go through ignition modules. Normally I believe they fail hot, but don't run at all. Yours sounds kinda different, but thought I would throw that out there.
  20. May 30, 2011 at 4:16 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Yeah, you would think there would be CEL, or at least a code logged into the computer. I know on my brother's old Dodge Dakota the IACV failed and there was no light or codes present, just wouldn't idle without your foot on the gas.
    Come to think of it, if the OP hasn't already had the computer scanned for codes, that may be a good step to take. I had a crank sensor fail on a Jeep once, it stalled out several times, couldn't figure out what was wrong with it, mechanic couldn't reproduce it, finally pulled the codes and it had a crank sensor code, just had to look and we had our answer. But no check engine light lit up on that one.
